Problem to build a docker container and use the GPU on JETSON AGX ORIGIN
When i launch the command:
 sudo docker run -it --runtime nvidia --network host nvcr.io/nvidia/l4t-pytorch:r34.1.1-pth1.11-py3
Appear the following error:
docker: Error response from daemon: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: src: /etc/vulkan/icd.d/nvidia_icd.json, src_lnk: /usr/lib/aarch64-linux-gnu/tegra/nvidia_icd.json, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/etc/vulkan/icd.d/nvidia_icd.json, dst_lnk: /usr/lib/aarch64-linux-gnu/tegra/nvidia_icd.json
src: /usr/lib/aarch64-linux-gnu/libcuda.so, src_lnk: tegra/libcuda.so, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/libcuda.so, dst_lnk: tegra/libcuda.so
src: /usr/lib/aarch64-linux-gnu/libnvcucompat.so, src_lnk: tegra/libnvcucompat.so, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/libnvcucompat.so, dst_lnk: tegra/libnvcucompat.so
src: /usr/lib/aarch64-linux-gnu/libnvidia-nvvm.so, src_lnk: tegra/libnvidia-nvvm.so, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/libnvidia-nvvm.so, dst_lnk: tegra/libnvidia-nvvm.so
src: /usr/lib/aarch64-linux-gnu/libv4l2.so.0.0.999999, src_lnk: tegra/libnvv4l2.so, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/libv4l2.so.0.0.999999, dst_lnk: tegra/libnvv4l2.so
src: /usr/lib/aarch64-linux-gnu/libv4lconvert.so.0.0.999999, src_lnk: tegra/libnvv4lconvert.so, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/libv4lconvert.so.0.0.999999, dst_lnk: tegra/libnvv4lconvert.so
src: /usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvargus.so, src_lnk: ../../../tegra/libv4l2_nvargus.so, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvargus.so, dst_lnk: ../../../tegra/libv4l2_nvargus.so
src: /usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvcuvidvideocodec.so, src_lnk: ../../../tegra/libv4l2_nvcuvidvideocodec.so, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvcuvidvideocodec.so, dst_lnk: ../../../tegra/libv4l2_nvcuvidvideocodec.so
src: /usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvvideocodec.so, src_lnk: ../../../tegra/libv4l2_nvvideocodec.so, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvvideocodec.so, dst_lnk: ../../../tegra/libv4l2_nvvideocodec.so
src: /usr/lib/aarch64-linux-gnu/libvulkan.so.1.3.203, src_lnk: tegra/libvulkan.so.1.3.203, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/libvulkan.so.1.3.203, dst_lnk: tegra/libvulkan.so.1.3.203
src: /usr/lib/aarch64-linux-gnu/tegra/libcuda.so, src_lnk: libcuda.so.1.1, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/tegra/libcuda.so, dst_lnk: libcuda.so.1.1
src: /usr/lib/aarch64-linux-gnu/tegra/libgstnvdsseimeta.so, src_lnk: libgstnvdsseimeta.so.1.0.0, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/tegra/libgstnvdsseimeta.so, dst_lnk: libgstnvdsseimeta.so.1.0.0
src: /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurface.so, src_lnk: libnvbufsurface.so.1.0.0, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/tegra/libnvbufsurface.so, dst_lnk: libnvbufsurface.so.1.0.0
src: /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so, src_lnk: libnvbufsurftransform.so.1.0.0, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so, dst_lnk: libnvbufsurftransform.so.1.0.0
src: /usr/lib/aarch64-linux-gnu/tegra/libnvbuf_utils.so, src_lnk: libnvbuf_utils.so.1.0.0, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/tegra/libnvbuf_utils.so, dst_lnk: libnvbuf_utils.so.1.0.0
src: /usr/lib/aarch64-linux-gnu/tegra/libnvdsbufferpool.so, src_lnk: libnvdsbufferpool.so.1.0.0, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/tegra/libnvdsbufferpool.so, dst_lnk: libnvdsbufferpool.so.1.0.0
src: /usr/lib/aarch64-linux-gnu/tegra/libnvidia-nvvm.so, src_lnk: libnvidia-nvvm.so.4, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/tegra/libnvidia-nvvm.so, dst_lnk: libnvidia-nvvm.so.4
src: /usr/lib/aarch64-linux-gnu/tegra/libnvidia-nvvm.so.4, src_lnk: libnvidia-nvvm.so.4.0.0, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/tegra/libnvidia-nvvm.so.4, dst_lnk: libnvidia-nvvm.so.4.0.0
src: /usr/lib/aarch64-linux-gnu/tegra/libnvid_mapper.so, src_lnk: libnvid_mapper.so.1.0.0, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/tegra/libnvid_mapper.so, dst_lnk: libnvid_mapper.so.1.0.0
src: /usr/lib/aarch64-linux-gnu/tegra/libnvscibuf.so, src_lnk: libnvscibuf.so.1, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/tegra/libnvscibuf.so, dst_lnk: libnvscibuf.so.1
src: /usr/lib/aarch64-linux-gnu/tegra/libnvscicommon.so, src_lnk: libnvscicommon.so.1, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/tegra/libnvscicommon.so, dst_lnk: libnvscicommon.so.1
src: /usr/lib/aarch64-linux-gnu/tegra/libnvscistream.so, src_lnk: libnvscistream.so.1, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/tegra/libnvscistream.so, dst_lnk: libnvscistream.so.1
src: /usr/lib/aarch64-linux-gnu/tegra/libnvscisync.so, src_lnk: libnvscisync.so.1, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/lib/aarch64-linux-gnu/tegra/libnvscisync.so, dst_lnk: libnvscisync.so.1
src: /usr/share/glvnd/egl_vendor.d/10_nvidia.json, src_lnk: ../../../lib/aarch64-linux-gnu/tegra-egl/nvidia.json, dst: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/share/glvnd/egl_vendor.d/10_nvidia.json, dst_lnk: ../../../lib/aarch64-linux-gnu/tegra-egl/nvidia.json
, stderr: nvidia-container-cli: mount error: stat failed: /var/lib/docker/overlay2/8190cabf21d73bbfb7ca56dacd037479fa105fb88515b9c8c128d53b69844a8a/merged/usr/local/cuda-11.4/compat/libcuda.so.1: no such file or directory: unknown.
ERRO[0000] error waiting for container: context canceled
I am trying to build a docker container in a Jetson AGX Origin, but I could not do it, I think that I am having problems with the CUDA version installed on the Jetson.
When I do nvcc --version appear CUDA 11.4, but when I do jetson_release -v appear CUDA 12.1.
I do not know if I could change the CUDA version in the jetson_release, or any idea of what is the problem?.
Other information of the installation:
JetPack version: 5.0.1DP
L4T: 34.1.1
cuDNN: 8.3.2.49
TensorRT: 5.0.1
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
r34 (JetPack 5.0.1 DP) is a DP release.
Would you mind upgrading your environment into a GA release (ex. 5.0.2 or the latest 5.1.2?) and trying it again?
