PGIE element could not be created. Exiting
**• Hardware Platform (Jetson / GPU)**GPU3080
• DeepStream Version6.3
I tried to run deepstream-pose-classification using triton version app.
But the app failed as
PGIE element could not be created. Exiting.
What could be wrong?
The config files are as follows
deepstream_pose_classification_config.yaml
source-list:
   list: file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_walk.mov
streammux:
  width: 1280
  height: 720
  batched-push-timeout: 40000
tracker:
  enable: 1
  ll-lib-file: /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
  ll-config-file: /opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_tracker_NvDCF_accuracy.yml
primary-gie:
  plugin-type: 1
  #config-file-path: ../nvinfer/peoplenet_tao/config_infer_primary_peoplenet.txt
  config-file-path: ../triton/peoplenet_tao/config_infer_primary_peoplenet.yml
  #config-file-path: ../triton-grpc/peoplenet_tao/config_infer_primary_peoplenet.yml
secondary-gie0:
  plugin-type: 1
  #config-file-path: ../nvinfer/bodypose3d_tao/config_infer_secondary_bodypose3dnet.txt
  config-file-path: ../triton/bodypose3d_tao/config_infer_secondary_bodypose3dnet.yml
  #config-file-path: ../triton-grpc/bodypose3d_tao/config_infer_secondary_bodypose3dnet.yml
secondary-preprocess1:
  config-file-path: ../nvinfer/bodypose_classification_tao/config_preprocess_bodypose_classification.txt
secondary-gie1:
  plugin-type: 2
  #config-file-path: ../nvinfer/bodypose_classification_tao/config_infer_third_bodypose_classification.txt
  config-file-path: ../triton/bodypose_classification_tao/config_infer_third_bodypose_classification.txt
  #config-file-path: ../triton-grpc/bodypose_classification_tao/config_infer_third_bodypose_classification.yml
sink:
  #0 fakesink
  #1 filesinke generate the out.mp4 file in the current directory
  #2 rtspsink publish at rtsp://localhost:8554/ds-test
  #3 displaysink
  sink-type: 3
infer_config {
  unique_id: 1
  gpu_ids: [0]
  max_batch_size: 1
  backend {
    inputs: [ {
    outputs: [
      {name: "output_bbox/BiasAdd"},
      {name: "output_cov/Sigmoid"}
    triton {
      model_name: "peoplenet"
      version: -1
      model_repo {
        root: "../../../models"
        strict_model_config: true
  preprocess {
    network_format: MEDIA_FORMAT_NONE
    tensor_order: TENSOR_ORDER_LINEAR
    tensor_name: "input_1"
    maintain_aspect_ratio: 0
    frame_scaling_hw: FRAME_SCALING_HW_DEFAULT
    frame_scaling_filter: 1
    normalize {
      scale_factor: 0.0039215697906911373
      channel_offsets: [0, 0, 0]
  postprocess {
    labelfile_path: "../../../models/peoplenet/labels.txt"
    detection {
      num_detected_classes: 1
      per_class_params {
        key: 0
        value { pre_threshold: 0.4 }
      nms {
        confidence_threshold:0.2
        topk:20
        iou_threshold:0.5
  extra {
    copy_input_to_host_buffers: false
    output_buffer_pool_size: 2
input_control {
  process_mode: PROCESS_MODE_FULL_FRAME
  operate_on_gie_id: -1
  interval: 0
infer_config {
  unique_id: 1
  gpu_ids: 0
  max_batch_size: 8
  backend {
    inputs: [
      {name: "input0"},
      {name: "k_inv"},
      {name: "t_form_inv"},
      {name: "scale_normalized_mean_limb_lengths"},
      {name: "mean_limb_lengths"}
    outputs: [
      {name: "pose2d"},
      {name: "pose2d_org_img"},
      {name: "pose25d"},
      {name: "pose3d"}
    triton {
      model_name: "bodypose3dnet"
      version: -1
      model_repo {
    output_mem_type: MEMORY_TYPE_DEFAULT
  preprocess {
    network_format: IMAGE_FORMAT_BGR
    symmetric_padding: 0
    normalize {
  postprocess {
    other {}
  custom_lib {
    path: "../../../apps/tao_others/deepstream-pose-classification/nvdsinfer_custom_impl_BodyPose3DNet/libnvdsinfer_custom_impl_BodyPose3DNet.so"
  extra {
    output_buffer_pool_size: 64
input_control {
  process_mode: PROCESS_MODE_CLIP_OBJECTS
  operate_on_gie_id: 1
  operate_on_class_ids: [0]
  interval: 0
output_control {
  output_tensor_meta: true
infer_config {
  unique_id: 4
  gpu_ids: 0
  max_batch_size: 1
  backend {
    triton {
      model_name: "poseclassificationnet"
      version: -1
      model_repo {
  input_tensor_from_meta {
    is_first_dim_batch: true
  postprocess {
    classification {
      custom_parse_classifier_func: "NvDsParseCustomPoseClassification"
      threshold: 0.51
  custom_lib {
    path: "../../../apps/tao_others/deepstream-pose-classification/infer_pose_classification_parser/libnvdsinfer_pose_classfication_parser.so"
  extra {
    output_buffer_pool_size: 4
output_control {
You can export GST_DEBUG=5 and run the pipeline. maybe you will see the error.
Do I need docker to run triton version?
Docker Containers — DeepStream documentation 6.4 documentation You can try deepstream container with Triton installed. If you installed triton server, maybe you can set ENV GST_DEBUG to see the error
If you want to run inference in triton, it is recommended that you use the following image
nvcr.io/nvidia/deepstream:6.3-gc-triton-devel
thanks let me try
