pi cuda
It’s a device query for nvidia.
/opt/NVIDIA_GPU_Computing_SDK/C/bin/linux/release/deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
There are 4 devices supporting CUDA
Device 0: “Tesla S2050”
CUDA Driver Version: 3.20
CUDA Runtime Version: 3.20
CUDA Capability Major/Minor version number: 2.0
Total amount of global memory: 2817982464 bytes
Multiprocessors x Cores/MP = Cores: 14 (MP) x 32 (Cores/MP) = 448 (Cores)
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 32768
Warp size: 32
Maximum number of threads per block: 1024
Maximum sizes of each dimension of a block: 1024 x 1024 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Clock rate: 1.15 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: No
Integrated: No
Support host page-locked memory mapping: Yes
Compute mode: Default (multiple host threads can use this device simultaneously)
Concurrent kernel execution: Yes
Device has ECC support enabled: Yes
Device is using TCC driver mode: No
Device 1: “Tesla S2050”
Warp size: 32
Integrated: No
Device 2: “Tesla S2050”
Warp size: 32
Integrated: No
Device 3: “Tesla S2050”
Warp size: 32
Integrated: No
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 3.20, CUDA Runtime Version = 3.20, NumDevs = 4, Device = Tesla S2050, Device = Tesla S2050
PASSED
Press to Quit…
And code is
#include <stdio.h>
#include <cuda.h>
#include <math.h>
#define NUM_THREAD 1024
global void cal_pi(float sum, long long nbin, float step, long long nthreads, long long nblocks) {
long long i;
float x;
long long idx = blockIdx.x
blockDim.x+threadIdx.x;
for (i=idx; i< nbin; i+=nthreads*nblocks) {
	x = (i+0.5)*step;
	sum[idx] = sum[idx]+4.0/(1.+x*x);
int main(void) {
long long tid;
float pi = 0;
long long num_steps = 10000000;
dim3 numBlocks(NUM_THREAD*NUM_THREAD*(int)sqrt(NUM_THREAD),1,1);
dim3 threadsPerBlock(NUM_THREAD,1,1);
float *sumHost, *sumDev;
float step = 1./(float)num_steps;
long long size = NUM_THREAD*NUM_THREAD*NUM_THREAD*(int)sqrt(NUM_THREAD)*sizeof(float);
// clock_t before, after;
sumHost = (float *)malloc(size);
cudaMalloc((void **)&sumDev, size);
// Initialize array in device to 0
cudaMemset(sumDev, 0, size);
// before = clock();
// Do calculation on device
printf("Before Compute \n\n");
cal_pi <<<numBlocks, threadsPerBlock>>> (sumDev, (int)num_steps, step, NUM_THREAD, NUM_THREAD*NUM_THREAD*(int)sqrt(NUM_THREAD) ); // call CUDA kernel
printf("After Compute \n\n");
// Retrieve result from device and store it in host array
cudaMemcpy(sumHost, sumDev, size, cudaMemcpyDeviceToHost);
printf("After Copy \n\n");
for(tid=0; tid<NUM_THREAD*NUM_THREAD*NUM_THREAD*(int)sqrt(NUM_THREAD); tid++){
	pi = pi+sumHost[tid];
	printf("The value of PI is %d\n",tid);
pi = pi*step;
//after = clock();
printf("The value of PI is %15.12f\n",pi);
//printf("The time to calculate PI was %f seconds\n",((double)(after - before)/1000.0));
free(sumHost);
cudaFree(sumDev);
return 0;
my problem is pi’s value is 0.00000 why noy 3.1415…
please tell me or edit my code please
thank you
Your blockDim.x is way above the allowed 65535. If you checked your error you would have realized that the kernel simply did not launch.
