Which model is supported by jetson nano because while trying to run fasterRcnn and yolov4 samples on jetson nano device i get for fatserRcnn model out of memory problem and for yolov3 the run interrupt and log shows “killed” message.
***env ***
Jetson Nano
jetpack 4.5.1
DeepStream 5.1
Please remember to share the environment information first.
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
