Pitched Texture delivers wrong results?
I believe I am doing something fundamentally wrong when binding pitched memory to 2D textures. I have a kernel that works fine, when the pitch equals the width. Somehow the texture seems to deliver wrong values when the pitch is not equal to the width.
//Texture reference to work represent image data
        texture<unsigned char, 2, cudaReadModeElementType> bayTex;
//Bind Texture to reference
	const textureReference* bayTexPtr;
	cudaGetTextureReference(&bayTexPtr, "bayTex");
	cudaChannelFormatDesc channelDesc = cudaCreateChannelDesc<unsigned char>();
	//Set acces parameters
	bayTex.addressMode[0] = cudaAddressModeClamp;
	bayTex.addressMode[1] = cudaAddressModeClamp;
	//Bind pitched data to texture
	unsigned int width_px = source->d_width / (source->d_padding * source->element_size);
	cudaBindTexture2D(NULL, bayTexPtr, source->d_pointer, &channelDesc, width_px, source->d_height, source->d_pitch);
I am fetching my values with tex2D(bayTex, x, y). When I put in the same image with different crop (resulting in different pitch), the same texture position returns different results.
Any ideas?
Kwyjibo
P.S.: What about that offset parameter? Do I need to use it?
Any ideas?
Kwyjibo
Just tried the minimal example and it works. I am relly confused right now. The error must be somewhere else.
[/code]
#include <stdio.h>
texture<unsigned char, 2, cudaReadModeElementType> arr1Tex;
texture<unsigned char, 2, cudaReadModeElementType> arr2Tex;
//Test texture fetch
global void textureTestKernel()
printf("arr1Tex (3,3): %i\n", tex2D(arr1Tex, 3, 3));
printf("arr2Tex (3,3): %i\n", tex2D(arr2Tex, 3, 3));
int main()
//Allocate arrays
unsigned char arr1[64*64] = {0};
arr1[64*3+3] = 1;
unsigned char* d_pointer_arr1;
size_t pitch_arr1;
unsigned char arr2[50*50] = {0};
arr2[50*3+3] = 1;
unsigned char* d_pointer_arr2;
size_t pitch_arr2;
//Upload arrays
cudaMallocPitch((void**) &d_pointer_arr1, &pitch_arr1, 64, 64);
cudaMallocPitch((void**) &d_pointer_arr2, &pitch_arr2, 50, 50);
cudaMemcpy2D(d_pointer_arr1, pitch_arr1, arr1, 64, 64, 64, cudaMemcpyHostToDevice);
cudaMemcpy2D(d_pointer_arr2, pitch_arr2, arr2, 50, 50, 50, cudaMemcpyHostToDevice);
//Print pitch values
printf("pitch1: %i\n", pitch_arr1);
printf("pitch2: %i\n", pitch_arr2);
//Bind arr1 to reference
const textureReference* arr1TexPtr;
cudaGetTextureReference(&arr1TexPtr, "arr1Tex");
cudaChannelFormatDesc channelDesc1 = cudaCreateChannelDesc<unsigned char>();
arr1Tex.addressMode[0] = cudaAddressModeClamp;
arr1Tex.addressMode[1] = cudaAddressModeClamp;
cudaBindTexture2D(NULL, arr1TexPtr, d_pointer_arr1, &channelDesc1, 64, 64, pitch_arr1);
//Bind arr2 to reference
const textureReference* arr2TexPtr;
cudaGetTextureReference(&arr2TexPtr, "arr2Tex");
cudaChannelFormatDesc channelDesc2 = cudaCreateChannelDesc<unsigned char>();
arr2Tex.addressMode[0] = cudaAddressModeClamp;
arr2Tex.addressMode[1] = cudaAddressModeClamp;
cudaBindTexture2D(NULL, arr2TexPtr, d_pointer_arr2, &channelDesc2, 50, 50, pitch_arr1);
//Start Kernel
textureTestKernel<<<1, 1>>>();
}[/code]
[/code]
#include <stdio.h>
int main()
//Allocate arrays
arr1[64*3+3] = 1;
size_t pitch_arr1;
arr2[50*3+3] = 1;
size_t pitch_arr2;
//Upload arrays
//Start Kernel
}[/code]
Okay,
I’m trying to hunt this bug down.
The values of the first row are fetched correctly, but as soon as the kernel fetches values from the second or third row I get wrong values.
Has anyone ever experienced auch a behaviour?
Regards,
Kwyjibo
Okay,
Regards,
Kwyjibo
