Hello forum,
I found an issue in “vi5_fops.c” in the jetpack6 / l4t 36.4.0 release.
Is it possible to include this bugfix in upstream?
When repeatedly starting streaming with the VIDIOC_STREAMON
it might happen that it is not possible to receive images, because tegra_channel_kthread_capture_enqueue
aborts because chan->capture_reqs_enqueued
has inconsistent value.
vi5_fops.c source
if ((chan->capture_state == CAPTURE_ERROR)
|| !(chan->capture_reqs_enqueued
< (chan->capture_queue_depth * chan->valid_ports))) {
spin_unlock_irqrestore(
&chan->capture_state_lock, flags);
break;
resetting chan->capture_reqs_enqueued
when stopping streaming solves this issue (similar to the error recovery routine) 0008-tegra-camera-vi-reset-capture-requests-count-on-chan.txt (1.0 KB)
What’s the test and how to observe the issue?
Hi ShaneCCC,
I created a small example application in c++ that shows the behaviour.
Without the fix the output of the application will show this message after a few toggles:
Streaming started
Timeout waiting for frame
With the fix the application will just keep running and print this:
Streaming started
Captured frame 0, size: 1240064 bytes
Captured frame 1, size: 1240064 bytes
Captured frame 2, size: 1240064 bytes
Captured frame 3, size: 1240064 bytes
Captured frame 4, size: 1240064 bytes
Captured frame 5, size: 1240064 bytes
Captured frame 6, size: 1240064 bytes
Captured frame 7, size: 1240064 bytes
Captured frame 8, size: 1240064 bytes
Captured frame 9, size: 1240064 bytes
Streaming stopped
main.cpp.txt (4.2 KB)
How about set the capture_reqs_enqueued to 0 in the tegra_channel_init_ring_buffer()?
diff --git a/drivers/media/platform/tegra/camera/vi/channel.c b/drivers/media/platform/tegra/camera/vi/channel.c
index bb60ba4ad6..1026c73d09 100644
--- a/drivers/media/platform/tegra/camera/vi/channel.c
+++ b/drivers/media/platform/tegra/camera/vi/channel.c
@@ -471,6 +471,7 @@ void tegra_channel_init_ring_buffer(struct tegra_channel *chan)
chan->capture_descr_index = 0;
chan->capture_descr_sequence = 0;
chan->queue_error = false;
+ chan->capture_reqs_enqueued = 0;
EXPORT_SYMBOL(tegra_channel_init_ring_buffer);
Yes, that is a better place for that.
Thank you :)
