Preprocessing steps for UNET using TensorRT
Continuing the discussion from Why we need image pre and post processing when deploying a tlt model by using TensorRT?:
I’ve trained a UNET using TAO-Toolkit and tested inference with with
“tao model unet inference …” and the results looked pretty good.
I then exported the onnx file and used my local TenorRT trtexec to convert it to an .engine file. When I now run this engine in C++ using the same images my results are not that good. I exported with FP32, so I am expecting very similar output from local TensorRT.
My preprocessing looks the following:
  1. Load image with opencv
  2. resize image to network size (cv::resize)
  3. convert colors from BGR to RGB (cv::cvtColor)
  4. Calculate mean and std deviation over image
  5. convert image to float and normalize: pixel_float = (float(pixel_uchar)/255.0 - mean) / stdDev
As a source for step 5 I used TensorRT example:
TensorRT/quickstart/common/util.cpp at release/8.6 · NVIDIA/TensorRT (github.com)
In some other files I found that TAO is using BGR color space and also transposes the image with [2.0, 0.0, 1.0]:
tao_deploy/nvidia_tao_deploy/cv/unet/dataloader.py at main · NVIDIA/tao_deploy (github.com)
But what do I need to do, to make my TensorRT results most similar to tao inference results?
TAO Info:
task_group: [‘model’, ‘dataset’, ‘deploy’]
format_version: 3.0
toolkit_version: 5.3.0
published_date: 03/14/2024
local:
TensorRT: 8.6.1.6
CUDA: 12.1 update 1
cuDNN 8.9.0
Thank you
Please take a look at topic Custom TAO unet model classifying only two classes on Deepstream! - #33 by Morganh.
Thank you, that solved the problem.
For anyone stepping by:
To reproduce TAO (5.3.0) inference results in TensorRT (8.6.1.6) C++ follow these preprocessing steps:
  1. BGR image (when using opencv cv::imread, you already have BGR)
  2. resize image to net size
  3. pixel_new = (float(pixel) - 127.5) / 127.5
Maybe a better documentation for
UNET - NVIDIA Docs
would be helpfull to list all the preprocessing steps. That would make deploying to C++ way easier.
