So In my company where we program computing programs for structural mechanics, we decided to try using cuda for GPU computing and I was given the mission to test it and try to use it with a Fortran program we already developed.
I understood how to use Cuda in C along with the library cublast. Now I want to test launching a cuda calculus from fortran. So I have the following fortran main program (fortranF.f90)
program fortran
use appelc
implicit none
integer itaille
real, allocatable :: matr1(:), matr2(:), matr3(:)
allocate(matr1(itaille*itaille),matr2(itaille*itaille),matr3(itaille*itaille))
matr3 = 0
matr1 = 2
matr2 = 3
call monde
call mulmat(matr1,matr2,matr3,itaille)
PAUSE 1
end program fortran
With the corresponding module (moduleC.f90):
module appelc
interface
subroutine mulmat(A,B,C,N) bind(C,NAME='matcal')
use,intrinsic :: ISO_C_BINDING ! Declares C kinds
real(c_float),intent(in) :: A(*)
real(c_float),intent(in) :: B(*)
real(c_float),intent(out) :: C(*)
integer(c_int),intent(in) :: N
end subroutine mulmat
end interface
end module appelc
I also have a C++ project compiled as a static library, with only one file (LibC++.cpp):
#include "simpleCUBLAS.h"
extern "C"
void matcal(float *A, float *B, float *C, int &taille)
fortcublas(A,B,C,taille);
For cuda I use the same file in simpleCUBLAS sample example transforming the main into the fortcublas function. The cuda project is also compiled as static library.
The problem is when I try to build it seems fortran gets to lauching the fortcublas function but doesn’t recognise different cuda and cublas functions:
Erreur 12 fatal error LNK1120: 11 externes non résolus x64\Debug\Fortran.exe
Erreur 5 error LNK2019: symbole externe non résolu cudaMalloc référencé dans la fonction "void __cdecl fortcublas(float *,float *,float *,int)" (?fortcublas@@YAXPEAM00H@Z) simpleCUBLAS.lib(simpleCUBLAS.obj)
Erreur 6 error LNK2019: symbole externe non résolu cudaFree référencé dans la fonction "void __cdecl fortcublas(float *,float *,float *,int)" (?fortcublas@@YAXPEAM00H@Z) simpleCUBLAS.lib(simpleCUBLAS.obj)
Erreur 3 error LNK2019: symbole externe non résolu cudaEventSynchronize référencé dans la fonction "void __cdecl fortcublas(float *,float *,float *,int)" (?fortcublas@@YAXPEAM00H@Z) simpleCUBLAS.lib(simpleCUBLAS.obj)
Erreur 2 error LNK2019: symbole externe non résolu cudaEventRecord référencé dans la fonction "void __cdecl fortcublas(float *,float *,float *,int)" (?fortcublas@@YAXPEAM00H@Z) simpleCUBLAS.lib(simpleCUBLAS.obj)
Erreur 4 error LNK2019: symbole externe non résolu cudaEventElapsedTime référencé dans la fonction "void __cdecl fortcublas(float *,float *,float *,int)" (?fortcublas@@YAXPEAM00H@Z) simpleCUBLAS.lib(simpleCUBLAS.obj)
Erreur 1 error LNK2019: symbole externe non résolu cudaEventCreate référencé dans la fonction "void __cdecl fortcublas(float *,float *,float *,int)" (?fortcublas@@YAXPEAM00H@Z) simpleCUBLAS.lib(simpleCUBLAS.obj)
Erreur 11 error LNK2019: symbole externe non résolu cublasSgemm_v2 référencé dans la fonction "void __cdecl fortcublas(float *,float *,float *,int)" (?fortcublas@@YAXPEAM00H@Z) simpleCUBLAS.lib(simpleCUBLAS.obj)
Erreur 9 error LNK2019: symbole externe non résolu cublasSetVector référencé dans la fonction "void __cdecl fortcublas(float *,float *,float *,int)" (?fortcublas@@YAXPEAM00H@Z) simpleCUBLAS.lib(simpleCUBLAS.obj)
Erreur 10 error LNK2019: symbole externe non résolu cublasGetVector référencé dans la fonction "void __cdecl fortcublas(float *,float *,float *,int)" (?fortcublas@@YAXPEAM00H@Z) simpleCUBLAS.lib(simpleCUBLAS.obj)
Erreur 8 error LNK2019: symbole externe non résolu cublasDestroy_v2 référencé dans la fonction "void __cdecl fortcublas(float *,float *,float *,int)" (?fortcublas@@YAXPEAM00H@Z) simpleCUBLAS.lib(simpleCUBLAS.obj)
Erreur 7 error LNK2019: symbole externe non résolu cublasCreate_v2 référencé dans la fonction "void __cdecl fortcublas(float *,float *,float *,int)" (?fortcublas@@YAXPEAM00H@Z) simpleCUBLAS.lib(simpleCUBLAS.obj)
I know I made it compilcated using fortran to call c++ then to call cuda, but I didn’t find how to do it directly.
Do anyone know how to solve this problem ? Thanks.
