Description
I am trying to run the Action Recognition example with the Region of Interest (ROI) being the inference result from the Primary GIE (PGIE). In my example, I am receiving bounding boxes from the PeopleNet PGIE, which are intended to serve as the ROI for the Action Recognition application in DeepStream examples.
My simplified pipeline looks like this:
filesource > nvstreammux > nvinfer > nvtracker > nvdspreprocess > nvinfer > eglsink
Models:
- I have used the peoplenet model from Nvidia for PGIE (https://api.ngc.nvidia.com/v2/models/nvidia/tao/peoplenet/versions/deployable_quantized_v2.6.1/files)
- I have used default Action Recognition model from Nvidia for SGIE (https://api.ngc.nvidia.com/v2/models/nvidia/tao/actionrecognitionnet/versions/deployable_v1.0/files) with classes push, walk, run etc.
I have refered the example : Action Recognition on Dynamic ROIs fails with CUDA error
I followed the steps provided in the link above, but I am encountering a segmentation fault when running the pipeline.
Difference wrt above example is :
- The referred example was tried on deepstream 6.2, and the moderator indicated that the issue might have been fixed with 6.3. I am using deepstream 7.0
- Minor config file differences
The segmentation fault output on the terminal is below:
Decodebin child added: nvv4l2decoder0
In cb_newpad
[DEBUG: DS_3DAR] Infer done for frame 0, number of objects: 0
[tanmay:115 :0:137] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x18)
==== backtrace (tid: 137) ====
0 0x0000000000042520 __sigaction() ???:0
1 0x000000000001c4a2 NvTrackerProc::processBatch() ???:0
2 0x00000000000dc253 std::error_code::default_error_condition() ???:0
3 0x0000000000094ac3 pthread_condattr_setpshared() ???:0
4 0x0000000000125a04 clone() ???:0
The code and config file that I have used for setting this up is attached below.
Could you please guide me on any additional modifications or troubleshooting steps I should consider to make the Action Recognition run smoothly as a secondary GIE with dynamic boxes from PGIE?
Thank you in advance for your assistance.
Environment
TensorRT Version:8.5.2.2
GPU Type: NVIDIA GeForce RTX 3070 Ti 8GB VRAM
Nvidia Driver Version: 535
DeepStream Version: 7.0 (Docker)
Relevant Files
https://drive.google.com/file/d/1e1BTZFGB1qsOCcwjVWDWQOvvzzy4RYj2/view?usp=sharing
