I bought Jetson Orin Nano 8GB which has a part number - 900-13767-0030-000 from NVIDIA via Arrow. I can’t see any USB or HDMI port in that device. I don’t know how to connect that to my monitor. Do I need to purchase a separate carrier board (having these ports)? Can you please suggest?
If it is expensive to integrate this Jetson Orin Nano device then can I return this item and buy a Jetson Orin Nano Super Developer kit? It seems like it is currently not available. I wanted to ask when will it be available?
I already spent more than $250 to buy that Jetson Nano Orin 8 GB and not struggling with integrating with my computer. Can you please suggest a best possible way so that my money is not wasted?
Thank you.
Suppopsed what you bought is just a module, then you still need a carrier board to combine it as a developer kit.
You can purchase the carrier board from our ecosystem partners: Robotics & Edge AI | NVIDIA Jetson
Thank you. I got the JNX42-M.2 carrier board. I also mounted Jetson Orin Nano 8GB module on top of that. Can you please help me to know the steps to boot? Do I need to insert any MicroSD card in the board? I can’t see any slot for that. Do I need to insert any SD card to proceed?
Can’t I just use the device without any SD card to run the ML algorithm using Python code?
Also, which barrel power supply I should buy to power JNX42-M.2? Is this link looks good to you which has 12V, 6A rating?
