problem compiling RIP4
I try to compile the RIP4 package ( the WRF Model GRAPHIC TOOLS) usiing pgf90 v.6.0 on suse 9.0. I was able to successfully produce the executales for all the tools exept ‘rip’.
The compiler print out a lot of unresolved symboi cannot determine to which library they could belong. I look after all the libraries that comes with the PGI compiler without success.
Some of the symbols are:
pghpf_sect1v
e_wsfe
e_wsfe
do_lio
Any help apreciated.
Follow a partial loutput from compilation:
pgf90 -o rip addorfill.o adjellip.o angle.o barb.o bes.o bogs.o brnshr.o bshear.o bvfricalc.o capecalc3d.o ceilingcalc.o colram.o colrln.o condheat.o cpchhl.o cpchll.o cpcolr.o cpmpxy.o createdtg.o cttcalc.o dbzcalc.o ddpcalc.o ddx.o ddy.o derivc.o drawcl.o driver.o eqthecalc.o extingcalc.o fields.o fillarray.o finterp.o finterp2d.o fregcalc.o frtitle.o fy.o fx.o getbasicvars.o getchar.o getconvals.o getdash.o getdims.o getheadinfo.o getinum.o getminfo.o getpt.o getrnum.o gettimes.o getvar.o getvarinfo.o hboxdraw.o hbulldraw.o hchadraw.o hcondraw.o hiresmap.o hlinedraw.o hmapdraw.o hodograph.o hsidsdraw.o hstrdraw.o hticdraw.o htrajdraw.o hvecdraw.o igetcoind.o lennonblank.o liftparcel.o locinterp.o maptform.o maptick.o mconvert.o mktrjpts.o mlen.o monotonic.o netasc.o numeric.o omgcalc.o pfcalc.o pltitle.o prcver.o precprob.o premaptform.o profil.o pvocalc.o qgomg.o rdcolt.o readspec.o relhl.o rhucalc.o rip.o rotipslab.o rotpslab.o sateqthecalc.o saweli.o scondraw.o setripheader.o smooth.o smoothcp.o smoothcz.o srflow.o srflow2.o sstats.o sticdraw.o sticdraw_polar.o svecdraw.o tdpcalc.o tfpcalc.o thecalc.o tonpsadiabat.o tserprep.o turb.o unblank.o vbardraw.o vc2dcalc.o vcondraw.o velbrb.o velvctmts.o vgp.o vinterp.o virtual.o virtualhyd.o viscalc.o vticdraw.o vtrajdraw.o vvecdraw.o vwinddraw.o wdircalc.o wetbulbcalc.o writefile.o wspcalc.o xmapcalc.o xtodot.o binio.o v5d.o -L/usr/local/ncarg/lib -lncarg -lcgm -lncarg_gks -lncarg_c -L/usr/X11R6/lib -lX11 -L/usr/lib -lm -L/usr/pgi/linux86/6.0/lib -lpgf90
/usr/local/ncarg/lib/libncarg_gks.a(gesc.o)(.text+0x1694): In function gesc_': : undefined reference to pghpf_sect1v’
/usr/local/ncarg/lib/libncarg_gks.a(gesc.o)(.text+0x1753): In function gesc_': : undefined reference to pghpf_sect1v’
/usr/local/ncarg/lib/libncarg_gks.a(gesc.o)(.text+0x180b): In function gesc_': : undefined reference to pghpf_sect1v’
/usr/local/ncarg/lib/libncarg_gks.a(gesc.o)(.text+0x18db): In function gesc_': : undefined reference to pghpf_sect1v’
/usr/local/ncarg/lib/libncarg_gks.a(gesc.o)(.text+0x199a): In function gesc_': : undefined reference to pghpf_sect1v’
/usr/local/ncarg/lib/libncarg_gks.a(gesc.o)(.text+0x1a5c): more undefined references to pghpf_sect1v' follow /usr/local/ncarg/lib/libncarg_c.a(i1mach.o)(.text+0x3ce): In function i1mach_‘:
: undefined reference to s_wsfe' /usr/local/ncarg/lib/libncarg_c.a(i1mach.o)(.text+0x3d3): In function i1mach_’:
: undefined reference to e_wsfe' /usr/local/ncarg/lib/libncarg_c.a(i1mach.o)(.text+0x519): In function i1mach_‘:
: undefined reference to s_wsle' /usr/local/ncarg/lib/libncarg_c.a(i1mach.o)(.text+0x52f): In function i1mach_’:
: undefined reference to do_lio' /usr/local/ncarg/lib/libncarg_c.a(i1mach.o)(.text+0x546): In function i1mach_‘:
: undefined reference to do_lio' /usr/local/ncarg/lib/libncarg_c.a(i1mach.o)(.text+0x55c): In function i1mach_’:
: undefined reference to do_lio' /usr/local/ncarg/lib/libncarg_c.a(i1mach.o)(.text+0x564): In function i1mach_':
Hi Ace,
These symbols (except the ‘pghpf_sectv1’) are located in the g2c library. Adding “-g77libs” to the link line should bring in the correct g77 libraries (assuming you have g77 installed).
The ‘pghpf_sectv1’ symbol is a internal compiler generated symbol added with the 5.2 release of the compilers. Typically you get this if your using an older compiler (5.1 or earlier) with libraries built with 5.2 or later. Can you please post the command line passed to the linker? To get this add ‘-v’ to your link line and look for the command starting with ‘/usr/bin/ld’. To save space, please omitt the objects. Also, please post the output of the command ‘which pgf90’.
Thanks,
Mat
Hi!
Ok, I recompile the package adding the the g2c library and the only unresolved symbol now is ‘pghpf_sectv1’.
As I wrote, I’m using the last version of the compiler, 6.0…anyway I post what you ask.
Thank a lot!
Command passed to the linker:
/usr/bin/ld /usr/lib/crt1.o /usr/lib/crti.o /usr/lib/gcc-lib/i586-suse-linux/3.3.3/crtbegin.o /usr/pgi/linux86/6.0/lib/f90main.o -m elf_i386 -dynamic-linker /lib/ld-linux.so.2 addorfill.o adjellip.o angle.o barb.o bes.o bogs.o … v5d.o -o rip -L/usr/local/ncarg/lib -L/usr/X11R6/lib -L/usr/lib -L/usr/pgi/linux86/6.0/lib -L/usr/lib -L/usr/lib/gcc-lib/i586-suse-linux/3.3.3 -L/usr/lib/gcc-lib/i586-suse-linux/3.3.3 -rpath /usr/pgi/linux86/6.0/lib -lncarg -lcgm -lncarg_gks -lncarg_c -lX11 -lm -lpgf90 -lpgf90_rpm1 -lpgf902 -lpgf90rtl -lpgftnrtl -lg2c -lc -lnspgc -lpgc -lm -lgcc -lc -lgcc /usr/lib/gcc-lib/i586-suse-linux/3.3.3/crtend.o /usr/lib/crtn.o
‘which pgf90’ output:
/usr/pgi/linux86/6.0/bin/pgf90
Hi Ace,
I think rebuilding the ncarg libraries with the 6.0 compiler should take care of the problem. I just built ncarg with 6.0 and RIP4 was able to link correctly.
Thanks,
Mat
