How to decode the image frame with PIXEL_FMT_P016 format?
I do something like this:
_iEGLStreamSettings->setPixelFormat(Argus::PIXEL_FMT_P016);
EGLStream::IFrame *iFrame = Argus::interface_castEGLStream::IFrame(frame);
EGLStream::Image *image = iFrame->getImage();
Please share what your source format is. In general the format after ISP engine is YUV420 and if your source is not 16-bit content, it may not be required to set to PIXEL_FMT_P016.
Thanks for your answer.
I don’t really know what’s a format after ISP.
I use the LI-IMX265-MIPI-M12 camera module. It works with PIXEL_FMT_YCbCr_420_888 as it should, with PIXEL_FMT_RAW16 works without libargus postprocessing? but a can grab a frame and process int via NPP. With PIXEL_FMT_P016 it works (no errors, without libargus) but I can’t decode it (as I do with PIXEL_FMT_RAW16). I expect PIXEL_FMT_P016 will give me a YUV image, 16 (12 provided by sensor) bits per channel.
I want to have a 16-bit color image, but I don’t want to process PIXEL_FMT_RAW16 by NPP because it’s pretty slow (CFA + CCM takes about 50 ms). Libargus can’t process PIXEL_FMT_RAW16 and PIXEL_FMT_P016.
I think argus only support PIXEL_FMT_YCbCr_420_888 and PIXEL_FMT_RAW16, and the PIXEL_FMT_RAW16 is bayer raw format. I don’t think it could be support PIXEL_FMT_P016.
Yes, libargus does not support PIXEL_FMT_P016, but ISP probably do, at least I can grab a frame without errors. As I understand libargus can convert raw nvidia ISP frame (NVMM ?) into the usual CPU buffer. But without libargus i don’t know how to convert ISP frame into conventional CPU buffer.
PIXEL_FMT_P016 ISP frame in pseudocolors looks like this:
The case is not supported by hardware ISP engine. A possible solution is to do raw capture through v4l2 and implement de-bayering algorithm via CUDA. You may start with the sample:
