Post-update old CUDA Drivers still hanging
Hi there, I recently updated my NVIDIA Drivers and CUDA Toolkit to the latest version, see below for the nvidia-smi output.
| NVIDIA-SMI 545.23.06              Driver Version: 545.23.06    CUDA Version: 12.3     |
| GPU  Name                 Persistence-M | Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |         Memory-Usage | GPU-Util  Compute M. |
|                                         |                      |               MIG M. |
|   0  Quadro RTX 5000                On  | 00000000:01:00.0 Off |                  N/A |
| N/A   68C    P8              20W / 110W |   2249MiB / 16384MiB |      4%      Default |
|                                         |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                            GPU Memory |
|        ID   ID                                                             Usage      |
|    0   N/A  N/A     29480      G   /usr/lib/xorg/Xorg                         1012MiB |
|    0   N/A  N/A     29947      G   /usr/bin/gnome-shell                        340MiB |
|    0   N/A  N/A     30573      G   /usr/bin/gjs-console                         21MiB |
|    0   N/A  N/A     30818      G   ...,WinRetrieveSuggestionsOnlyOnDemand       36MiB |
|    0   N/A  N/A     30862      G   ...vice,SpareRendererForSitePerProcess      263MiB |
|    0   N/A  N/A     31169      G   ...ures=SpareRendererForSitePerProcess      296MiB |
|    0   N/A  N/A    318550    C+G   ...74756456,5044128994603659582,262144      170MiB |
I then moved on and configured my Docker so that I can use it with these latest Drivers and Toolkit. Everything went smoothly; however, after installing the nvidia-container-toolkit I got prompted with the following:
The following packages were automatically installed and are no longer required:
cuda-cccl-12-2 cuda-command-line-tools-12-2 cuda-compiler-12-2 cuda-crt-12-2 cuda-cudart-12-2 cuda-cudart-12-3 cuda-cudart-dev-12-2 cuda-cuobjdump-12-2 cuda-cupti-12-2 cuda-cupti-dev-12-2 cuda-cuxxfilt-12-2 cuda-documentation-12-2
cuda-driver-dev-12-2 cuda-gdb-12-2 cuda-libraries-12-2 cuda-libraries-12-3 cuda-libraries-dev-12-2 cuda-nsight-12-2 cuda-nsight-compute-12-2 cuda-nsight-systems-12-2 cuda-nvcc-12-2 cuda-nvdisasm-12-2 cuda-nvml-dev-12-2 cuda-nvprof-12-2
cuda-nvprune-12-2 cuda-nvrtc-12-2 cuda-nvrtc-12-3 cuda-nvrtc-dev-12-2 cuda-nvtx-12-2 cuda-nvvm-12-2 cuda-nvvp-12-2 cuda-opencl-12-2 cuda-opencl-12-3 cuda-opencl-dev-12-2 cuda-profiler-api-12-2 cuda-sanitizer-12-2 cuda-toolkit-12-2
cuda-toolkit-12-2-config-common cuda-toolkit-12-3-config-common cuda-toolkit-12-config-common cuda-toolkit-config-common cuda-tools-12-2 cuda-visual-tools-12-2 gds-tools-12-2 gds-tools-12-3 libcublas-12-2 libcublas-12-3
libcublas-dev-12-2 libcufft-12-2 libcufft-12-3 libcufft-dev-12-2 libcufile-12-2 libcufile-12-3 libcufile-dev-12-2 libcufile-dev-12-3 libcurand-12-2 libcurand-12-3 libcurand-dev-12-2 libcusolver-12-2 libcusolver-12-3 libcusolver-dev-12-2
libcusparse-12-2 libcusparse-12-3 libcusparse-dev-12-2 libnpp-12-2 libnpp-12-3 libnpp-dev-12-2 libnvjitlink-12-2 libnvjitlink-12-3 libnvjitlink-dev-12-2 libnvjpeg-12-2 libnvjpeg-12-3 libnvjpeg-dev-12-2 libtinfo5 nsight-compute-2023.2.2
nsight-systems-2023.2.3 nvidia-firmware-535-535.113.01 nvidia-modprobe
with the usual hint on how to remove them with autoremove.
Now, it seems for some reason that CUDA 12.2 is still around on my system, and I refrained from launching an autoremove because it seems to me that there are also CUDA 12.3 packages in that list and don’t want to mess-up/break anything by removing them…
If that’s the case is there a reason why the system is picking up those packages when they are currently in use? Also, if that’s the case and those CUDA 12.2 packages are no longer required is there a safe way to purge them without having to reinstall everything form zero? Let me know, thanks in advance!
I went back to an old post for a very similar issue I had.
Thanks to @generix the problem was solved back then and also in this case the approach seemed to be working! Essentially, for some reason CUDA did not complete the installation of the new Toolkit which was producing the hanging dependencies detected by autoremove.
After running sudo apt install cuda the latter were correctly installed, and I follow up removing the old CUDA Toolkit; one thing that would be helpful in these cases would be if CUDA pointed out about partial install so that users are aware of the source for this issue.
I think this post can be close for now.
