Pointer to struct How create a typedef?
I’m a new CUDA programmer. The following code can be done in C but I get an error with nvcc.
typedef struct {
unsigned long nn;
} myS;
typedef struct myS* mySPtr; /* error: invalid redeclaration of type name “myS” */
Copyright (c) 2005-2010 NVIDIA Corporation
Built on Thu_Nov__4_13:45:48_PDT_2010
Cuda compilation tools, release 3.2, V0.2.1221
Any ways to do this?
try typedef myS* mySPtr;
Thanks for the fast response!
My problem, as stated, is fixed as you suggested.
However, if I want to put typedef myS* mySPtr1; into a header file, how would I do it?
Is it possible? I don’t want myS to be in the header. In C, I can put the line with the
error into the header file and all works.
typedef myS* mySPtr1; /* not ok here. How put this in header file? */
typedef struct {
  unsigned long nn;
} myS;
//typedef struct myS* mySPtr; /* error: invalid redeclaration of type name “myS” */
typedef myS* mySPtr2; /* ok here */
The reason there is a difference between CUDA and C here is because CUDA processes the code according to C++ rules. g++ gives an essentially identical error to CUDA:
typedef.cpp:8: error: using typedef-name ‘myS’ after ‘struct’
typedef.cpp:6: error: ‘myS’ has a previous declaration here
typedef.cpp:8: error: invalid type in declaration before ‘;’ token
I am not sure what the use case is, but maybe the following approximates what is desired? In a header file typedef.h, put
typedef struct list_node *node_ptr;
Then in a program typedef.cpp, we use this as follows:
#include <stdlib.h>
#include <stdio.h>
#include "typedef.h"
typedef struct list_node node;
struct list_node {
    unsigned long nn;
    node_ptr next;
int main (void)
    node foo;
    node_ptr bar;
foo.nn = 0xfeedbeefL;
    bar = &foo;
    foo.next = bar;
    printf ("bar=%p  bar->nn=%lx  bar->next=%p\n", bar, bar->nn, bar->next);
    return EXIT_SUCCESS;
Perfect :) Thanks for the help!
The following is my working example. From it, I can see that the struct needed to be explicitly named rather than anonymous.
typedef struct myNamedS* myNamedSPtr1;
   typedef struct myNamedS* myNamedSPtr2;
   struct myNamedS {
      unsigned long nn;
   typedef struct myNamedS* myNamedSPtr3;
Thanks again!
