Looks like there is a typo in the PGI configuration file “cpprc” located in your installation’s bin directory.
switch --use_pch$dir is
help(Use precompiled headers from directory)
helpgroup(language)
append(CPP1ARGS=--use_dir $dir); <-- should be --use_pch not --use_dir
I have created a technical problem report (TPR#4010) and we should be able get this corrected in the next release. Please feel free to update your local copy of cpprc with this correction. Thank you for pointing this out!
pgCC 7.0-2 32-bit target on x86 Linux
Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved.
Copyright 2000-2007, STMicroelectronics, Inc. All Rights Reserved.
luoyi@skyking:~/icc$ pgCC -flags |grep pch
Reading rcfile /home/luoyi/pgi/linux86/7.0-2/bin/.pgcpprc
–pch Do automatic precompiled header processing
–pch_dir Set precompiled header directory
–pch_mem Specify memory to be used for PCH processing
–[no_]pch_messages Enable PCH messages
–use_pch Use precompiled headers from directory
-M[no]depchk Check dependence relations for vector or parallel code
Nothing has changed in regards to this help message between 6.x and 7.0.
%pgCC -V
pgCC 6.1-5 64-bit target on x86-64 Linux
Copyright 2000-2006, STMicroelectronics, Inc. All Rights Reserved.
% pgCC -help --create_pch
Reading rcfile /usr/pgi/linux86-64/6.1-5/bin/.pgCCrc
–create_pch Create precompiled header file in directory
% pgCC -flags | grep pch
% pgCC -V
pgCC 7.0-2 64-bit target on x86-64 Linux
Reading rcfile /usr/pgi/linux86-64/7.0-2/bin/.pgcpprc
