We tried to build it on local device but no error happens. Please compare the parameters with your case.
$ make t186 PROJECT=t186 TARGET=t186 BUILDROOT=./t194ref TOOLCHAIN_PREFIX="${CROSS_COMPILE_AARCH64}" ARCH_arm_TOOLCHAIN_PREFIX="${CROSS_COMPILE_ARM}" ARCH_arm64_TOOLCHAIN_PREFIX="${CROSS_COMPILE_AARCH64}" DEBUG=0 DEBUG_LVL=0 DEFAULT_OTE_APP_DEBUGLEVEL=1 NOECHO=@ TRUSTY_VARIANT=l4t-public TRUSTY_MULTI_GUEST_CONFIGURATION=TARGET_SOC=t194
make[1]: Entering directory '/home/carol/Desktop/JEP/Image/TX2+Xavier_R32.5.1_Build/Linux_for_Tegra/source/public/atf_and_trusty/trusty/trusty'
make[2]: Entering directory '/home/carol/Desktop/JEP/Image/TX2+Xavier_R32.5.1_Build/Linux_for_Tegra/source/public/atf_and_trusty/trusty/trusty'
PROJECT = t186
PLATFORM = t18x
TARGET = t186
TOOLCHAIN_PREFIX = /home/carol/Desktop/JEP/Image/CROSS_COMPILE/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-
including app dev dev/interrupt/arm_gic dev/timer/arm_generic kernel lib/boot_profiler lib/memlog lib/sm lib/trusty platform target
including kernel/vm lib/debug lib/fixed_point lib/heap lib/libc lib/syscall lib/uthread lib/version
Include Trusty user tasks support
XBIN_TOOLCHAIN_PREFIX = /home/carol/Desktop/JEP/Image/CROSS_COMPILE/gcc-linaro-7.3.1-2018.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-
XBIN_LIBGCC = /home/carol/Desktop/JEP/Image/CROSS_COMPILE/gcc-linaro-7.3.1-2018.05-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.3.1/libgcc.a
including app/trusty lib/libc-trusty
including lib/libc
including lib/libc
including app/trusty lib/libc-trusty lib/openssl
including lib/libc lib/openssl-stubs
including lib/rng
including interface/hwrng
including lib/rng
LIBGCC = /home/carol/Desktop/JEP/Image/CROSS_COMPILE/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/libgcc.a
GLOBAL_COMPILEFLAGS = -g -fno-builtin -finline -include ./t194ref/build-t186/config.h -W -Wall -Wno-multichar -Wno-unused-parameter -Wno-nonnull-compare -ffunction-sections -fdata-sections
GLOBAL_OPTFLAGS = -O2
generating t194ref/build-t186/tegra/public/platform/t18x/module_config.h
generating t194ref/build-t186/config.h
compiling tegra/public/platform/t18x/platform.c
compiling tegra/public/platform/t18x/combined_uart.c
compiling tegra/public/platform/tegra_common/boot.c
compiling tegra/public/platform/tegra_common/combined_uart.c
compiling tegra/public/platform/tegra_common/debug.c
compiling tegra/public/platform/tegra_common/common_platform.c
compiling tegra/public/platform/tegra_common/ioctl.c
compiling tegra/public/platform/tegra_common/syscall.c
compiling tegra/public/platform/tegra_common/hyp_stubs.c
linking t194ref/build-t186/tegra/public/platform/t18x.mod.o
generating t194ref/build-t186/lk/common/arch/arm64/module_config.h
compiling lk/common/arch/arm64/arch.c
compiling lk/common/arch/arm64/exceptions_c.c
compiling lk/common/arch/arm64/fpu.c
compiling lk/common/arch/arm64/thread.c
compiling lk/common/arch/arm64/stacktrace.c
compiling lk/common/arch/arm64/mp.c
compiling lk/common/arch/arm64/mmu.c
compiling lk/common/arch/arm64/asm.S
compiling lk/common/arch/arm64/exceptions.S
compiling lk/common/arch/arm64/spinlock.S
compiling lk/common/arch/arm64/start.S
compiling lk/common/arch/arm64/cache-ops.S
compiling lk/common/arch/arm64/cache_helpers.S
linking t194ref/build-t186/lk/common/arch/arm64.mod.o
generating t194ref/build-t186/lk/common/top/module_config.h
compiling lk/common/top/init.c
compiling lk/common/top/main.c
linking t194ref/build-t186/lk/common/top.mod.o
generating t194ref/build-t186/lk/common/app/module_config.h
compiling lk/common/app/app.c
linking t194ref/build-t186/lk/common/app.mod.o
generating t194ref/build-t186/lk/common/dev/module_config.h
compiling lk/common/dev/dev.c
compiling lk/common/dev/driver.c
compiling lk/common/dev/class/block_api.c
compiling lk/common/dev/class/i2c_api.c
compiling lk/common/dev/class/spi_api.c
compiling lk/common/dev/class/uart_api.c
compiling lk/common/dev/class/fb_api.c
compiling lk/common/dev/class/netif_api.c
linking t194ref/build-t186/lk/common/dev.mod.o
generating t194ref/build-t186/lk/common/dev/interrupt/arm_gic/module_config.h
compiling lk/common/dev/interrupt/arm_gic/arm_gic.c
linking t194ref/build-t186/lk/common/dev/interrupt/arm_gic.mod.o
generating t194ref/build-t186/lk/common/dev/timer/arm_generic/module_config.h
compiling lk/common/dev/timer/arm_generic/arm_generic_timer.c
linking t194ref/build-t186/lk/common/dev/timer/arm_generic.mod.o
generating t194ref/build-t186/lk/common/kernel/module_config.h
compiling lk/common/kernel/debug.c
compiling lk/common/kernel/event.c
compiling lk/common/kernel/init.c
compiling lk/common/kernel/mutex.c
compiling lk/common/kernel/thread.c
compiling lk/common/kernel/timer.c
compiling lk/common/kernel/semaphore.c
compiling lk/common/kernel/mp.c
linking t194ref/build-t186/lk/common/kernel.mod.o
generating t194ref/build-t186/tegra/public/lib/boot_profiler/module_config.h
compiling tegra/public/lib/boot_profiler/boot_profiler.c
linking t194ref/build-t186/tegra/public/lib/boot_profiler.mod.o
generating t194ref/build-t186/lk/trusty/lib/memlog/module_config.h
compiling lk/trusty/lib/memlog/memlog.c
linking t194ref/build-t186/lk/trusty/lib/memlog.mod.o
generating t194ref/build-t186/lk/trusty/lib/sm/module_config.h
compiling lk/trusty/lib/sm/halt.c
compiling lk/trusty/lib/sm/sm.c
compiling lk/trusty/lib/sm/smcall.c
compiling lk/trusty/lib/sm/ns_mem.c
compiling lk/trusty/lib/sm/arch/arm64/entry.S
linking t194ref/build-t186/lk/trusty/lib/sm.mod.o
generating t194ref/build-t186/lk/trusty/lib/trusty/module_config.h
compiling lk/trusty/lib/trusty/trusty.c
compiling lk/trusty/lib/trusty/trusty_app.c
compiling lk/trusty/lib/trusty/syscall.c
compiling lk/trusty/lib/trusty/handle.c
compiling lk/trusty/lib/trusty/uctx.c
compiling lk/trusty/lib/trusty/ipc.c
compiling lk/trusty/lib/trusty/ipc_msg.c
compiling lk/trusty/lib/trusty/iovec.c
compiling lk/trusty/lib/trusty/uuid.c
compiling lk/trusty/lib/trusty/vqueue.c
compiling lk/trusty/lib/trusty/smcall.c
compiling lk/trusty/lib/trusty/trusty_virtio.c
compiling lk/trusty/lib/trusty/tipc_dev.c
compiling lk/trusty/lib/trusty/tipc_dev_ql.c
compiling lk/trusty/lib/trusty/tipc_config.c
linking t194ref/build-t186/lk/trusty/lib/trusty.mod.o
generating t194ref/build-t186/lk/common/platform/module_config.h
compiling lk/common/platform/debug.c
compiling lk/common/platform/init.c
compiling lk/common/platform/power.c
linking t194ref/build-t186/lk/common/platform.mod.o
generating t194ref/build-t186/lk/common/target/module_config.h
compiling lk/common/target/init.c
linking t194ref/build-t186/lk/common/target.mod.o
generating t194ref/build-t186/lk/common/kernel/vm/module_config.h
compiling lk/common/kernel/vm/bootalloc.c
compiling lk/common/kernel/vm/pmm.c
compiling lk/common/kernel/vm/vm.c
compiling lk/common/kernel/vm/vmm.c
linking t194ref/build-t186/lk/common/kernel/vm.mod.o
generating t194ref/build-t186/lk/common/lib/debug/module_config.h
compiling lk/common/lib/debug/debug.c
linking t194ref/build-t186/lk/common/lib/debug.mod.o
generating t194ref/build-t186/lk/common/lib/fixed_point/module_config.h
compiling lk/common/lib/fixed_point/fixed_point.c
linking t194ref/build-t186/lk/common/lib/fixed_point.mod.o
generating t194ref/build-t186/lk/common/lib/heap/module_config.h
compiling lk/common/lib/heap/heap.c
linking t194ref/build-t186/lk/common/lib/heap.mod.o
generating t194ref/build-t186/lk/common/lib/libc/module_config.h
compiling lk/common/lib/libc/atoi.c
compiling lk/common/lib/libc/bsearch.c
compiling lk/common/lib/libc/ctype.c
compiling lk/common/lib/libc/errno.c
compiling lk/common/lib/libc/printf.c
compiling lk/common/lib/libc/rand.c
compiling lk/common/lib/libc/strtol.c
compiling lk/common/lib/libc/strtoll.c
compiling lk/common/lib/libc/stdio.c
compiling lk/common/lib/libc/qsort.c
compiling lk/common/lib/libc/eabi.c
compiling lk/common/lib/libc/stackprotector.c
compiling lk/common/lib/libc/malloc.c
compiling lk/common/lib/libc/string/bcopy.c
compiling lk/common/lib/libc/string/bzero.c
compiling lk/common/lib/libc/string/memchr.c
compiling lk/common/lib/libc/string/memcmp.c
compiling lk/common/lib/libc/string/memcpy.c
compiling lk/common/lib/libc/string/memmove.c
compiling lk/common/lib/libc/string/memset.c
compiling lk/common/lib/libc/string/strcat.c
compiling lk/common/lib/libc/string/strchr.c
compiling lk/common/lib/libc/string/strcmp.c
compiling lk/common/lib/libc/string/strcoll.c
compiling lk/common/lib/libc/string/strcpy.c
compiling lk/common/lib/libc/string/strdup.c
compiling lk/common/lib/libc/string/strerror.c
compiling lk/common/lib/libc/string/strlcat.c
compiling lk/common/lib/libc/string/strlcpy.c
compiling lk/common/lib/libc/string/strlen.c
compiling lk/common/lib/libc/string/strncat.c
compiling lk/common/lib/libc/string/strncpy.c
compiling lk/common/lib/libc/string/strncmp.c
compiling lk/common/lib/libc/string/strnicmp.c
compiling lk/common/lib/libc/string/strnlen.c
compiling lk/common/lib/libc/string/strpbrk.c
compiling lk/common/lib/libc/string/strrchr.c
compiling lk/common/lib/libc/string/strspn.c
compiling lk/common/lib/libc/string/strstr.c
compiling lk/common/lib/libc/string/strtok.c
compiling lk/common/lib/libc/string/strxfrm.c
linking t194ref/build-t186/lk/common/lib/libc.mod.o
generating t194ref/build-t186/lk/trusty/lib/syscall/module_config.h
compiling lk/trusty/lib/syscall/syscall.c
compiling lk/trusty/lib/syscall/arch/arm64/syscall.S
linking t194ref/build-t186/lk/trusty/lib/syscall.mod.o
generating t194ref/build-t186/lk/trusty/lib/uthread/module_config.h
compiling lk/trusty/lib/uthread/uthread.c
compiling lk/trusty/lib/uthread/arch/arm64/uthread.c
compiling lk/trusty/lib/uthread/arch/arm64/usercopy.S
linking t194ref/build-t186/lk/trusty/lib/uthread.mod.o
generating t194ref/build-t186/lk/trusty/lib/version/module_config.h
make[2]: Circular t194ref/build-t186/lk/trusty/lib/version/version.o <- t194ref/build-t186/lk/trusty/lib/version.mod.o dependency dropped.
generating t194ref/build-t186/user_tasks/sample/ipc-unittest/main/app/sample/ipc-unittest/main/module_config.h
compiling app/sample/ipc-unittest/main/manifest.c
compiling app/sample/ipc-unittest/main/main.c
linking t194ref/build-t186/user_tasks/sample/ipc-unittest/main/app/sample/ipc-unittest/main.mod.o
compiling lib/lib/libc-trusty/arch/arm/crtbegin.c
compiling lib/lib/libc-trusty/arch/arm/crtend.S
generating t194ref/build-t186/user_tasks/sample/ipc-unittest/main/lib/lib/libc-trusty/module_config.h
compiling lib/lib/libc-trusty/abort.c
compiling lib/lib/libc-trusty/assert.c
compiling lib/lib/libc-trusty/atexit.c
compiling lib/lib/libc-trusty/exit.c
compiling lib/lib/libc-trusty/malloc.c
compiling lib/lib/libc-trusty/stdio.c
compiling lib/lib/libc-trusty/libc_init.c
compiling lib/lib/libc-trusty/libc_fatal.c
compiling lib/lib/libc-trusty/arch/arm/trusty_syscall.S
linking t194ref/build-t186/user_tasks/sample/ipc-unittest/main/lib/lib/libc-trusty.mod.o
generating t194ref/build-t186/user_tasks/sample/ipc-unittest/main/lk/common/lib/libc/module_config.h
linking t194ref/build-t186/user_tasks/sample/ipc-unittest/main/lk/common/lib/libc.mod.o
generating t194ref/build-t186/user_tasks/sample/ipc-unittest/main/user_task.ld
linking t194ref/build-t186/user_tasks/sample/ipc-unittest/main/main.syms.elf
/home/carol/Desktop/JEP/Image/CROSS_COMPILE/gcc-linaro-7.3.1-2018.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-ld.bfd: warning: section `.bss' type changed to PROGBITS
stripping t194ref/build-t186/user_tasks/sample/ipc-unittest/main/main.syms.elf
generating t194ref/build-t186/user_tasks/sample/ipc-unittest/srv/app/sample/ipc-unittest/srv/module_config.h
compiling app/sample/ipc-unittest/srv/manifest.c
compiling app/sample/ipc-unittest/srv/srv.c
linking t194ref/build-t186/user_tasks/sample/ipc-unittest/srv/app/sample/ipc-unittest/srv.mod.o
generating t194ref/build-t186/user_tasks/sample/ipc-unittest/srv/lib/lib/libc-trusty/module_config.h
linking t194ref/build-t186/user_tasks/sample/ipc-unittest/srv/lib/lib/libc-trusty.mod.o
generating t194ref/build-t186/user_tasks/sample/ipc-unittest/srv/lk/common/lib/libc/module_config.h
linking t194ref/build-t186/user_tasks/sample/ipc-unittest/srv/lk/common/lib/libc.mod.o
generating t194ref/build-t186/user_tasks/sample/ipc-unittest/srv/user_task.ld
linking t194ref/build-t186/user_tasks/sample/ipc-unittest/srv/srv.syms.elf
stripping t194ref/build-t186/user_tasks/sample/ipc-unittest/srv/srv.syms.elf
generating t194ref/build-t186/user_tasks/nvidia-sample/hwkey-agent/app/nvidia-sample/hwkey-agent/module_config.h
compiling app/nvidia-sample/hwkey-agent/crypto_service.c
compiling app/nvidia-sample/hwkey-agent/ekb_helper.c
compiling app/nvidia-sample/hwkey-agent/get_key_srv.c
compiling app/nvidia-sample/hwkey-agent/hwkey_agent.c
compiling app/nvidia-sample/hwkey-agent/ipc.c
compiling app/nvidia-sample/hwkey-agent/key_mgnt.c
compiling app/nvidia-sample/hwkey-agent/manifest.c
compiling app/nvidia-sample/hwkey-agent/platform/fuse/fuse.c
compiling app/nvidia-sample/hwkey-agent/platform/tegra_se/tegra_se.c
compiling app/nvidia-sample/hwkey-agent/platform/tegra_se/tegra_se_aes.c
linking t194ref/build-t186/user_tasks/nvidia-sample/hwkey-agent/app/nvidia-sample/hwkey-agent.mod.o
generating t194ref/build-t186/user_tasks/nvidia-sample/hwkey-agent/lib/lib/libc-trusty/module_config.h
linking t194ref/build-t186/user_tasks/nvidia-sample/hwkey-agent/lib/lib/libc-trusty.mod.o
generating t194ref/build-t186/user_tasks/nvidia-sample/hwkey-agent/lib/lib/openssl/module_config.h
compiling lib/lib/openssl/crypto/aes/aes_cbc.c
compiling lib/lib/openssl/crypto/aes/aes_cfb.c
compiling lib/lib/openssl/crypto/aes/aes_core.c
compiling lib/lib/openssl/crypto/aes/aes_ecb.c
compiling lib/lib/openssl/crypto/aes/aes_ige.c
compiling lib/lib/openssl/crypto/aes/aes_misc.c
compiling lib/lib/openssl/crypto/aes/aes_ofb.c
compiling lib/lib/openssl/crypto/aes/aes_wrap.c
compiling lib/lib/openssl/crypto/asn1/a_bitstr.c
compiling lib/lib/openssl/crypto/asn1/a_d2i_fp.c
compiling lib/lib/openssl/crypto/asn1/a_digest.c
compiling lib/lib/openssl/crypto/asn1/a_dup.c
compiling lib/lib/openssl/crypto/asn1/a_gentm.c
compiling lib/lib/openssl/crypto/asn1/a_i2d_fp.c
compiling lib/lib/openssl/crypto/asn1/a_int.c
compiling lib/lib/openssl/crypto/asn1/a_mbstr.c
compiling lib/lib/openssl/crypto/asn1/a_object.c
compiling lib/lib/openssl/crypto/asn1/a_octet.c
compiling lib/lib/openssl/crypto/asn1/a_print.c
compiling lib/lib/openssl/crypto/asn1/a_sign.c
compiling lib/lib/openssl/crypto/asn1/a_strex.c
lib/lib/openssl/crypto/asn1/a_strex.c: In function ‘do_name_ex’:
lib/lib/openssl/crypto/asn1/a_strex.c:442:16: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
sep_dn = "\n";
lib/lib/openssl/crypto/asn1/a_strex.c:444:16: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
sep_mv = " + ";
lib/lib/openssl/crypto/asn1/a_strex.c:449:16: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
sep_dn = ",";
lib/lib/openssl/crypto/asn1/a_strex.c:451:16: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
sep_mv = "+";
lib/lib/openssl/crypto/asn1/a_strex.c:457:16: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
sep_dn = ", ";
lib/lib/openssl/crypto/asn1/a_strex.c:459:16: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
sep_mv = " + ";
lib/lib/openssl/crypto/asn1/a_strex.c:465:16: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
sep_dn = "; ";
lib/lib/openssl/crypto/asn1/a_strex.c:467:16: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
sep_mv = " + ";
lib/lib/openssl/crypto/asn1/a_strex.c:477:16: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
sep_eq = " = ";
lib/lib/openssl/crypto/asn1/a_strex.c:480:16: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
sep_eq = "=";
compiling lib/lib/openssl/crypto/asn1/a_strnid.c
compiling lib/lib/openssl/crypto/asn1/a_time.c
compiling lib/lib/openssl/crypto/asn1/a_type.c
compiling lib/lib/openssl/crypto/asn1/a_utctm.c
compiling lib/lib/openssl/crypto/asn1/a_utf8.c
compiling lib/lib/openssl/crypto/asn1/a_verify.c
compiling lib/lib/openssl/crypto/asn1/ameth_lib.c
compiling lib/lib/openssl/crypto/asn1/asn1_err.c
compiling lib/lib/openssl/crypto/asn1/asn1_gen.c
compiling lib/lib/openssl/crypto/asn1/asn1_item_list.c
compiling lib/lib/openssl/crypto/asn1/asn1_lib.c
compiling lib/lib/openssl/crypto/asn1/asn1_par.c
compiling lib/lib/openssl/crypto/asn1/asn_mime.c
compiling lib/lib/openssl/crypto/asn1/asn_moid.c
compiling lib/lib/openssl/crypto/asn1/asn_mstbl.c
compiling lib/lib/openssl/crypto/asn1/asn_pack.c
compiling lib/lib/openssl/crypto/asn1/bio_asn1.c
lib/lib/openssl/crypto/asn1/bio_asn1.c:81:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"asn1",
compiling lib/lib/openssl/crypto/asn1/bio_ndef.c
compiling lib/lib/openssl/crypto/asn1/d2i_pr.c
compiling lib/lib/openssl/crypto/asn1/d2i_pu.c
compiling lib/lib/openssl/crypto/asn1/evp_asn1.c
compiling lib/lib/openssl/crypto/asn1/f_int.c
compiling lib/lib/openssl/crypto/asn1/f_string.c
compiling lib/lib/openssl/crypto/asn1/i2d_pr.c
compiling lib/lib/openssl/crypto/asn1/i2d_pu.c
compiling lib/lib/openssl/crypto/asn1/nsseq.c
compiling lib/lib/openssl/crypto/asn1/p5_pbe.c
compiling lib/lib/openssl/crypto/asn1/p5_pbev2.c
compiling lib/lib/openssl/crypto/asn1/p8_pkey.c
compiling lib/lib/openssl/crypto/asn1/t_bitst.c
compiling lib/lib/openssl/crypto/asn1/t_pkey.c
compiling lib/lib/openssl/crypto/asn1/t_spki.c
compiling lib/lib/openssl/crypto/asn1/tasn_dec.c
compiling lib/lib/openssl/crypto/asn1/tasn_enc.c
compiling lib/lib/openssl/crypto/asn1/tasn_fre.c
compiling lib/lib/openssl/crypto/asn1/tasn_new.c
compiling lib/lib/openssl/crypto/asn1/tasn_prn.c
lib/lib/openssl/crypto/asn1/tasn_prn.c: In function ‘asn1_template_print_ctx’:
lib/lib/openssl/crypto/asn1/tasn_prn.c:298:27: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
tname = "SET";
lib/lib/openssl/crypto/asn1/tasn_prn.c:300:27: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
tname = "SEQUENCE";
compiling lib/lib/openssl/crypto/asn1/tasn_scn.c
compiling lib/lib/openssl/crypto/asn1/tasn_typ.c
compiling lib/lib/openssl/crypto/asn1/tasn_utl.c
compiling lib/lib/openssl/crypto/asn1/x_algor.c
compiling lib/lib/openssl/crypto/asn1/x_bignum.c
compiling lib/lib/openssl/crypto/asn1/x_info.c
compiling lib/lib/openssl/crypto/asn1/x_int64.c
compiling lib/lib/openssl/crypto/asn1/x_long.c
compiling lib/lib/openssl/crypto/asn1/x_pkey.c
compiling lib/lib/openssl/crypto/asn1/x_sig.c
compiling lib/lib/openssl/crypto/asn1/x_spki.c
compiling lib/lib/openssl/crypto/asn1/x_val.c
compiling lib/lib/openssl/crypto/async/arch/async_null.c
compiling lib/lib/openssl/crypto/async/async.c
compiling lib/lib/openssl/crypto/async/async_err.c
compiling lib/lib/openssl/crypto/async/async_wait.c
compiling lib/lib/openssl/crypto/bio/b_dump.c
compiling lib/lib/openssl/crypto/bio/b_print.c
compiling lib/lib/openssl/crypto/bio/bf_buff.c
lib/lib/openssl/crypto/bio/bf_buff.c:27:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"buffer",
compiling lib/lib/openssl/crypto/bio/bf_lbuf.c
lib/lib/openssl/crypto/bio/bf_lbuf.c:32:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"linebuffer",
compiling lib/lib/openssl/crypto/bio/bf_nbio.c
lib/lib/openssl/crypto/bio/bf_nbio.c:36:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"non-blocking IO test filter",
compiling lib/lib/openssl/crypto/bio/bf_null.c
lib/lib/openssl/crypto/bio/bf_null.c:27:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"NULL filter",
compiling lib/lib/openssl/crypto/bio/bio_cb.c
compiling lib/lib/openssl/crypto/bio/bio_err.c
compiling lib/lib/openssl/crypto/bio/bio_lib.c
compiling lib/lib/openssl/crypto/bio/bio_meth.c
compiling lib/lib/openssl/crypto/bio/bss_bio.c
lib/lib/openssl/crypto/bio/bss_bio.c:40:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"BIO pair",
compiling lib/lib/openssl/crypto/bio/bss_fd.c
compiling lib/lib/openssl/crypto/bio/bss_log.c
compiling lib/lib/openssl/crypto/bio/bss_mem.c
lib/lib/openssl/crypto/bio/bss_mem.c:28:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"memory buffer",
lib/lib/openssl/crypto/bio/bss_mem.c:45:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"secure memory buffer",
compiling lib/lib/openssl/crypto/bio/bss_null.c
lib/lib/openssl/crypto/bio/bss_null.c:22:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"NULL",
compiling lib/lib/openssl/crypto/bn/bn_add.c
compiling lib/lib/openssl/crypto/bn/bn_asm.c
compiling lib/lib/openssl/crypto/bn/bn_blind.c
compiling lib/lib/openssl/crypto/bn/bn_const.c
compiling lib/lib/openssl/crypto/bn/bn_ctx.c
compiling lib/lib/openssl/crypto/bn/bn_dh.c
compiling lib/lib/openssl/crypto/bn/bn_div.c
compiling lib/lib/openssl/crypto/bn/bn_err.c
compiling lib/lib/openssl/crypto/bn/bn_exp.c
compiling lib/lib/openssl/crypto/bn/bn_exp2.c
compiling lib/lib/openssl/crypto/bn/bn_gcd.c
compiling lib/lib/openssl/crypto/bn/bn_gf2m.c
compiling lib/lib/openssl/crypto/bn/bn_intern.c
compiling lib/lib/openssl/crypto/bn/bn_kron.c
compiling lib/lib/openssl/crypto/bn/bn_lib.c
compiling lib/lib/openssl/crypto/bn/bn_mod.c
compiling lib/lib/openssl/crypto/bn/bn_mont.c
compiling lib/lib/openssl/crypto/bn/bn_mpi.c
compiling lib/lib/openssl/crypto/bn/bn_mul.c
compiling lib/lib/openssl/crypto/bn/bn_nist.c
compiling lib/lib/openssl/crypto/bn/bn_prime.c
compiling lib/lib/openssl/crypto/bn/bn_print.c
compiling lib/lib/openssl/crypto/bn/bn_rand.c
compiling lib/lib/openssl/crypto/bn/bn_recp.c
compiling lib/lib/openssl/crypto/bn/bn_shift.c
compiling lib/lib/openssl/crypto/bn/bn_sqr.c
compiling lib/lib/openssl/crypto/bn/bn_sqrt.c
compiling lib/lib/openssl/crypto/bn/bn_word.c
compiling lib/lib/openssl/crypto/bn/bn_x931p.c
compiling lib/lib/openssl/crypto/buffer/buf_err.c
compiling lib/lib/openssl/crypto/buffer/buffer.c
compiling lib/lib/openssl/crypto/cmac/cm_ameth.c
lib/lib/openssl/crypto/cmac/cm_ameth.c:37:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"CMAC",
lib/lib/openssl/crypto/cmac/cm_ameth.c:38:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"OpenSSL CMAC method",
compiling lib/lib/openssl/crypto/cmac/cm_pmeth.c
compiling lib/lib/openssl/crypto/cmac/cmac.c
compiling lib/lib/openssl/crypto/conf/conf_sap.c
lib/lib/openssl/crypto/conf/conf_sap.c: In function ‘openssl_config_int’:
lib/lib/openssl/crypto/conf/conf_sap.c:48:19: warning: variable ‘flags’ set but not used [-Wunused-but-set-variable]
unsigned long flags;
lib/lib/openssl/crypto/conf/conf_sap.c:47:17: warning: variable ‘appname’ set but not used [-Wunused-but-set-variable]
const char *appname;
lib/lib/openssl/crypto/conf/conf_sap.c:46:17: warning: variable ‘filename’ set but not used [-Wunused-but-set-variable]
const char *filename;
compiling lib/lib/openssl/crypto/cpt_err.c
compiling lib/lib/openssl/crypto/cryptlib.c
compiling lib/lib/openssl/crypto/ctype.c
compiling lib/lib/openssl/crypto/cversion.c
In file included from lib/lib/openssl/crypto/cversion.c:12:0:
lib/lib/openssl/crypto/buildinf.h:13:0: warning: "PLATFORM" redefined
#define PLATFORM "platform: linux-generic32"
In file included from <command-line>:0:0:
././t194ref/build-t186/config.h:37:0: note: this is the location of the previous definition
#define PLATFORM "T18X"
compiling lib/lib/openssl/crypto/dh/dh_ameth.c
lib/lib/openssl/crypto/dh/dh_ameth.c:536:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"DH",
lib/lib/openssl/crypto/dh/dh_ameth.c:537:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"OpenSSL PKCS#3 DH method",
lib/lib/openssl/crypto/dh/dh_ameth.c:575:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"X9.42 DH",
lib/lib/openssl/crypto/dh/dh_ameth.c:576:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"OpenSSL X9.42 DH method",
compiling lib/lib/openssl/crypto/dh/dh_asn1.c
compiling lib/lib/openssl/crypto/dh/dh_check.c
compiling lib/lib/openssl/crypto/dh/dh_err.c
compiling lib/lib/openssl/crypto/dh/dh_gen.c
compiling lib/lib/openssl/crypto/dh/dh_key.c
lib/lib/openssl/crypto/dh/dh_key.c:48:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"OpenSSL DH Method",
compiling lib/lib/openssl/crypto/dh/dh_lib.c
compiling lib/lib/openssl/crypto/dh/dh_meth.c
compiling lib/lib/openssl/crypto/dh/dh_pmeth.c
compiling lib/lib/openssl/crypto/dh/dh_rfc5114.c
compiling lib/lib/openssl/crypto/dh/dh_rfc7919.c
compiling lib/lib/openssl/crypto/dsa/dsa_ameth.c
lib/lib/openssl/crypto/dsa/dsa_ameth.c:544:6: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"DSA",
lib/lib/openssl/crypto/dsa/dsa_ameth.c:545:6: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"OpenSSL DSA method",
compiling lib/lib/openssl/crypto/dsa/dsa_asn1.c
compiling lib/lib/openssl/crypto/dsa/dsa_err.c
compiling lib/lib/openssl/crypto/dsa/dsa_gen.c
compiling lib/lib/openssl/crypto/dsa/dsa_key.c
compiling lib/lib/openssl/crypto/dsa/dsa_lib.c
compiling lib/lib/openssl/crypto/dsa/dsa_meth.c
compiling lib/lib/openssl/crypto/dsa/dsa_ossl.c
lib/lib/openssl/crypto/dsa/dsa_ossl.c:31:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
compiling lib/lib/openssl/crypto/dsa/dsa_pmeth.c
compiling lib/lib/openssl/crypto/dsa/dsa_prn.c
compiling lib/lib/openssl/crypto/dsa/dsa_sign.c
compiling lib/lib/openssl/crypto/dsa/dsa_vrf.c
compiling lib/lib/openssl/crypto/ec/ec2_oct.c
compiling lib/lib/openssl/crypto/ec/ec2_smpl.c
compiling lib/lib/openssl/crypto/ec/ec_ameth.c
lib/lib/openssl/crypto/ec/ec_ameth.c:575:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"EC",
lib/lib/openssl/crypto/ec/ec_ameth.c:576:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"OpenSSL EC algorithm",
compiling lib/lib/openssl/crypto/ec/ec_asn1.c
compiling lib/lib/openssl/crypto/ec/ec_check.c
compiling lib/lib/openssl/crypto/ec/ec_curve.c
compiling lib/lib/openssl/crypto/ec/ec_cvt.c
compiling lib/lib/openssl/crypto/ec/ec_err.c
compiling lib/lib/openssl/crypto/ec/ec_key.c
compiling lib/lib/openssl/crypto/ec/ec_kmeth.c
compiling lib/lib/openssl/crypto/ec/ec_lib.c
compiling lib/lib/openssl/crypto/ec/ec_mult.c
compiling lib/lib/openssl/crypto/ec/ec_oct.c
compiling lib/lib/openssl/crypto/ec/ec_pmeth.c
compiling lib/lib/openssl/crypto/ec/ec_print.c
compiling lib/lib/openssl/crypto/ec/ecdh_kdf.c
compiling lib/lib/openssl/crypto/ec/ecdh_ossl.c
compiling lib/lib/openssl/crypto/ec/ecdsa_ossl.c
compiling lib/lib/openssl/crypto/ec/ecdsa_sign.c
compiling lib/lib/openssl/crypto/ec/ecdsa_vrf.c
compiling lib/lib/openssl/crypto/ec/eck_prn.c
compiling lib/lib/openssl/crypto/ec/ecp_mont.c
compiling lib/lib/openssl/crypto/ec/ecp_nist.c
compiling lib/lib/openssl/crypto/ec/ecp_oct.c
compiling lib/lib/openssl/crypto/ec/ecp_smpl.c
compiling lib/lib/openssl/crypto/err/err.c
lib/lib/openssl/crypto/err/err.c: In function ‘ERR_add_error_vdata’:
lib/lib/openssl/crypto/err/err.c:862:15: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
a = "<NULL>";
compiling lib/lib/openssl/crypto/err/err_all.c
compiling lib/lib/openssl/crypto/err/err_prn.c
compiling lib/lib/openssl/crypto/evp/bio_b64.c
lib/lib/openssl/crypto/evp/bio_b64.c:48:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"base64 encoding",
compiling lib/lib/openssl/crypto/evp/bio_enc.c
lib/lib/openssl/crypto/evp/bio_enc.c:44:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"cipher",
compiling lib/lib/openssl/crypto/evp/bio_md.c
lib/lib/openssl/crypto/evp/bio_md.c:33:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"message digest",
compiling lib/lib/openssl/crypto/evp/bio_ok.c
lib/lib/openssl/crypto/evp/bio_ok.c:112:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"reliable",
compiling lib/lib/openssl/crypto/evp/c_allc.c
compiling lib/lib/openssl/crypto/evp/c_alld.c
compiling lib/lib/openssl/crypto/evp/cmeth_lib.c
compiling lib/lib/openssl/crypto/evp/digest.c
compiling lib/lib/openssl/crypto/evp/e_aes.c
compiling lib/lib/openssl/crypto/evp/e_aes_cbc_hmac_sha1.c
compiling lib/lib/openssl/crypto/evp/e_aes_cbc_hmac_sha256.c
compiling lib/lib/openssl/crypto/evp/e_null.c
compiling lib/lib/openssl/crypto/evp/encode.c
compiling lib/lib/openssl/crypto/evp/evp_cnf.c
compiling lib/lib/openssl/crypto/evp/evp_enc.c
compiling lib/lib/openssl/crypto/evp/evp_err.c
compiling lib/lib/openssl/crypto/evp/evp_key.c
compiling lib/lib/openssl/crypto/evp/evp_lib.c
compiling lib/lib/openssl/crypto/evp/evp_pbe.c
compiling lib/lib/openssl/crypto/evp/evp_pkey.c
compiling lib/lib/openssl/crypto/evp/m_md5.c
compiling lib/lib/openssl/crypto/evp/m_md5_sha1.c
compiling lib/lib/openssl/crypto/evp/m_null.c
compiling lib/lib/openssl/crypto/evp/m_sha1.c
compiling lib/lib/openssl/crypto/evp/m_sha3.c
compiling lib/lib/openssl/crypto/evp/m_sigver.c
compiling lib/lib/openssl/crypto/evp/names.c
compiling lib/lib/openssl/crypto/evp/p5_crpt.c
compiling lib/lib/openssl/crypto/evp/p5_crpt2.c
compiling lib/lib/openssl/crypto/evp/p_dec.c
compiling lib/lib/openssl/crypto/evp/p_enc.c
compiling lib/lib/openssl/crypto/evp/p_lib.c
compiling lib/lib/openssl/crypto/evp/p_open.c
compiling lib/lib/openssl/crypto/evp/p_seal.c
compiling lib/lib/openssl/crypto/evp/p_sign.c
compiling lib/lib/openssl/crypto/evp/p_verify.c
compiling lib/lib/openssl/crypto/evp/pmeth_fn.c
compiling lib/lib/openssl/crypto/evp/pmeth_gn.c
compiling lib/lib/openssl/crypto/evp/pmeth_lib.c
compiling lib/lib/openssl/crypto/ex_data.c
compiling lib/lib/openssl/crypto/getenv.c
compiling lib/lib/openssl/crypto/hmac/hm_ameth.c
lib/lib/openssl/crypto/hmac/hm_ameth.c:99:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"HMAC",
lib/lib/openssl/crypto/hmac/hm_ameth.c:100:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"OpenSSL HMAC method",
compiling lib/lib/openssl/crypto/hmac/hm_pmeth.c
compiling lib/lib/openssl/crypto/hmac/hmac.c
compiling lib/lib/openssl/crypto/init.c
compiling lib/lib/openssl/crypto/kdf/hkdf.c
compiling lib/lib/openssl/crypto/kdf/kdf_err.c
compiling lib/lib/openssl/crypto/kdf/tls1_prf.c
compiling lib/lib/openssl/crypto/lhash/lh_stats.c
compiling lib/lib/openssl/crypto/lhash/lhash.c
compiling lib/lib/openssl/crypto/md5/md5_dgst.c
compiling lib/lib/openssl/crypto/md5/md5_one.c
compiling lib/lib/openssl/crypto/mem.c
compiling lib/lib/openssl/crypto/mem_clr.c
compiling lib/lib/openssl/crypto/mem_dbg.c
compiling lib/lib/openssl/crypto/mem_sec.c
compiling lib/lib/openssl/crypto/modes/cbc128.c
compiling lib/lib/openssl/crypto/modes/ccm128.c
compiling lib/lib/openssl/crypto/modes/cfb128.c
compiling lib/lib/openssl/crypto/modes/ctr128.c
compiling lib/lib/openssl/crypto/modes/cts128.c
compiling lib/lib/openssl/crypto/modes/gcm128.c
compiling lib/lib/openssl/crypto/modes/ofb128.c
compiling lib/lib/openssl/crypto/modes/wrap128.c
compiling lib/lib/openssl/crypto/modes/xts128.c
compiling lib/lib/openssl/crypto/o_dir.c
compiling lib/lib/openssl/crypto/o_fips.c
compiling lib/lib/openssl/crypto/o_fopen.c
compiling lib/lib/openssl/crypto/o_init.c
compiling lib/lib/openssl/crypto/o_str.c
lib/lib/openssl/crypto/o_str.c: In function ‘openssl_strerror_r’:
lib/lib/openssl/crypto/o_str.c:260:9: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
err = strerror(errnum);
compiling lib/lib/openssl/crypto/o_time.c
lib/lib/openssl/crypto/o_time.c: In function ‘OPENSSL_gmtime’:
lib/lib/openssl/crypto/o_time.c:49:10: warning: implicit declaration of function ‘gmtime’; did you mean ‘time’? [-Wimplicit-function-declaration]
ts = gmtime(timer);
time
lib/lib/openssl/crypto/o_time.c:49:8: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
ts = gmtime(timer);
compiling lib/lib/openssl/crypto/objects/o_names.c
compiling lib/lib/openssl/crypto/objects/obj_dat.c
compiling lib/lib/openssl/crypto/objects/obj_err.c
compiling lib/lib/openssl/crypto/objects/obj_lib.c
compiling lib/lib/openssl/crypto/objects/obj_xref.c
compiling lib/lib/openssl/crypto/pem/pem_all.c
compiling lib/lib/openssl/crypto/pem/pem_err.c
compiling lib/lib/openssl/crypto/pem/pem_info.c
compiling lib/lib/openssl/crypto/pem/pem_lib.c
compiling lib/lib/openssl/crypto/pem/pem_oth.c
compiling lib/lib/openssl/crypto/pem/pem_pk8.c
compiling lib/lib/openssl/crypto/pem/pem_pkey.c
compiling lib/lib/openssl/crypto/pem/pem_sign.c
compiling lib/lib/openssl/crypto/pem/pem_x509.c
compiling lib/lib/openssl/crypto/pem/pem_xaux.c
compiling lib/lib/openssl/crypto/pem/pvkfmt.c
compiling lib/lib/openssl/crypto/pkcs12/p12_add.c
compiling lib/lib/openssl/crypto/pkcs12/p12_asn.c
compiling lib/lib/openssl/crypto/pkcs12/p12_attr.c
compiling lib/lib/openssl/crypto/pkcs12/p12_crpt.c
compiling lib/lib/openssl/crypto/pkcs12/p12_crt.c
compiling lib/lib/openssl/crypto/pkcs12/p12_decr.c
compiling lib/lib/openssl/crypto/pkcs12/p12_init.c
compiling lib/lib/openssl/crypto/pkcs12/p12_key.c
compiling lib/lib/openssl/crypto/pkcs12/p12_kiss.c
compiling lib/lib/openssl/crypto/pkcs12/p12_mutl.c
compiling lib/lib/openssl/crypto/pkcs12/p12_npas.c
compiling lib/lib/openssl/crypto/pkcs12/p12_p8d.c
compiling lib/lib/openssl/crypto/pkcs12/p12_p8e.c
compiling lib/lib/openssl/crypto/pkcs12/p12_sbag.c
compiling lib/lib/openssl/crypto/pkcs12/p12_utl.c
compiling lib/lib/openssl/crypto/pkcs12/pk12err.c
compiling lib/lib/openssl/crypto/pkcs7/bio_pk7.c
compiling lib/lib/openssl/crypto/pkcs7/pk7_asn1.c
compiling lib/lib/openssl/crypto/pkcs7/pk7_attr.c
compiling lib/lib/openssl/crypto/pkcs7/pk7_doit.c
compiling lib/lib/openssl/crypto/pkcs7/pk7_lib.c
compiling lib/lib/openssl/crypto/pkcs7/pk7_mime.c
compiling lib/lib/openssl/crypto/pkcs7/pk7_smime.c
compiling lib/lib/openssl/crypto/pkcs7/pkcs7err.c
compiling lib/lib/openssl/crypto/rand/drbg_ctr.c
compiling lib/lib/openssl/crypto/rand/drbg_lib.c
compiling lib/lib/openssl/crypto/rand/rand_err.c
compiling lib/lib/openssl/crypto/rand/rand_lib.c
compiling lib/lib/openssl/crypto/rsa/rsa_ameth.c
lib/lib/openssl/crypto/rsa/rsa_ameth.c: In function ‘pkey_rsa_print’:
lib/lib/openssl/crypto/rsa/rsa_ameth.c:338:13: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
str = "modulus:";
lib/lib/openssl/crypto/rsa/rsa_ameth.c:343:13: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
str = "Modulus:";
lib/lib/openssl/crypto/rsa/rsa_ameth.c: At top level:
lib/lib/openssl/crypto/rsa/rsa_ameth.c:1054:6: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"RSA",
lib/lib/openssl/crypto/rsa/rsa_ameth.c:1055:6: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"OpenSSL RSA method",
lib/lib/openssl/crypto/rsa/rsa_ameth.c:1094:6: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"RSA-PSS",
lib/lib/openssl/crypto/rsa/rsa_ameth.c:1095:6: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"OpenSSL RSA-PSS method",
compiling lib/lib/openssl/crypto/rsa/rsa_asn1.c
compiling lib/lib/openssl/crypto/rsa/rsa_chk.c
compiling lib/lib/openssl/crypto/rsa/rsa_crpt.c
compiling lib/lib/openssl/crypto/rsa/rsa_err.c
compiling lib/lib/openssl/crypto/rsa/rsa_gen.c
compiling lib/lib/openssl/crypto/rsa/rsa_lib.c
compiling lib/lib/openssl/crypto/rsa/rsa_meth.c
compiling lib/lib/openssl/crypto/rsa/rsa_mp.c
compiling lib/lib/openssl/crypto/rsa/rsa_none.c
compiling lib/lib/openssl/crypto/rsa/rsa_oaep.c
compiling lib/lib/openssl/crypto/rsa/rsa_ossl.c
lib/lib/openssl/crypto/rsa/rsa_ossl.c:28:5: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
"OpenSSL PKCS#1 RSA",
compiling lib/lib/openssl/crypto/rsa/rsa_pk1.c
compiling lib/lib/openssl/crypto/rsa/rsa_pmeth.c
compiling lib/lib/openssl/crypto/rsa/rsa_prn.c
compiling lib/lib/openssl/crypto/rsa/rsa_pss.c
compiling lib/lib/openssl/crypto/rsa/rsa_saos.c
compiling lib/lib/openssl/crypto/rsa/rsa_sign.c
compiling lib/lib/openssl/crypto/rsa/rsa_ssl.c
compiling lib/lib/openssl/crypto/rsa/rsa_x931.c
compiling lib/lib/openssl/crypto/rsa/rsa_x931g.c
compiling lib/lib/openssl/crypto/sha/sha1_one.c
compiling lib/lib/openssl/crypto/sha/sha1dgst.c
compiling lib/lib/openssl/crypto/sha/sha256.c
compiling lib/lib/openssl/crypto/sha/sha512.c
compiling lib/lib/openssl/crypto/stack/stack.c
compiling lib/lib/openssl/crypto/threads_none.c
compiling lib/lib/openssl/crypto/x509/t_x509.c
compiling lib/lib/openssl/crypto/x509/x509_set.c
compiling lib/lib/openssl/crypto/x509/x_all.c
compiling lib/lib/openssl/crypto/x509/x_attrib.c
compiling lib/lib/openssl/crypto/x509/x_pubkey.c
compiling lib/lib/openssl/crypto/x509v3/v3_utl.c
linking t194ref/build-t186/user_tasks/nvidia-sample/hwkey-agent/lib/lib/openssl.mod.o
generating t194ref/build-t186/user_tasks/nvidia-sample/hwkey-agent/lk/common/lib/libc/module_config.h
linking t194ref/build-t186/user_tasks/nvidia-sample/hwkey-agent/lk/common/lib/libc.mod.o
generating t194ref/build-t186/user_tasks/nvidia-sample/hwkey-agent/lib/lib/openssl-stubs/module_config.h
compiling lib/lib/openssl-stubs/bio.c
compiling lib/lib/openssl-stubs/rand.c
compiling lib/lib/openssl-stubs/sscanf.c
compiling lib/lib/openssl-stubs/strcasecmp.c
linking t194ref/build-t186/user_tasks/nvidia-sample/hwkey-agent/lib/lib/openssl-stubs.mod.o
generating t194ref/build-t186/user_tasks/nvidia-sample/hwkey-agent/lib/lib/rng/module_config.h
compiling lib/lib/rng/trusty_rng.c
linking t194ref/build-t186/user_tasks/nvidia-sample/hwkey-agent/lib/lib/rng.mod.o
generating t194ref/build-t186/user_tasks/nvidia-sample/hwkey-agent/user_task.ld
linking t194ref/build-t186/user_tasks/nvidia-sample/hwkey-agent/hwkey-agent.syms.elf
stripping t194ref/build-t186/user_tasks/nvidia-sample/hwkey-agent/hwkey-agent.syms.elf
generating t194ref/build-t186/user_tasks/nvidia-sample/luks-srv/app/nvidia-sample/luks-srv/module_config.h
compiling app/nvidia-sample/luks-srv/get_key_srv.c
compiling app/nvidia-sample/luks-srv/ipc.c
compiling app/nvidia-sample/luks-srv/key_mgnt.c
compiling app/nvidia-sample/luks-srv/luks_srv.c
compiling app/nvidia-sample/luks-srv/main.c
compiling app/nvidia-sample/luks-srv/manifest.c
linking t194ref/build-t186/user_tasks/nvidia-sample/luks-srv/app/nvidia-sample/luks-srv.mod.o
generating t194ref/build-t186/user_tasks/nvidia-sample/luks-srv/lib/lib/libc-trusty/module_config.h
linking t194ref/build-t186/user_tasks/nvidia-sample/luks-srv/lib/lib/libc-trusty.mod.o
generating t194ref/build-t186/user_tasks/nvidia-sample/luks-srv/lib/lib/openssl/module_config.h
sep_dn = "\n";
sep_mv = " + ";
sep_dn = ",";
sep_mv = "+";
sep_dn = ", ";
sep_mv = " + ";
sep_dn = "; ";
sep_mv = " + ";
sep_eq = " = ";
sep_eq = "=";
"asn1",
tname = "SET";
tname = "SEQUENCE";
"buffer",
"linebuffer",
"NULL filter",
"BIO pair",
"memory buffer",
"NULL",
"CMAC",
"DH",
"X9.42 DH",
"DSA",
"EC",
a = "<NULL>";
"base64 encoding",
"cipher",
"message digest",
"reliable",
"HMAC",
ts = gmtime(timer);
time
ts = gmtime(timer);
str = "modulus:";
str = "Modulus:";
"RSA",
"RSA-PSS",
linking t194ref/build-t186/user_tasks/nvidia-sample/luks-srv/lib/lib/openssl.mod.o
generating t194ref/build-t186/user_tasks/nvidia-sample/luks-srv/lk/common/lib/libc/module_config.h
linking t194ref/build-t186/user_tasks/nvidia-sample/luks-srv/lk/common/lib/libc.mod.o
generating t194ref/build-t186/user_tasks/nvidia-sample/luks-srv/lib/lib/openssl-stubs/module_config.h
linking t194ref/build-t186/user_tasks/nvidia-sample/luks-srv/lib/lib/openssl-stubs.mod.o
generating t194ref/build-t186/user_tasks/nvidia-sample/luks-srv/lib/lib/rng/module_config.h
linking t194ref/build-t186/user_tasks/nvidia-sample/luks-srv/lib/lib/rng.mod.o
generating t194ref/build-t186/user_tasks/nvidia-sample/luks-srv/user_task.ld
linking t194ref/build-t186/user_tasks/nvidia-sample/luks-srv/luks-srv.syms.elf
stripping t194ref/build-t186/user_tasks/nvidia-sample/luks-srv/luks-srv.syms.elf
combining tasks into t194ref/build-t186/user_tasks.bin: ./t194ref/build-t186/user_tasks/sample/ipc-unittest/main/main.elf ./t194ref/build-t186/user_tasks/sample/ipc-unittest/srv/srv.elf ./t194ref/build-t186/user_tasks/nvidia-sample/hwkey-agent/hwkey-agent.elf ./t194ref/build-t186/user_tasks/nvidia-sample/luks-srv/luks-srv.elf
generating t194ref/build-t186/user_tasks.o
generating t194ref/build-t186/system-onesegment.ld
compiling lk/trusty/lib/version/version.c
linking t194ref/build-t186/lk/trusty/lib/version.mod.o
linking t194ref/build-t186/lk.elf
text data bss dec hex filename
329 0 0 329 149 ./t194ref/build-t186/lk/common/app.mod.o
9898 12 41036 50946 c702 ./t194ref/build-t186/lk/common/arch/arm64.mod.o
1898 0 0 1898 76a ./t194ref/build-t186/lk/common/dev.mod.o
3950 932 16497 21379 5383 ./t194ref/build-t186/lk/common/dev/interrupt/arm_gic.mod.o
1949 0 48 1997 7cd ./t194ref/build-t186/lk/common/dev/timer/arm_generic.mod.o
9924 0 7056 16980 4254 ./t194ref/build-t186/lk/common/kernel.mod.o
5367 160 88 5615 15ef ./t194ref/build-t186/lk/common/kernel/vm.mod.o
2545 136 8 2689 a81 ./t194ref/build-t186/lk/common/lib/debug.mod.o
0 0 0 0 0 ./t194ref/build-t186/lk/common/lib/fixed_point.mod.o
2050 0 128 2178 882 ./t194ref/build-t186/lk/common/lib/heap.mod.o
11962 16 12 11990 2ed6 ./t194ref/build-t186/lk/common/lib/libc.mod.o
93 0 0 93 5d ./t194ref/build-t186/lk/common/platform.mod.o
16 0 0 16 10 ./t194ref/build-t186/lk/common/target.mod.o
1664 0 92 1756 6dc ./t194ref/build-t186/lk/common/top.mod.o
1367 40 20 1427 593 ./t194ref/build-t186/lk/trusty/lib/memlog.mod.o
5635 1884 554 8073 1f89 ./t194ref/build-t186/lk/trusty/lib/sm.mod.o
392 8 0 400 190 ./t194ref/build-t186/lk/trusty/lib/syscall.mod.o
36185 488 49 36722 8f72 ./t194ref/build-t186/lk/trusty/lib/trusty.mod.o
6792 0 28 6820 1aa4 ./t194ref/build-t186/lk/trusty/lib/uthread.mod.o
0 29 0 29 1d ./t194ref/build-t186/lk/trusty/lib/version.mod.o
32 0 0 32 20 ./t194ref/build-t186/tegra/public/lib/boot_profiler.mod.o
5011 408 100 5519 158f ./t194ref/build-t186/tegra/public/platform/t18x.mod.o
107059 4113 65716 176888 2b2f8 (TOTALS)
generating image: t194ref/build-t186/lk.bin
94584 213000 65832 373416 5b2a8 t194ref/build-t186/lk.elf
generating listing: t194ref/build-t186/lk.elf.lst
Unrecognised disassembler option: reg-names-raw
generating listing: t194ref/build-t186/lk.elf.debug.lst
generating symbols: t194ref/build-t186/lk.elf.sym
generating symbols: t194ref/build-t186/lk.elf.sym.sorted
generating size map: t194ref/build-t186/lk.elf.size
generating listing: t194ref/build-t186/user_tasks/sample/ipc-unittest/main/main.elf.lst
generating listing: t194ref/build-t186/user_tasks/sample/ipc-unittest/main/main.elf.debug.lst
generating listing: t194ref/build-t186/user_tasks/sample/ipc-unittest/srv/srv.elf.lst
generating listing: t194ref/build-t186/user_tasks/sample/ipc-unittest/srv/srv.elf.debug.lst
generating listing: t194ref/build-t186/user_tasks/nvidia-sample/hwkey-agent/hwkey-agent.elf.lst
generating listing: t194ref/build-t186/user_tasks/nvidia-sample/hwkey-agent/hwkey-agent.elf.debug.lst
generating listing: t194ref/build-t186/user_tasks/nvidia-sample/luks-srv/luks-srv.elf.lst
generating listing: t194ref/build-t186/user_tasks/nvidia-sample/luks-srv/luks-srv.elf.debug.lst
make[2]: Leaving directory '/home/carol/Desktop/JEP/Image/TX2+Xavier_R32.5.1_Build/Linux_for_Tegra/source/public/atf_and_trusty/trusty/trusty'
