Hello everyone,
I use JetPack 5.0 preview on Jetson Orin, I modified imx318 to imx586 according to medium, generate ko file, the driver has been able to load successfully and find video0, but when I test it with v4l2-ctl, I can’t receive data, dmesg log as follows:
ubuntu login: [ 633.047219] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 633.047501] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 633.048145] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 633.048347] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 633.048621] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 633.048828] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 633.049329] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 635.607189] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 635.607465] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 635.608156] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 635.608371] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 635.608661] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 635.608886] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 635.609324] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 638.135181] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 638.135447] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 638.136295] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 638.136511] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 638.136791] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 638.137000] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 638.137435] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 638.143049] bwmgr API not supported
