Problem when compiling CUDA Open GL examples
I try to compile example like this:
#ifdef _WIN32
#  define WINDOWS_LEAN_AND_MEAN
#  define NOMINMAX
#  include <windows.h>
#endif
// includes, system
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
// includes, GL
#include <GL/glew.h>
#include <GL/glut.h>
// includes
#include <cutil.h>
#include <cutil_gl_error.h>
#include <cuda_gl_interop.h>
// constants
const unsigned int window_width = 512;
const unsigned int window_height = 512;
const unsigned int mesh_width = 256;
const unsigned int mesh_height = 256;
// vbo variables
GLuint vbo;
float anim = 0.0;
// mouse controls
int mouse_old_x, mouse_old_y;
int mouse_buttons = 0;
float rotate_x = 0.0, rotate_y = 0.0;
float translate_z = -3.0;
// kernels
//#include <simpleGL_kernel.cu>
__global__ void kernel(float4* pos, unsigned int width, unsigned int height, float time)
	unsigned int x = blockIdx.x*blockDim.x + threadIdx.x;
	unsigned int y = blockIdx.y*blockDim.y + threadIdx.y;
	// calculate uv coordinates
	float u = x / (float) width;
	float v = y / (float) height;
	u = u*2.0f - 1.0f;
	v = v*2.0f - 1.0f;
	// calculate simple sine wave pattern
	float freq = 4.0f;
	float w = sinf(u*freq + time) * cosf(v*freq + time) * 0.5f;
	// write output vertex
	pos[y*width+x] = make_float4(u, w, v, 1.0f);
 void launch_kernel(float4* pos, unsigned int mesh_width, unsigned int mesh_height, float time)
	// execute the kernel
	dim3 block(8, 8, 1);
	dim3 grid(mesh_width / block.x, mesh_height / block.y, 1);
	kernel<<< grid, block>>>(pos, mesh_width, mesh_height, time);
// declaration, forward
void runTest( int argc, char** argv);
// GL functionality
CUTBoolean initGL();
void createVBO( GLuint* vbo);
void deleteVBO( GLuint* vbo);
// rendering callbacks
void display();
void keyboard( unsigned char key, int x, int y);
void mouse(int button, int state, int x, int y);
void motion(int x, int y);
// Cuda functionality
void runCuda( GLuint vbo);
void checkResultCuda( int argc, char** argv, const GLuint& vbo);
// Program main
int main( int argc, char** argv)
	runTest( argc, argv);
	CUT_EXIT(argc, argv);
//! Run a simple test for CUDA
	//CUT_DEVICE_INIT();
	// Create GL context
	glutInit( &argc, argv);
	glutInitDisplayMode( GLUT_RGBA | GLUT_DOUBLE);
	glutInitWindowSize( window_width, window_height);
	glutCreateWindow( "Cuda GL interop");
	// initialize GL
	if( CUTFalse == initGL()) {
		return;
	// register callbacks
	glutDisplayFunc( display);
	glutKeyboardFunc( keyboard);
	glutMouseFunc( mouse);
	glutMotionFunc( motion);
	// create VBO
	createVBO( &vbo);
	// run the cuda part
	runCuda( vbo);
	// check result of Cuda step
	checkResultCuda( argc, argv, vbo);
	// start rendering mainloop
	glutMainLoop();
//! Run the Cuda part of the computation
	// map OpenGL buffer object for writing from CUDA
	float4 *dptr;
	CUDA_SAFE_CALL(cudaGLMapBufferObject( (void**)&dptr, vbo));
	kernel<<< grid, block>>>(dptr, mesh_width, mesh_height, anim);
	// unmap buffer object
	CUDA_SAFE_CALL(cudaGLUnmapBufferObject( vbo));
//! Initialize GL
CUTBoolean initGL()
	// initialize necessary OpenGL extensions
	glewInit();
	if (! glewIsSupported( "GL_VERSION_2_0 "
		"GL_ARB_pixel_buffer_object"
		fprintf( stderr, "ERROR: Support for necessary OpenGL extensions missing.");
		fflush( stderr);
		return CUTFalse;
	// default initialization
	glClearColor( 0.0, 0.0, 0.0, 1.0);
	glDisable( GL_DEPTH_TEST);
	// viewport
	glViewport( 0, 0, window_width, window_height);
	// projection
	glMatrixMode( GL_PROJECTION);
	glLoadIdentity();
	gluPerspective(60.0, (GLfloat)window_width / (GLfloat) window_height, 0.1, 10.0);
	CUT_CHECK_ERROR_GL();
	return CUTTrue;
//! Create VBO
void createVBO(GLuint* vbo)
	// create buffer object
	glGenBuffers( 1, vbo);
	glBindBuffer( GL_ARRAY_BUFFER, *vbo);
	// initialize buffer object
	unsigned int size = mesh_width * mesh_height * 4 * sizeof( float);
	glBufferData( GL_ARRAY_BUFFER, size, 0, GL_DYNAMIC_DRAW);
	glBindBuffer( GL_ARRAY_BUFFER, 0);
	// register buffer object with CUDA
	CUDA_SAFE_CALL(cudaGLRegisterBufferObject(*vbo));
//! Delete VBO
	glBindBuffer( 1, *vbo);
	glDeleteBuffers( 1, vbo);
	CUDA_SAFE_CALL(cudaGLUnregisterBufferObject(*vbo));
	*vbo = 0;
//! Display callback
void display()
	// run CUDA kernel to generate vertex positions
	runCuda(vbo);
	glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
	// set view matrix
	glMatrixMode(GL_MODELVIEW);
	glLoadIdentity();
	glTranslatef(0.0, 0.0, translate_z);
	glRotatef(rotate_x, 1.0, 0.0, 0.0);
	glRotatef(rotate_y, 0.0, 1.0, 0.0);
	// render from the vbo
	glBindBuffer(GL_ARRAY_BUFFER, vbo);
	glVertexPointer(4, GL_FLOAT, 0, 0);
	glEnableClientState(GL_VERTEX_ARRAY);
	glColor3f(1.0, 0.0, 0.0);
	glDrawArrays(GL_POINTS, 0, mesh_width * mesh_height);
	glDisableClientState(GL_VERTEX_ARRAY);
	glutSwapBuffers();
	glutPostRedisplay();
	anim += 0.01;
//! Keyboard events handler
void keyboard( unsigned char key, int /*x*/, int /*y*/)
	switch( key) {
	case( 27) :
		deleteVBO( &vbo);
		exit( 0);
//! Mouse event handlers
	if (state == GLUT_DOWN) {
		mouse_buttons |= 1<<button;
	} else if (state == GLUT_UP) {
		mouse_buttons = 0;
	mouse_old_x = x;
	mouse_old_y = y;
	float dx, dy;
	dx = x - mouse_old_x;
	dy = y - mouse_old_y;
	if (mouse_buttons & 1) {
		rotate_x += dy * 0.2;
		rotate_y += dx * 0.2;
	} else if (mouse_buttons & 4) {
		translate_z += dy * 0.01;
	mouse_old_x = x;
	mouse_old_y = y;
//! Check if the result is correct or write data to file for external
//! regression testing
	CUDA_SAFE_CALL(cudaGLUnregisterBufferObject(vbo));
	// map buffer object
	glBindBuffer( GL_ARRAY_BUFFER_ARB, vbo );
	float* data = (float*) glMapBuffer( GL_ARRAY_BUFFER, GL_READ_ONLY);
	// check result
	if( cutCheckCmdLineFlag( argc, (const char**) argv, "regression")) {
		// write file for regression test
		CUT_SAFE_CALL( cutWriteFilef( "./data/regression.dat",
			data, mesh_width * mesh_height * 3, 0.0));
	// unmap GL buffer object
	if( ! glUnmapBuffer( GL_ARRAY_BUFFER)) {
		fprintf( stderr, "Unmap buffer failed.\n");
		fflush( stderr);
	CUDA_SAFE_CALL(cudaGLRegisterBufferObject(vbo));
but thore are erross, plenty of them
Error 1 error LNK2019: unresolved external symbol glutMainLoop referenced in function “void __cdecl runTest(int,char * *)” (?runTest@@YAXHPEAPEAD@Z) sample.cu.obj
Error 1 error LNK2019: unresolved external symbol glutMotionFunc referenced in function “void __cdecl runTest(int,char * *)” (?runTest@@YAXHPEAPEAD@Z) sample.cu.obj
this happens every time when I try with OpenGL/Cuda sample. Just CUDA sample runs ok.
any help pelase
kind regards
milan
On Linux install the freeglut-devel package, make sure the glut library is found during the linking phase.
Apparrently you have the GLUT headers on your system, but something went wrong during linking. It could also be that your installed GLUT library is too old and doesn’t offer all the functions needed.
