Howdy,
I’m trying to use NVRTC to generate Ptx files. I’m using the basic code from the Optix7 SDK samples
The call to nvrtcCompileProgram() results in this error
C:/ProgramData/NVIDIA Corporation/OptiX SDK 7.0.0/include/optix_7_device.h(36): catastrophic error: #error directive: Device code for OptiX requires at least C++11. Consider adding “–std c++11” to the nvcc command-line.
If I add the language option like thie
// NVRTC compiler options
#define CUDA_NVRTC_OPTIONS
“-arch”,
“compute_30”,
“-use_fast_math”,
“-lineinfo”,
“-default-device”,
“-rdc”,
“true”,
“-std”,
“c++11”,
“-D__x86_64”,
I get this error
NVRTC Compilation failed.
nvrtc: error: unrecognized option -std found
Anybody know what I’m doing wrong?
