I am having problems compiling and installing netCDF using pgi version 10.2.
I have been following the build directions in http://www.pgroup.com/resources/netcdf/netcdf360_pgi60.htm
(These directions worked fine for me when previously building netCDF with PGI version 5.2.)
Now when I try to follow them with the version 10.2 compiler, I encounter the following make error (only the last lines of make log):
pgcc 10.2-1 64-bit target on x86-64 Linux -tp nehalem-64
Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved.
Copyright 2000-2010, STMicroelectronics, Inc. All Rights Reserved.
make[4]: Leaving directory /tmp/netcdf3/working/netcdf-4.0.1/ncdump' make[3]: Leaving directory
/tmp/netcdf3/working/netcdf-4.0.1/ncdump’
make[2]: Leaving directory /tmp/netcdf3/working/netcdf-4.0.1/ncdump' Making all in nf_test make[2]: Entering directory
/tmp/netcdf3/working/netcdf-4.0.1/nf_test’
make[2]: Nothing to be done for all'. make[2]: Leaving directory
Making all in cxx
make[2]: Entering directory /tmp/netcdf3/working/netcdf-4.0.1/cxx' source='netcdf.cpp' object='netcdf.lo' libtool=yes \ DEPDIR=.deps depmode=none /bin/sh ../depcomp \ /bin/sh ../libtool --tag=CXX --mode=compile /opt/pgi/linux86-64/10.2/bin/pgCC -DHAVE_CONFIG_H -I. -I.. -I../fortran -I../libsrc -DNDEBUG -DpgiFortran -g -c -o netcdf.lo netcdf.cpp libtool: compile: /opt/pgi/linux86-64/10.2/bin/pgCC -DHAVE_CONFIG_H -I. -I.. -I../fortran -I../libsrc -DNDEBUG -DpgiFortran -g -c netcdf.cpp -o netcdf.o source='ncvalues.cpp' object='ncvalues.lo' libtool=yes \ DEPDIR=.deps depmode=none /bin/sh ../depcomp \ /bin/sh ../libtool --tag=CXX --mode=compile /opt/pgi/linux86-64/10.2/bin/pgCC -DHAVE_CONFIG_H -I. -I.. -I../fortran -I../libsrc -DNDEBUG -DpgiFortran -g -c -o ncvalues.lo ncvalues.cpp libtool: compile: /opt/pgi/linux86-64/10.2/bin/pgCC -DHAVE_CONFIG_H -I. -I.. -I../fortran -I../libsrc -DNDEBUG -DpgiFortran -g -c ncvalues.cpp -o ncvalues.o /bin/sh ../libtool --tag=CXX --mode=link /opt/pgi/linux86-64/10.2/bin/pgCC -g -version-info 4:0:0 -o libnetcdf_c++.la -rpath /tmp/netcdf3/final/lib netcdf.lo ncvalues.lo ../libsrc/libnetcdf.la libtool: link: tpldir=Template.dir libtool: link: rm -rf Template.dir libtool: link: /opt/pgi/linux86-64/10.2/bin/pgCC --prelink_objects --instantiation_dir Template.dir netcdf.o ncvalues.o pgCC-Error-Unknown switch: --instantiation_dir make[2]: *** [libnetcdf_c++.la] Error 1 make[2]: Leaving directory
/tmp/netcdf3/working/netcdf-4.0.1/cxx’
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/tmp/netcdf3/working/netcdf-4.0.1’
make: *** [all] Error 2
After searching online about “pgCC-Error-Unknown switch: --instantiation_dir”, I see that it may be related to a libtool problem for versions 10.x. I tried applying changes from the two patches to libtool.m4 referenced in the following response to an openmpi question:
http://www.pgroup.com/userforum/viewtopic.php?p=6244&sid=3b40192af234822fa5d23451ea2996b8
(specifically, to add a dot to lower version numbers and adding “pgfortran*”).
However, I STILL get the same make error. What could the problem be???
