Hi everyone
i n my cuda code i have a struct like this :
typedef struct {
char tur;
int a;
int b;
dim3 d1, d2;
char message[100];
}mytype_t;
but when i described a local variable (in a global func. ) , in compilation i have this error :
1>d:\projects\cuda\cuda_pro\cuda_pro\kernel.cu(22): error: identifier “_ZN7mytype_tC1Ev” is undefined
but variable declaration consists. i got same problem in both linux and windows compilations of code.
what does this error means and how can i fix it ?
LSChien
2
use uint3, which also has three unsigned int
typedef struct {
char tur;
int a;
int b;
uint3 d1, d2;
char message[100];
}mytype_t;
avidday
3
It means that some C++ name mangling is interfering with your type declaration so it is unrecognizable to the linker. Try declaring it like this
extern "C" {
typedef struct {
char tur;
int a;
int b;
dim3 d1, d2;
char message[100];
}mytype_t;
and see whether it makes any difference.
