I use usb camera. Therefore, I refer the following.
GST_DEBUG_CATEGORY_EXTERN (NVDS_APP);
static gboolean
set_camera_csi_params (NvDsSourceConfig * config, NvDsSrcBin * bin)
g_object_set (G_OBJECT (bin->src_elem), “sensor-id”,
config->camera_csi_sensor_id, NULL);
// GST_CAT_DEBUG (NVDS_APP, “Setting csi camera params successful”);
return TRUE;
static gboolean
set_camera_v4l2_params (NvDsSourceConfig * config, NvDsSrcBin * bin)
gchar device[64];
g_snprintf (device, sizeof (device), “/dev/video%d”,
config->camera_v4l2_dev_node);
g_object_set (G_OBJECT (bin->src_elem), “device”, device, NULL);
// GST_CAT_DEBUG (NVDS_APP, “Setting v4l2 camera params successful”);
return TRUE;
static gboolean
create_camera_source_bin (NvDsSourceConfig * config, NvDsSrcBin * bin)
GstCaps *caps = NULL, *caps1 = NULL, *convertCaps = NULL;
gboolean ret = FALSE;
switch (config->type) {
case NV_DS_SOURCE_CAMERA_CSI:
bin->src_elem =
gst_element_factory_make (NVDS_ELEM_SRC_CAMERA_CSI, “src_elem”);
g_object_set (G_OBJECT (bin->src_elem), “bufapi-version”, TRUE, NULL);
g_object_set (G_OBJECT (bin->src_elem), “maxperf”, TRUE, NULL);
break;
case NV_DS_SOURCE_CAMERA_V4L2:
bin->src_elem =
gst_element_factory_make (NVDS_ELEM_SRC_CAMERA_V4L2, “src_elem”);
bin->cap_filter1 =
gst_element_factory_make (NVDS_ELEM_CAPS_FILTER, “src_cap_filter1”);
if (!bin->cap_filter1) {
NVGSTDS_ERR_MSG_V (“Could not create ‘src_cap_filter1’”);
goto done;
caps1 = gst_caps_new_simple (“video/x-raw”,
“width”, G_TYPE_INT, config->source_width, “height”, G_TYPE_INT,
config->source_height, “framerate”, GST_TYPE_FRACTION,
config->source_fps_n, config->source_fps_d, NULL);
break;
default:
NVGSTDS_ERR_MSG_V (“Unsupported source type”);
goto done;
if (!bin->src_elem) {
NVGSTDS_ERR_MSG_V (“Could not create ‘src_elem’”);
goto done;
bin->cap_filter =
gst_element_factory_make (NVDS_ELEM_CAPS_FILTER, “src_cap_filter”);
if (!bin->cap_filter) {
NVGSTDS_ERR_MSG_V (“Could not create ‘src_cap_filter’”);
goto done;
caps = gst_caps_new_simple (“video/x-raw”, “format”, G_TYPE_STRING, “NV12”,
if (config->type == NV_DS_SOURCE_CAMERA_CSI) {
GstCapsFeatures *feature = NULL;
feature = gst_caps_features_new (“memory:NVMM”, NULL);
gst_caps_set_features (caps, 0, feature);
if (config->type == NV_DS_SOURCE_CAMERA_V4L2) {
GstElement *nvvidconv2;
#ifndef IS_TEGRA
GstElement *nvvidconv1;
nvvidconv1 = gst_element_factory_make (“videoconvert”, “nvvidconv1”);
if (!nvvidconv1) {
NVGSTDS_ERR_MSG_V (“Failed to create ‘nvvidconv1’”);
goto done;
#endif
feature = gst_caps_features_new ("memory:NVMM", NULL);
g_object_set (G_OBJECT (bin->cap_filter), "caps", caps, NULL);
g_object_set (G_OBJECT (bin->cap_filter1), "caps", caps1, NULL);
nvvidconv2 = gst_element_factory_make (NVDS_ELEM_VIDEO_CONV, "nvvidconv2");
if (!nvvidconv2) {
NVGSTDS_ERR_MSG_V ("Failed to create 'nvvidconv2'");
goto done;
g_object_set (G_OBJECT (nvvidconv2), "gpu-id", config->gpu_id,
"nvbuf-memory-type", config->nvbuf_memory_type, NULL);
#ifndef IS_TEGRA
gst_bin_add_many (GST_BIN (bin->bin), bin->src_elem, bin->cap_filter1,
nvvidconv1, nvvidconv2, bin->cap_filter,
NULL);
#else
nvvidconv2, bin->cap_filter, NULL);
#endif
NVGSTDS_LINK_ELEMENT (bin->src_elem, bin->cap_filter1);
#ifndef IS_TEGRA
NVGSTDS_LINK_ELEMENT (bin->cap_filter1, nvvidconv1);
NVGSTDS_LINK_ELEMENT (nvvidconv1, nvvidconv2);
#else
NVGSTDS_LINK_ELEMENT (bin->cap_filter1, nvvidconv2);
#endif
NVGSTDS_LINK_ELEMENT (nvvidconv2, bin->cap_filter);
NVGSTDS_BIN_ADD_GHOST_PAD (bin->bin, bin->cap_filter, "src");
} else {
gst_bin_add_many (GST_BIN (bin->bin), bin->src_elem, bin->cap_filter, NULL);
NVGSTDS_LINK_ELEMENT (bin->src_elem, bin->cap_filter);
if (!set_camera_csi_params (config, bin)) {
NVGSTDS_ERR_MSG_V (“Could not set CSI camera properties”);
goto done;
break;
if (!set_camera_v4l2_params (config, bin)) {
NVGSTDS_ERR_MSG_V (“Could not set V4L2 camera properties”);
goto done;
break;
default:
goto done;
ret = TRUE;
// GST_CAT_DEBUG (NVDS_APP, “Created camera source bin successfully”);
done:
if (caps)
gst_caps_unref (caps);
if (convertCaps)
gst_caps_unref (convertCaps);
if (!ret) {
NVGSTDS_ERR_MSG_V (“%s failed”, func);
return ret;
gboolean
create_source_bin (NvDsSourceConfig * config, NvDsSrcBin * bin)
static guint bin_cnt = 0;
gchar bin_name[64];
g_snprintf(bin_name, 64, “src_bin_%d”, bin_cnt++);
bin->bin = gst_bin_new (bin_name);
if (!bin->bin) {
NVGSTDS_ERR_MSG_V (“Failed to create ‘src_bin’”);
return FALSE;
if (!create_camera_source_bin (config, bin)) {
return FALSE;
break;
case NV_DS_SOURCE_URI:
// if (!create_uridecode_src_bin (config, bin)) {
// return FALSE;
// bin->live_source = config->live_source;
break;
case NV_DS_SOURCE_RTSP:
// if (!create_rtsp_src_bin (config, bin)) {
// return FALSE;
break;
default:
NVGSTDS_ERR_MSG_V (“Source type not yet implemented!\n”);
return FALSE;
// GST_CAT_DEBUG (NVDS_APP, “Source bin created”);
return TRUE;
And then I add the following to “Main()”. But I don’t understand how to send the arg of “create_source_bin()”. Should I send what? Because it the first arg needs config format and the second arg needs “bin” format.
GstElement *source_bin = create_source_bin (pgie, argv[1]);
if (!source_bin) {
g_printerr (“Failed to create source bin. Exiting.\n”);
return -1;
deepstream_pose_estimation_app.zip (6.8 KB)
