• Hardware Platform (Jetson / GPU) : GPU
• DeepStream Version : 6.2
• NVIDIA GPU Driver Version (valid for GPU only): 525.147.05
• Issue Type( questions, new requirements, bugs): questions, bug
• How to reproduce the issue?
I have person detection as pgie
i have actionrecognitionnet model provided by nvidia as sgie
i have a preprocess before sgie
self.pgie.link(self.queue2)
self.queue2.link(self.tracker)
self.tracker.link(self.queue3)
self.queue3.link(self.preprocess)
self.preprocess.link(self.queue4)
self.queue4.link(self.sgie1)
self.sgie1.link(self.queue5)
this is config file for pgie
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
labelfile-path=labels_yolov8.txt
model-engine-file=…/primary_yolov8.engine
input-dims=3;640;640;0
uff-input-blob-name=images
batch-size=16
process-mode=1
maintain-aspect-ratio=1
symmetric-padding=0
model-color-format=0
network-mode=0
num-detected-classes=80
cluster-mode=4
interval=5
gie-unique-id=1
output-blob-names=num_dets;bboxes;scores;labels
parse-bbox-func-name=NvDsInferParseCustomYoloV8
custom-lib-path=libnvdsinfer_custom_bbox_yoloV8_infer.so
network-type=0
detected-min-w=50
detected-min-h=50
detected-max-w=500
detected-max-h=500
this is config file for preprocess
[property]
enable=1
gpu-id=0
unique_id=3
process-on-frame=0
target-unique-ids=2
operate-on-gie-id=1
network-input-order=2
network-input-shape=1;3;32;224;224
network-color-format=0
tensor-data-type=0
tensor-name=input_rgb
processing-width=224
processing-height=224
scaling-pool-memory-type=0
scaling-pool-compute-hw=0
scaling-filter=0
tensor-buf-pool-size=8custom-lib-path=/opt/nvidia/deepstream/deepstream/lib/libnvds_custom_sequence_preprocess.so
custom-tensor-preparation-function=CustomSequenceTensorPreparation[user-configs]
channel-scale-factors=0.007843137;0.007843137;0.007843137
channel-mean-offsets=127.5;127.5;127.5
stride=1
subsample=0
this is config file for sgie
[property]
gpu-id=0
tlt-encoded-model=…/resnet18_3d_rgb_hmdb5_32.etlt
tlt-model-key=nvidia_tao
model-engine-file=…/resnet18_3d_rgb_hmdb5_32.etlt_b4_gpu0_fp16.engine
process-mode=2
labelfile-path=labels.txt
gie-unique-id=2
batch-size=1
input-tensor-from-meta=1
network-mode=2
network-type=1
output-tensor-meta=1
parse-classifier-func-name=NvDsInferParseCustomNVPlate
custom-lib-path=libnvdsinfer_custom_impl_action.so
num-detected-classes=5
- The pipeline runs without an error
- The person detector is working properly and I can get the results both in NvDsObjectMeta inside probe and bounding boxes are also properly displayed on the output rtsp
The problem is that my sgie is not producing any results. I have placed a cout inside NvDsInferParseCustom c++ code and that is not printing anything
