Problem Starting GStreamer on Jetson Nano after Suspend
Hardware:
  • NVIDIA Jetson Nano Developer Kit with JetPack 4.6.1 on MicroSD Card
  • Raspberry Pi Camera v2
I am attempting to write a Python program that achieves the following:
  1. Perform live object detection using YOLOv7
  2. When a car or truck is detected with 80% confidence, suspend the Jetson Nano with sudo systemctl suspend
  3. Manually wake up the Jetson by grounding the PWR BTN pin
  4. Continue object detection from step 1
I am currently getting errors with the GStreamer Pipeline after I wake up the Jetson Nano from sleep mode, and the program continues. Below is a snippet of what I have so far. The program runs on the run() program inside the inferThread class which calls the infer function inside the YoLov7TRT class.
class YoLov7TRT(object):
    def infer(self, image, cap):
        if obj in ['car','truck'] and score >= 0.8:
                cap.release() # release the cv2.VideoCapture
                process = subprocess.Popen(['sudo', 'systemctl', 'suspend'])
                process.wait()
                newCap = True
        return image_raw, end - start, num_of_objects, newCap
def gstreamer_pipeline(
        camera_id,
        capture_width=1280,
        capture_height=720,
        display_width=512,
        display_height=288,
        framerate=60,
        flip_method=0,
    return (
            "nvarguscamerasrc sensor-id=%d ! "
            "video/x-raw(memory:NVMM), "
            "width=(int)%d, height=(int)%d, "
            "format=(string)NV12, framerate=(fraction)%d/1 ! "
            "nvvidconv flip-method=%d ! "
            "video/x-raw, width=(int)%d, height=(int)%d, format=I420 ! "
            "videoconvert ! "
            "video/x-raw, format=(string)BGR ! appsink max-buffers=1 drop=true"
                    camera_id,
                    capture_width,
                    capture_height,
                    framerate,
                    flip_method,
                    display_width,
                    display_height,
class inferThread(threading.Thread):
    def __init__(self, yolov7_wrapper):
        threading.Thread.__init__(self)
        self.yolov7_wrapper = yolov7_wrapper
        self.cap = cv2.VideoCapture(gstreamer_pipeline(camera_id=0, flip_method=2), cv2.CAP_GSTREAMER)
        # Check if the video file was successfully loaded
        if not self.cap.isOpened():
            print("Error opening video file")
    def run(self):
        while True:
            status, frame = self.cap.read()
            if status:
                img = cv2.resize(frame, (512, 288))
                result, use_time, number_of_objects, newCap = self.yolov7_wrapper.infer(img, self.cap)
                if newCap: # need to initialize a new VideoCapture after waking from suspend
                        print("Error starting video capture")
                    # Here the program goes back to the 'while True' statement
                else:
I am getting errors along the following lines after the suspend command is called and the run() function continues:
# cap.release()
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
# sudo systemctl suspend
[sudo] password for user:
# After Jetson Nano is woken up from suspend
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
[ WARN:1] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (933) open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
CONSUMER: ERROR OCCURRED
[ WARN:1] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (488) isPipelinePlaying OpenCV | GStreamer warning: unable to query pipeline state
[ WARN:1] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (1757) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module nvarguscamerasrc1 reported: TIMEOUT
What is going wrong here? Are there alternatives or changes I can make to make this possible?
An alternative I thought of would be to stream the video feed from a separate program and subscribe to that stream inside of the Python program above, but I do not know how to do so.
Any help is greatly appreciated.
Please terminate the application before entering suspend mode. And re-start it after resuming the system. It is not supported to enter suspend/resume in runtime while the gstreamer pipeline is running.
What alternatives to gstreamer are there, since it is not supported to enter suspend/resume in runtime while the gstreamer pipeline is running?
The system I am writing this program for requires that an object detection algorithm run almost immediately after the Jetson wakes up from suspend due to power constraints. I am unable to terminate the application before entering suspend because the first thing the application does is load a YOLOv7 object detection model. The loading of this model takes ~7 seconds which is too long for the specifications I am trying to meet.
Maybe it is possible to have two separate programs, one for running the YOLOv7 model and one for running the gstreamer pipeline that sends video frames to the object detection program? This would make it so that I can terminate the gstreamer pipeline program before entering suspend and start it after without having to load the YOLOv7 model again. What are your thoughts on this?
The use-case of entering suspend/resume is not validated in SQA coverage, so it may not work properly. If there’s performance concern for terminating and re-initializing the application, we would suggest keep the application alive without entering suspend/resume.
