This is the method I followed using L4T 32.2 sources. My host machine has Ubuntu 18.04.2 and I worked on my home folder:
# Install required packages
sudo apt-get update
sudo apt-get install libncurses5-dev build-essential bc lbzip2
# Work folder
mkdir jetson_nano
cd jetson_nano
# Download L4T Jetson Driver Package:
https://developer.nvidia.com/embedded/dlc/Jetson-210_Linux_R32.2.0-0
# Download L4T Sample Root File System:
https://developer.nvidia.com/embedded/dlc/Tegra_Linux_Sample-Root-Filesystem_Nano
# Download L4T Sources:
https://developer.nvidia.com/embedded/dlc/public_sources_Nano
# Download GCC Tool Chain for 64-bit BSP:
https://developer.nvidia.com/embedded/dlc/l4t-gcc-7-3-1-toolchain-64-bit
# Prepare files
sudo tar xpf Jetson-210_Linux_R32.2.0-0.tbz2
cd Linux_for_Tegra/rootfs/
sudo tar xpf ../../Tegra_Linux_Sample-Root-Filesystem_Nano.tbz2
cd ../../
tar -xvf l4t-gcc-7-3-1-toolchain-64-bit.tar.xz
tar -xjf public_sources_Nano.tbz2
tar -xjf public_sources/kernel_src.tbz2
# Apply PREEMPT-RT patches
cd kernel/kernel-4.9/
./scripts/rt-patch.sh apply-patches
# Build kernel
TEGRA_KERNEL_OUT=jetson_nano_kernel
mkdir $TEGRA_KERNEL_OUT
export CROSS_COMPILE=$HOME/jetson_nano/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-
make ARCH=arm64 O=$TEGRA_KERNEL_OUT tegra_defconfig
make ARCH=arm64 O=$TEGRA_KERNEL_OUT -j4
# Prepare files for creating image
sudo cp jetson_nano_kernel/arch/arm64/boot/Image $HOME/jetson_nano/Linux_for_Tegra/kernel/Image
sudo cp -r jetson_nano_kernel/arch/arm64/boot/dts/* $HOME/jetson_nano/Linux_for_Tegra/kernel/dtb/
sudo make ARCH=arm64 O=$TEGRA_KERNEL_OUT modules_install INSTALL_MOD_PATH=$HOME/jetson_nano/Linux_for_Tegra/rootfs/
cd $HOME/jetson_nano/Linux_for_Tegra/rootfs/
sudo tar --owner root --group root -cjf kernel_supplements.tbz2 lib/modules
sudo mv kernel_supplements.tbz2 ../kernel/
# Create Jetson Nano image
cd ..
sudo ./apply_binaries.sh
sudo ./create-jetson-nano-sd-card-image.sh -o jetson_nano.img -s 12G -r 100
After that, I flashed the resulting image into my micro SD card using Etcher. However, when I tried it in my Jetson Nano it only shows the Nvidia logo, then black screen then Nvidia logo again and so on, in a bootloop.
