Hi guys,
Trying to make the TX2’s USB0 USB 2.0 OTG work on our own circuit board is an ongoing headache. We have tried to follow the Platform Adaption and Bring-Up Guide to no avail.
Could you please enlighten us on the complete and comprihensive way to do this, not just link to disconnected forum posts and pdf documents? I know we are not the only team driven to despair over how to configure USB0 for USB 2.0 OTG.
Our hardware has USB 2.0 OTG on the USB0 port. We have verified USB functionality by flashing the module through this port. There is no other USB functionality (no USB 3.0 and no other USB ports in use.) We don’t use PCIe. We have followed the OEM Product Design Guide and grounded the unused signals PEX0_RX+/-, PEX1_RX+/-, PEX2_RX+/- and PEX_RFU_RX+/-. These signals float on the development board when no USB3.0 or PCIe device is plugged in.
The baseline dts from Nvidia works, in that the development kit turns VBUS0 high when an OTG adapter is plugged in. Our hardware remains incapable of this. We seriously consider giving up on dts configuration and spin another version of our PCB where we let the RX pins float like on the development kit.
Struggling to find overarching documentation on the subject (Platform Adaption guide including), we have unsuccessfully tried one edit at the time. Thus far we have seen that:
hardware/nvidia/platform/t18x/common/kernel-dts/t18x-commonplatforms/tegra186-quill-power-tree-p3310-1000-a00-00.dtsi: vbus-2-supply = <&battery_reg>;
ID=0 → VBUS=5 works on dev-kit, not on our PCB
pcie0_lane2_mux { … “okay”
pads, ports usb3 … “disabled”
ID=0 → VBUS=5 fails on both dev-kit and our PCB
Our todo list includes:
Find out where the ODMDATA is defined and what string could possibly be the inverse of “enable-xusb-on-uphy-lane0”
Experiment further with xhci@3530000 {…
Bypass hardware USB 2.0 OTG in our product given the complexity of this stuff
Any help welcome. Qualified help very welcome!
Thanks,
Børge
Better sharing what you’ve done to your dts as a patch and your schematics. Also current boot up log.
Thanks guys!
We’ve been parsing pdfs and forum posts like there is no tomorrow. And today it works! Here is our patch. We’d appreciate your comments on whether all the changes we made are indeed needed for a system where:
- USB0 OTG USB 2.0 is the only USB port
- There are no PCIe ports
- There is no USB 3.0 functionality
- PEXn_RX+/- are all grounded
Cheers,
Børge
— a/nvidia/platform/t18x/common/kernel-dts/t18x-common-platforms/tegra186-quill-common-p3310-1000-a00.dtsi
+++ b/nvidia/platform/t18x/common/kernel-dts/t18x-common-platforms/tegra186-quill-common-p3310-1000-a00.dtsi
@@ -60,7 +60,7 @@
gpios = <TEGRA_MAIN_GPIO(R, 3) 0>;
output-low;
label = “pcie-lane2-mux”;
diff --git a/nvidia/platform/t18x/common/kernel-dts/t18x-common-platforms/tegra186-quill-power-tree-p3310-1000-a00-00.dtsi b/nvidia/platform/t18x/common/kernel-dts/t18x-common-platforms/tegra186-quill-power-tree-p3310-1000-a00-00.dtsi
index f604a600be56…7f2bc9a36c0e 100644
— a/nvidia/platform/t18x/common/kernel-dts/t18x-common-platforms/tegra186-quill-power-tree-p3310-1000-a00-00.dtsi
+++ b/nvidia/platform/t18x/common/kernel-dts/t18x-common-platforms/tegra186-quill-power-tree-p3310-1000-a00-00.dtsi
@@ -106,7 +106,7 @@
pinctrl@3520000 {
vbus-0-supply = <&vdd_usb0_5v>;
vbus-1-supply = <&vdd_usb1_5v>;
diff --git a/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-a00-00-base.dts b/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-a00-00-base.dts
index ed560d3de52d…6c0380c48dad 100644
— a/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-a00-00-base.dts
+++ b/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-a00-00-base.dts
@@ -118,19 +118,14 @@
#if TEGRA_XUSB_PADCONTROL_VERSION >= DT_VERSION_2
xhci@3530000 {
status = “okay”;
phys = <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-0}>,
<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-1}>,
<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-2}>,
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-1}>;
phy-names = "usb2-0", "usb2-1", "usb2-2", "usb3-1";
phys = <&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(0)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(1)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_USB3_P(1)>;
phy-names = "utmi-0", "utmi-1", "usb3-1";
phys = <&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(0)>;
phy-names = "utmi-0";
nvidia,boost_cpu_freq = <800>;
#endif
@@ -157,11 +152,11 @@
usb2-1 {
nvidia,function = “xusb”;
@@ -169,15 +164,15 @@
lanes {
usb3-0 {
@@ -191,22 +186,24 @@
nvidia,oc-pin = <0>;
usb2-1 {
vbus-supply = <&battery_reg>;
nvidia,oc-pin = <1>;
usb3-0 {
nvidia,usb2-companion = <2>;
status = "disabled";
usb3-1 {
nvidia,usb2-companion = <1>;
Thanks guys!
Cheers,
Børge
@@ -60,7 +60,7 @@
output-low;
@@ -106,7 +106,7 @@
pinctrl@3520000 {
xhci@3530000 {
status = “okay”;
#endif
usb2-1 {
lanes {
usb3-0 {
usb2-1 {
usb3-0 {
usb3-1 {
Thanks guys!
Cheers,
Børge
ODMDATA 0x00090000
@@ -60,7 +60,7 @@
output-low;
@@ -106,7 +106,7 @@
pinctrl@3520000 {
xhci@3530000 {
status = “okay”;
#endif
usb2-1 {
lanes {
usb3-0 {
usb2-1 {
usb3-0 {
usb3-1 {
