Where, I successfully created the app with yolo algorithm to detect persons, now, i am looking to create the secondary model sgie to predict the gender of that person.
The main challenge is in the pipeline, how to do the preprocessing of the objects detected from the pgie and then feed to sgie as input.
I am using a prob function to get the object bbox details of the pgie, but how to link the preprocessing instruction in the pipeline which is required for the sgie. Is the preprocessing instruction has to be linked like a prob function before sgie?
Another clarification, currently, i am using the prob to take the output of pgie, if i added sgie, then how to get that output along with the pgie outputs.
I need to know the hierarchy for this scenario, help me to understand this flow, thanks
Please refer to our source code sample sources\apps\sample_apps\deepstream-test2 first. This sample demonstrates how to first detect a vehicle, and then classify the type of the vehicle.
Pipeline:
source->nvstreammux->pgie->sgie->nvdsosd->sink
Please set the config files according to your sgie model.
I go through the test2 app, i understand the flow, but the sgie model needs little bit of custom preprocessing, I need to do that from the output prediction of pgie. for that, i need the flow how to achieve that.
How to link that preprocessing function, is there any components available to do?
Statement 1 - the pgie gives the coordinates of the objects for the input stream resolution
Statement 2 - the sgie needs the cropped object image with preprocessed using some instructions
these two statements are necessary,
is the deepstream, automatically cropped the image based on the pgie output and feeds as input to sgie, - is that the way it works? if so, how this is happening, what is the flow of it. In the apps, i seen, we are just link different components and it works fine, but where this flow of cropping the objects based on the pgie output is defined, I mean which parameter handling this input for the sgie, If known, i can check for adding prob to process that input.
And, how to create the labels.txt file if the models has multiple head, like one head for classification and other for regression value, how it will be handled in labels.txt file. And how to make the sgie config file for updating the other parameters, like num-detected-classes, etc
No. The pgie just sends the coordinates of the object, not crops the images. If you want to know the detailed process, please refer to the nvinfer diagram to read our open-source code sources\gst-plugins\gst-nvinfer\gstnvinfer.cpp.
This needs to be configured according to your own model.
For eg., from the model there we are getting three values, the first two values is the probability values for the classification task, and the last value is for regression task. If a model arch. is like this, then in what format the labels.txt should be?
