I’m trying to port a camera driver for R24 (kernel 3.x) to R28.1 (kernel 4.x), and am having trouble getting the driver to complete initialization at boot time. It looks like the camera driver itself is loading, but the I2C interface isn’t. This is for an IMX172 camera sensor hooked up through a Leopard Imaging carrier card. It was working on the same hardware using R24, but I haven’t had any luck getting it to run on the newer OS.
Here are the relevant lines getting printed to dmesg at boot time:
[ 3.356309] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.357164] i2c /dev entries driver
[ 3.358904] [IMX172]: probing v4l2 sensor.
[ 3.377878] imx172 30-0052: imx172_probe: name imx172_a
[ 3.377920] imx172 30-0052: imx172_ctrls_init++
[ 3.377971] MPJ initing 4 ctrls.
[ 3.377972] imx172 30-0052: Detected IMX172 sensor
[ 3.378735] pca9570 30-0024: pca9570_icr_move, forward val=5
[ 3.401101] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x24
[ 3.412814] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 3.412819] pca9570 30-0024: pca9570_icr_move:i2c write failed
[ 3.412926] pca9570: probe of 30-0024 failed with error -121
[ 3.413635] IR NEC protocol handler initialized
I’m wondering if my device tree is incorrect for the PCA9570. The camera driver is for an IMX172, so I’ve been using the IMX185 driver as a guide when porting. Here are the two device tree files I created.
tegra210-camera-imx172-a00.dtsi:
#include <dt-bindings/media/camera.h>
#include <dt-bindings/platform/t210/t210.h>
host1x {
vi {
num-channels = <2>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
liimx172_vi_in0: endpoint {
csi-port = <0>;
bus-width = <4>;
remote-endpoint = <&liimx172_out0>;
i2c@546c0000 {
avdd_dsi_csi-supply = <&max77620_gpio7>;
status = "okay";
#size-cells = <0>;
tca9546@70 {
i2c@0 {
imx172_a@52 {
compatible = "nvidia,imx172";
reg = <0x52>;
//devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "4.000";
physical_h = "3.000";
sensor_model ="imx172";
avdd-reg = "vana";
iovdd-reg = "vif";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
/* Defines number of frames to be dropped by driver internally after applying */
/* sensor crop settings. Some sensors send corrupt frames after applying */
/* crop co-ordinates */
post_crop_frame_drop = "0";
/* Convert Gain to unit of dB (decibel) befor passing to kernel driver */
use_decibel_gain = "true";
/* if true, delay gain setting by one frame to be in sync with exposure */
/* delayed_gain = "true"; */
/* enable CID_SENSOR_MODE_ID for sensor modes selection */
use_sensor_mode_id = "true";
mode0 { // mode IMX172_MODE_4000X3000
mclk_khz = "24000";
num_lanes = "4";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0xE";
dynamic_pixel_bit_depth = "12";
csi_pixel_bit_depth = "12";
mode_type = "bayer";
pixel_phase = "rggb";
pixel_t = "bayer_rggb";
active_w = "4000";
active_h = "3000";
readout_orientation = "0";
line_length = "6500"; // = hmax(540) * 8, one line time = line_length / pix_clk_hz (seconds)
inherent_gain = "1";
mclk_multiplier = "25";
pix_clk_hz = "400000000"; // imx172 : 400000000 = 50Mhz * 8
min_gain_val = "1.0"; /* dB */ // Defined in imx172.c
max_gain_val = "100"; /* dB */ // Defined in imx172.c
min_hdr_ratio = "1";
max_hdr_ratio = "64";
min_framerate = "2.2290"; // = 1 / max_exp_time
max_framerate = "10";
min_exp_time = "44"; // 4 line time, in micro-second
max_exp_time = "33000"; // max exposure time = 33ms, in micro-second
embedded_metadata_height = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
liimx172_out0: endpoint {
csi-port = <0>;
bus-width = <4>;
remote-endpoint = <&liimx172_vi_in0>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
num_csi_lanes = <4>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
modules {
module0 {
badge = "imx172_bottomleft_A6V24";
position = "bottomleft";
orientation = "1";
status = "okay";
drivernode0 {
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver v4l2 device name */
devname = "imx172 7-0052";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/host1x/i2c@546c0000/tca9546@70/i2c@0/imx172_a@52";
status = "okay";
tegra210-jetson-cv-camera-imx172-a00.dtsi:
#include "tegra210-camera-imx172-a00.dtsi"
//#define CAM0_RST_L TEGRA_GPIO(S, 4)
#define CAM0_RST TEGRA_GPIO(S, 4)
#define CAM0_PWDN TEGRA_GPIO(S, 7)
#define CAM1_PWDN TEGRA_GPIO(T, 0)
#define CAM0_SID TEGRA_GPIO(E, 8)
#define CAM1_RST_L TEGRA_GPIO(S, 5)
//#define CAMERA_I2C_MUX_BUS(x) (0x1E + x)
/* camera control gpio definitions */
host1x {
i2c@546c0000 {
tca9546@70 {
compatible = "nxp,pca9546";
reg = <0x70>;
#size-cells = <0>;
vif-supply = <&en_vdd_cam>;
vcc_lp = "vif";
i2c@0 {
reg = <0>;
i2c-mux,deselect-on-exit;
#size-cells = <0>;
pca9570_a@24 {
compatible = "nvidia,pca9570";
reg = <0x24>;
channel = "a";
host1x {
i2c@546c0000 {
tca9546@70 {
/* compatible = "nxp,pca9546";
* reg = <0x70>;
* #address-cells = <1>;
* #size-cells = <0>;
* vcc-supply = <&en_vdd_cam>;
* force_bus_start = <CAMERA_I2C_MUX_BUS(0)>;
vcc_lp = "vif";
i2c@0 {
imx172_a@52 {
clocks = <&tegra_car TEGRA210_CLK_CLK_OUT_3>;
clock-names = "clk_out_3";
clock-frequency = <24000000>;
mclk = "clk_out_3";
reset-gpios = <&gpio CAM0_RST GPIO_ACTIVE_HIGH>;
pwdn-gpios = <&gpio CAM0_RST GPIO_ACTIVE_HIGH>;
sid-gpios = <&tca9539_77 1 GPIO_ACTIVE_HIGH>;
vana_supply = <&en_vdd_cam_hv_2v8>;
gpio: gpio@6000d000 {
camera-control {
gpio-output-low = <
CAM0_RST
CAM0_PWDN
Does anyone have any ideas of what might not be configured correctly above?
Is there a guide for the upgrade process in the device tree between the two kernel versions? After this I’m going to be working on porting the driver to the TX2, so I’m guessing the device tree is going to need to change there as well.
