Porting from TI am68a to jetson Orin Nano
We are porting from TI am68a to jetson Orin Nano
The requirements:
Mic array integration
camara integration ( 3 camaras using TIv3link)
wifi integaration (using intel wifi card)
GSM integration (using PPP)
RADAR intergration (UART)
LDR integration ( GPIO input)
so these requirement is possible in jetson orin nano ?
The Jetson Orin Nano is a powerful and versatile module that can support a wide range of applications, including those with multiple peripherals and interfaces. Based on the requirements you’ve listed, here’s a breakdown of the possibilities and potential challenges:
  1. Mic array integration: The Jetson Orin Nano has a 40-pin GPIO Expansion Header, which can be used to connect a microphone array. Additionally, the module supports I2S (Inter-IC Sound) and DMIC (Digital Microphone Interface) audio interfaces, which can be used for microphone array integration.
  2. Camera integration (3 cameras using TI v3link): The Jetson Orin Nano has a MIPI CSI interface, which can be used to connect cameras. The module supports up to 6 cameras, so connecting 3 cameras using TI v3link should be possible. However, you may need to ensure that the camera modules are compatible with the Jetson Orin Nano’s MIPI CSI interface.
  3. WiFi integration using Intel WiFi card: The Jetson Orin Nano has a USB interface, which can be used to connect an Intel WiFi card. This should be a straightforward integration, as the module supports USB-based WiFi connectivity.
  4. GSM integration using PPP: The Jetson Orin Nano has a UART interface, which can be used to connect a GSM module. The module also supports PPP (Point-to-Point Protocol), which can be used for GSM connectivity. However, you may need to ensure that the GSM module is compatible with the Jetson Orin Nano’s UART interface.
  5. RADAR integration: The Jetson Orin Nano has a GPIO interface, which can be used to connect a RADAR module. However, the specifics of the RADAR integration will depend on the type of RADAR module being used and its interface requirements.
  6. UART integration: The Jetson Orin Nano has a UART interface, which can be used for serial communication with other devices.
  7. LDR integration: The Jetson Orin Nano has a GPIO interface, which can be used to connect an LDR (Light Dependent Resistor) module.
  8. GPIO input: The Jetson Orin Nano has a 40-pin GPIO Expansion Header, which can be used to connect GPIO inputs.
In comparison to the TI am68a, the Jetson Orin Nano offers a more powerful processing platform, with a NVIDIA Ampere GPU and a Arm Cortex-A78AE CPU. The module also has a more comprehensive set of interfaces, including USB, UART, SPI, and I2C.
However, there are some potential challenges to consider when porting from the TI am68a to the Jetson Orin Nano:
  • Power consumption: The Jetson Orin Nano has a higher power consumption than the TI am68a, which may require additional power management and thermal design considerations.
  • Software compatibility: The Jetson Orin Nano runs on a different operating system (Linux-based) and has a different software development kit (SDK) than the TI am68a. This may require significant software modifications and porting efforts.
  • Hardware compatibility: The Jetson Orin Nano has a different hardware architecture and interface set than the TI am68a, which may require hardware modifications and interface adaptations.
In summary, the Jetson Orin Nano can support the requirements you’ve listed, but may require additional design considerations, software modifications, and hardware adaptations to ensure compatibility and optimal performance. It’s recommended to consult the Jetson Orin Nano documentation and development resources to ensure a smooth transition from the TI am68a.
so its all possible in jetson orin nano Development kit ?
We didn ‘t try them all, but suppose should work.
