I don’t know what I did, I didn’t change anything between multiple reboots, but now suddenly prime-run works. Steam also works and automatically uses the dGPU.
However, now I have screen tearing issues. On every program, that I run via prime-run I get this problem. I’ve read about PRIME syncronization, but I’m not sure if it is what I’m looking for.
I did xrandr --output eDP --set "PRIME Synchronization" 1:
X Error of failed request: BadName (named color or font does not exist)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 11 (RRQueryOutputProperty)
Serial number of failed request: 55
Current serial number in output stream: 55
xrandr --prop:
Screen 0: minimum 320 x 200, current 2560 x 1600, maximum 16384 x 16384
eDP connected primary 2560x1600+0+0 (normal left inverted right x axis y axis) 345mm x 215mm
EDID:
00ffffffffffff000e6f001600000000
001e0104b522167803ee95a3544c9926
0f505400000001010101010101010101
0101010101016e6e00a0a04084603020
360059d710000018000000fd0c3ca51f
1f4e010a202020202020000000fe0043
534f542054330a2020202020000000fe
004d4e473030374441312d310a200103
02031d00e3058000e60605016a6a246d
1a000002033ca500046a246a24000000
00000000000000000000000000000000
000000000000000000000000000000ff
GAMMA_LUT_SIZE: 4096
range: (0, -1)
DEGAMMA_LUT_SIZE: 4096
range: (0, -1)
GAMMA_LUT: 0
range: (0, 65535)
CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
0 1
DEGAMMA_LUT: 0
range: (0, 65535)
TearFree: auto
supported: off, on, auto
HDCP Content Type: HDCP Type0
supported: HDCP Type0, HDCP Type1
Content Protection: Undesired
supported: Undesired, Desired, Enabled
vrr_capable: 1
range: (0, 1)
abm level: 0
range: (0, 4)
max bpc: 16
range: (8, 16)
underscan vborder: 0
range: (0, 128)
underscan hborder: 0
range: (0, 128)
underscan: off
scaling mode: None
supported: None, Full, Center, Full aspect
link-status: Good
supported: Good, Bad
CONNECTOR_ID: 78
supported: 78
non-desktop: 0
range: (0, 1)
2560x1600 60.01*+
1920x1200 60.01
1920x1080 60.01
1600x1200 60.01
1680x1050 60.01
1280x1024 60.01
1440x900 60.01
1280x800 60.01
1280x720 60.01
1024x768 60.01
800x600 60.01
640x480 60.01
DP-1-0 disconnected (normal left inverted right x axis y axis)
PRIME Synchronization: 1
supported: 0, 1
0 1
CscMatrix: 65536 0 0 0 0 65536 0 0 0 0 65536 0
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: DisplayPort
supported: DisplayPort
ConnectorType: DisplayPort
ConnectorNumber: 1
_ConnectorLocation: 1
non-desktop: 0
supported: 0, 1
DP-1-1 disconnected (normal left inverted right x axis y axis)
supported: 0, 1
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorNumber: 1
non-desktop: 0
supported: 0, 1
DP-1-2 disconnected (normal left inverted right x axis y axis)
supported: 0, 1
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
ConnectorNumber: 2
_ConnectorLocation: 2
non-desktop: 0
supported: 0, 1
DP-1-3 disconnected (normal left inverted right x axis y axis)
supported: 0, 1
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorNumber: 2
non-desktop: 0
supported: 0, 1
HDMI-1-0 disconnected (normal left inverted right x axis y axis)
supported: 0, 1
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorType: HDMI
ConnectorNumber: 3
_ConnectorLocation: 3
non-desktop: 0
supported: 0, 1
DP-1-4 disconnected (normal left inverted right x axis y axis)
supported: 0, 1
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
ConnectorType: Panel
ConnectorNumber: 0
_ConnectorLocation: 0
non-desktop: 0
supported: 0, 1
Here’s my nvidia-bug-report.sh: PrivateBin
Edit: I have an 165 hz laptop screen, but in kde it sais that 60 hz is the only supported. I don’t want to solve this problem in this thread, but I don’t know, maybe it has something to do with the problem.
