I have a Ublox ZED-F9P and Jetson, I enabled the PPS+NMEA in Jetson and input NMEA and PPS in the Jetson, however, I also used Chrony and GPSD as the deamon to synchronize my system time to PPS.
However, I noticed that the difference between PPS and my system time was jumped like:
Timestamp: 1720271466.0081768, PPS-Clock Difference: 0.006760120391845703
Timestamp: 1720271466.9999745, PPS-Clock Difference: 0.006780862808227539
Timestamp: 1720271468.0073886, PPS-Clock Difference: 0.006812334060668945
Timestamp: 1720271469.0007286, PPS-Clock Difference: 0.006842851638793945
Timestamp: 1720271470.0055888, PPS-Clock Difference: 0.00687408447265625
Timestamp: 1720271471.0012033, PPS-Clock Difference: 0.006923198699951172
Timestamp: 1720271472.9935737, PPS-Clock Difference: 1.0069923400878906
Timestamp: 1720271473.988717, PPS-Clock Difference: 1.0070548057556152
Timestamp: 1720271474.9976366, PPS-Clock Difference: 0.007140159606933594
Timestamp: 1720271476.9939167, PPS-Clock Difference: 1.0071022510528564
Timestamp: 1720271478.0124972, PPS-Clock Difference: 0.007025957107543945
Timestamp: 1720271478.9996452, PPS-Clock Difference: 0.006987571716308594
Timestamp: 1720271480.0062253, PPS-Clock Difference: 0.006937742233276367
Timestamp: 1720271481.0000224, PPS-Clock Difference: 0.0068895816802978516
Timestamp: 1720271482.9898431, PPS-Clock Difference: 1.0068442821502686
Timestamp: 1720271484.9938395, PPS-Clock Difference: 1.0068144798278809
Timestamp: 1720271486.0035696, PPS-Clock Difference: 0.006811618804931641
Timestamp: 1720271487.0000994, PPS-Clock Difference: 0.0068056583404541016
Timestamp: 1720271488.0096858, PPS-Clock Difference: 0.006804704666137695
Timestamp: 1720271489.0003412, PPS-Clock Difference: 0.006803274154663086
Timestamp: 1720271490.0116658, PPS-Clock Difference: 0.0068051815032958984
Timestamp: 1720271491.9939423, PPS-Clock Difference: 1.006800889968872
Timestamp: 1720271493.00087, PPS-Clock Difference: 0.006792783737182617
Timestamp: 1720271494.003225, PPS-Clock Difference: 0.006788492202758789
Timestamp: 1720271495.000403, PPS-Clock Difference: 0.006785392761230469
Timestamp: 1720271496.0079112, PPS-Clock Difference: 0.006781578063964844
Timestamp: 1720271497.000441, PPS-Clock Difference: 0.00677800178527832
Timestamp: 1720271498.0118775, PPS-Clock Difference: 0.006777524948120117
Timestamp: 1720271499.0002327, PPS-Clock Difference: 0.0067827701568603516
Timestamp: 1720271500.9894478, PPS-Clock Difference: 1.0067920684814453
Timestamp: 1720271502.0108378, PPS-Clock Difference: 0.0068264007568359375
Timestamp: 1720271503.0003114, PPS-Clock Difference: 0.006857156753540039
Timestamp: 1720271504.0072558, PPS-Clock Difference: 0.0069065093994140625
Timestamp: 1720271504.9999986, PPS-Clock Difference: 0.0069580078125
Timestamp: 1720271506.0063345, PPS-Clock Difference: 0.007006168365478516
Timestamp: 1720271506.9998312, PPS-Clock Difference: 0.00704503059387207
Timestamp: 1720271508.0159929, PPS-Clock Difference: 0.007086038589477539
Timestamp: 1720271509.9935262, PPS-Clock Difference: 1.0071132183074951
Timestamp: 1720271510.9986787, PPS-Clock Difference: 0.007178306579589844
Timestamp: 1720271512.0048263, PPS-Clock Difference: 0.00717926025390625
Timestamp: 1720271512.9992213, PPS-Clock Difference: 0.007177114486694336
Timestamp: 1720271514.0095427, PPS-Clock Difference: 0.007177829742431641
Timestamp: 1720271514.9997566, PPS-Clock Difference: 0.00717616081237793
Timestamp: 1720271516.0063536, PPS-Clock Difference: 0.007174015045166016
Timestamp: 1720271516.9995775, PPS-Clock Difference: 0.007170915603637695
Timestamp: 1720271518.0069094, PPS-Clock Difference: 0.007170677185058594
Timestamp: 1720271519.001263, PPS-Clock Difference: 0.007177114486694336
Timestamp: 1720271520.015941, PPS-Clock Difference: 0.007191181182861328
Timestamp: 1720271521.0009513, PPS-Clock Difference: 0.007202863693237305
Timestamp: 1720271522.0097504, PPS-Clock Difference: 0.0072174072265625
Timestamp: 1720271523.000543, PPS-Clock Difference: 0.007246494293212891
Timestamp: 1720271524.0086722, PPS-Clock Difference: 0.0072917938232421875 Some times the difference was just: 0.007246494293212891s but sometimes was: 1.0071022510528564s. I will appreciate if you can give me some ideas. Thx
