Is this a way to reproduce your problem?
γProblemγ
pip3 install stable-baselines
Defaulting to user installation because normal site-packages is not writeable
Collecting stable-baselines
Downloading stable_baselines-2.10.0-py3-none-any.whl (248 kB)
|ββββββββββββββββββββββββββββββββ| 248 kB 2.1 MB/s
Collecting pandas
Downloading pandas-1.0.3.tar.gz (5.0 MB)
|ββββββββββββββββββββββββββββββββ| 5.0 MB 920 kB/s
Installing build dependencies ... done
Getting requirements to build wheel ... done
Preparing wheel metadata ... done
Requirement already satisfied: scipy in ./.local/lib/python3.6/site-packages (from stable-baselines) (1.4.1)
Collecting gym[atari,classic_control]>=0.11
Downloading gym-0.17.1.tar.gz (1.6 MB)
|ββββββββββββββββββββββββββββββββ| 1.6 MB 7.0 MB/s
Requirement already satisfied: matplotlib in ./.local/lib/python3.6/site-packages (from stable-baselines) (3.2.1)
Collecting cloudpickle>=0.5.5
Downloading cloudpickle-1.3.0-py2.py3-none-any.whl (26 kB)
ERROR: Could not find a version that satisfies the requirement opencv-python (from stable-baselines) (from versions: none)
ERROR: No matching distribution found for opencv-python (from stable-baselines)
If so, the dependency issue that occurs when installing stable-baselines is not a JetPack/OpenCV issue, but a stable-baselines and gym issue.
γSolutionγ
γ»Download the source code with git clone. (stable-baselines, gym)
γ»Edit setup.py to remove the problematic pip dependency settings.
After that, installation is possible.
Please install the required packages separately. (pip3 install pandas, etc.)
mkdir ~/github/
cd ~/github
git clone https://github.com/hill-a/stable-baselines
git clone https://github.com/openai/gym
γstable-baselinesγ
vi ~/github/stable-baselines/setup.py
diff -u stable-baselines/setup.py.org stable-baselines/setup.py
--- stable-baselines/setup.py.org 2020-04-23 10:34:43.224638685 +0900
+++ stable-baselines/setup.py 2020-04-23 11:36:31.331999849 +0900
@@ -117,14 +117,14 @@
'stable_baselines': ['py.typed'],
install_requires=[
- 'gym[atari,classic_control]>=0.11',
- 'scipy',
- 'joblib',
- 'cloudpickle>=0.5.5',
- 'opencv-python',
- 'numpy',
- 'pandas',
- 'matplotlib'
+ #'gym[atari,classic_control]>=0.11',
+ #'scipy',
+ #'joblib',
+ #'cloudpickle>=0.5.5',
+ #'opencv-python',
+ #'numpy',
+ #'pandas',
+ #'matplotlib'
] + find_tf_dependency(),
extras_require={
'mpi': [
cd ~/github/stable-baselines
pip3 install -e .
γgymγ
vi ~/github/gym/setup.py
diff -u gym/setup.py.org gym/setup.py
--- gym/setup.py.org 2020-04-23 10:54:09.873214037 +0900
+++ gym/setup.py 2020-04-23 10:55:08.559488149 +0900
@@ -7,7 +7,7 @@
# Environment-specific dependencies.
extras = {
- 'atari': ['atari_py~=0.2.0', 'Pillow', 'opencv-python'],
+ 'atari': ['atari_py~=0.2.0', 'Pillow'],
'box2d': ['box2d-py~=2.3.5'],
'classic_control': [],
'mujoco': ['mujoco_py>=1.50, <2.0', 'imageio'],
install gym
cd ~/github/gym
pip3 install -e .
γtest codeγ
import gym
from stable_baselines.common.policies import MlpPolicy
from stable_baselines.common.vec_env import DummyVecEnv
from stable_baselines import PPO2
env = gym.make('CartPole-v1')
# Optional: PPO2 requires a vectorized environment to run
# the env is now wrapped automatically when passing it to the constructor
# env = DummyVecEnv([lambda: env])
model = PPO2(MlpPolicy, env, verbose=1)
model.learn(total_timesteps=10000)
obs = env.reset()
for i in range(1000):
action, _states = model.predict(obs)
obs, rewards, dones, info = env.step(action)
env.render()
env.close()
I run this code on xavier jetpack 4.3.
It seems to be working.
python a
2020-04-23 11:22:12.228691: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
WARNING:tensorflow:
The TensorFlow contrib module will not be included in TensorFlow 2.0.
For more information, please see:
* https://github.com/tensorflow/community/blob/master/rfcs/20180907-contrib-sunset.md
* https://github.com/tensorflow/addons
* https://github.com/tensorflow/io (for I/O related ops)
If you depend on functionality not listed there, please file an issue.
Wrapping the env in a DummyVecEnv.
WARNING:tensorflow:From /home/ubuntu/github/stable-baselines/stable_baselines/common/tf_util.py:191: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
WARNING:tensorflow:From /home/ubuntu/github/stable-baselines/stable_baselines/common/tf_util.py:200: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2020-04-23 11:22:21.250862: W tensorflow/core/platform/profile_utils/cpu_utils.cc:98] Failed to find bogomips in /proc/cpuinfo; cannot determine CPU frequency
2020-04-23 11:22:21.251782: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x2c2a2940 initialized for platform Host (this does not guarantee that XLA will be used). Devices:
2020-04-23 11:22:21.251875: I tensorflow/compiler/xla/service/service.cc:176] StreamExecutor device (0): Host, Default Version
2020-04-23 11:22:21.277550: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcuda.so.1
2020-04-23 11:22:21.427793: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-04-23 11:22:21.428238: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x2b6e7bf0 initialized for platform CUDA (this does not guarantee that XLA will be used). Devices:
2020-04-23 11:22:21.428369: I tensorflow/compiler/xla/service/service.cc:176] StreamExecutor device (0): Xavier, Compute Capability 7.2
2020-04-23 11:22:21.428997: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-04-23 11:22:21.429204: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1639] Found device 0 with properties:
name: Xavier major: 7 minor: 2 memoryClockRate(GHz): 1.377
pciBusID: 0000:00:00.0
2020-04-23 11:22:21.429340: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-04-23 11:22:21.460582: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2020-04-23 11:22:21.486875: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2020-04-23 11:22:21.523490: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2020-04-23 11:22:21.561647: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2020-04-23 11:22:21.584001: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2020-04-23 11:22:21.654566: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2020-04-23 11:22:21.655115: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-04-23 11:22:21.655503: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-04-23 11:22:21.655590: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1767] Adding visible gpu devices: 0
2020-04-23 11:22:21.655772: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-04-23 11:22:24.034253: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1180] Device interconnect StreamExecutor with strength 1 edge matrix:
2020-04-23 11:22:24.036868: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1186] 0
2020-04-23 11:22:24.036969: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1199] 0: N
2020-04-23 11:22:24.038026: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-04-23 11:22:24.038447: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-04-23 11:22:24.038640: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1325] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 445 MB memory) -> physical GPU (device: 0, name: Xavier, pci bus id: 0000:00:00.0, compute capability: 7.2)
WARNING:tensorflow:From /home/ubuntu/github/stable-baselines/stable_baselines/common/policies.py:116: The name tf.variable_scope is deprecated. Please use tf.compat.v1.variable_scope instead.
WARNING:tensorflow:From /home/ubuntu/github/stable-baselines/stable_baselines/common/input.py:25: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
WARNING:tensorflow:From /home/ubuntu/github/stable-baselines/stable_baselines/common/policies.py:561: flatten (from tensorflow.python.layers.core) is deprecated and will be removed in a future version.
Instructions for updating:
Use keras.layers.flatten instead.
WARNING:tensorflow:From /home/ubuntu/.local/lib/python3.6/site-packages/tensorflow_core/python/layers/core.py:332: Layer.apply (from tensorflow.python.keras.engine.base_layer) is deprecated and will be removed in a future version.
Please use `layer.__call__` method instead.
WARNING:tensorflow:From /home/ubuntu/github/stable-baselines/stable_baselines/common/tf_layers.py:123: The name tf.get_variable is deprecated. Please use tf.compat.v1.get_variable instead.
WARNING:tensorflow:From /home/ubuntu/github/stable-baselines/stable_baselines/common/distributions.py:326: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING:tensorflow:From /home/ubuntu/github/stable-baselines/stable_baselines/common/distributions.py:327: The name tf.log is deprecated. Please use tf.math.log instead.
WARNING:tensorflow:From /home/ubuntu/github/stable-baselines/stable_baselines/ppo2/ppo2.py:190: The name tf.summary.scalar is deprecated. Please use tf.compat.v1.summary.scalar instead.
WARNING:tensorflow:From /home/ubuntu/github/stable-baselines/stable_baselines/ppo2/ppo2.py:198: The name tf.trainable_variables is deprecated. Please use tf.compat.v1.trainable_variables instead.
WARNING:tensorflow:From /home/ubuntu/.local/lib/python3.6/site-packages/tensorflow_core/python/ops/math_grad.py:1424: where (from tensorflow.python.ops.array_ops) is deprecated and will be removed in a future version.
Use tf.where in 2.0, which has the same broadcast rule as np.where
WARNING:tensorflow:From /home/ubuntu/github/stable-baselines/stable_baselines/ppo2/ppo2.py:206: The name tf.train.AdamOptimizer is deprecated. Please use tf.compat.v1.train.AdamOptimizer instead.
WARNING:tensorflow:From /home/ubuntu/github/stable-baselines/stable_baselines/ppo2/ppo2.py:240: The name tf.global_variables_initializer is deprecated. Please use tf.compat.v1.global_variables_initializer instead.
WARNING:tensorflow:From /home/ubuntu/github/stable-baselines/stable_baselines/ppo2/ppo2.py:242: The name tf.summary.merge_all is deprecated. Please use tf.compat.v1.summary.merge_all instead.
2020-04-23 11:22:26.160466: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
| approxkl | 6.406616e-05 |
| clipfrac | 0.0 |
| explained_variance | 0.0302 |
| fps | 45 |
| n_updates | 1 |
| policy_entropy | 0.69308 |
| policy_loss | -0.00029999367 |
| serial_timesteps | 128 |
| time_elapsed | 3.86e-05 |
| total_timesteps | 128 |
| value_loss | 40.308636 |
| approxkl | 7.6444585e-06 |
| clipfrac | 0.0 |
| explained_variance | 0.00111 |
| fps | 120 |
| n_updates | 2 |
| policy_entropy | 0.69283825 |
| policy_loss | -1.502689e-06 |
| serial_timesteps | 256 |
| time_elapsed | 2.81 |
| total_timesteps | 256 |
| value_loss | 25.517273 |
| approxkl | 4.6624176e-05 |
| clipfrac | 0.0 |
| explained_variance | -0.0088 |
| fps | 131 |
| n_updates | 3 |
| policy_entropy | 0.6926168 |
| policy_loss | -0.0017333322 |
| serial_timesteps | 384 |
| time_elapsed | 3.88 |
| total_timesteps | 384 |
| value_loss | 42.726902 |
| approxkl | 7.5763994e-05 |
| clipfrac | 0.0 |
| explained_variance | -0.0303 |
| fps | 117 |
| n_updates | 4 |
| policy_entropy | 0.6916568 |
| policy_loss | -0.0009098172 |
| serial_timesteps | 512 |
| time_elapsed | 4.85 |
| total_timesteps | 512 |
| value_loss | 50.852077 |
