I am using Jetson AGX Orin and build a container with Ubuntu22.04 and CUDA toolkit 12.5.
I choose a base image with CUDA 12.2 and update its version manually in the dockerfile.
Below is my Dockerfile.
But it keep saying “CUDA driver version is insufficient for CUDA runtime version”, the same code base can be ran in x86 with CUDA toolkit 12.5.
Any solution for this?
Copyright (c) 2005-2024 NVIDIA Corporation
Built on Wed_Apr_17_19:34:47_PDT_2024
Cuda compilation tools, release 12.5, V12.5.40
Build cuda_12.5.r12.5/compiler.34177558_0
FROM nvcr.io/nvidia/l4t-cuda:12.2.12-runtime
# Install nvidia-l4t-core
RUN \
echo "deb https://repo.download.nvidia.com/jetson/common r32.4 main" >> /etc/apt/sources.list && \
echo "deb https://repo.download.nvidia.com/jetson/t194 r32.4 main" >> /etc/apt/sources.list && \
apt-key adv --fetch-key http://repo.download.nvidia.com/jetson/jetson-ota-public.asc && \
mkdir -p /opt/nvidia/l4t-packages/ && \
touch /opt/nvidia/l4t-packages/.nv-l4t-disable-boot-fw-update-in-preinstall
RUN apt-get update \
&& echo "Y" | apt-get install -y --no-install-recommends nvidia-l4t-core
ENV UDEV=1
RUN wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2204/arm64/cuda-keyring_1.1-1_all.deb \
&& dpkg -i cuda-keyring_1.1-1_all.deb \
&& apt-get update \
&& apt-get -y install cuda-toolkit-12-5
# Install necessary dependencies including gcc
&& apt-get install -y wget build-essential git cmake libzmq3-dev pkg-config curl vim python3 python3-pip docker-compose ninja-build \
&& rm -rf /var/lib/apt/lists/*
WORKDIR /
UPDATE:
docker run --gpus all -it jetsondev bash
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: , stderr: Auto-detected mode as ‘csv’
invoking the NVIDIA Container Runtime Hook directly (e.g. specifying the docker --gpus flag) is not supported. Please use the NVIDIA Container Runtime (e.g. specify the --runtime=nvidia flag) instead.: unknown.
