Problem with cufft
I encounter several problems when I use cufft. Below is my code:
-----------------------CODE BEGIN----------------------------------------------
#include <stdio.h>
#include <math.h>
#include <stdint.h>
#include <cufft.h>
#include <cutil.h>
#define MallocD(pointer, size)
do{CUDA_SAFE_CALL( cudaMalloc((void**)&pointer, size));} while(0)
#define FreeD(pointer)
do{CUDA_SAFE_CALL( cudaFree(pointer));}while(0)
#define MemcpyH2D(d_dst, h_src, size)
do{CUDA_SAFE_CALL(cudaMemcpy((void*)d_dst, (void*)h_src, size,cudaMemcpyHostToDevice));}while(0)
#define MemcpyD2H(h_dst, d_src, size)
do{CUDA_SAFE_CALL(cudaMemcpy((void*)h_dst, (void*)d_src, size,cudaMemcpyDeviceToHost));}while(0)
const uint32_t N=8192;
const uint32_t NBATCH=256;
void
gpufft_test()
CUT_DEVICE_INIT(1, 0);
float *d_idata;
float *h_idata;
MallocD(d_idata, NNBATCHsizeof(float));
h_idata=(float*)malloc(NNBATCHsizeof(float));
for(int k=0; k<NBATCH; ++k)
for(int i=0; i<N; ++i)
h_idata[k*N+i]=sqrtf((float)i)*0.0001f;
MemcpyH2D(d_idata, h_idata, NNBATCHsizeof(float));
cufftHandle plan;
cufftPlan1d(&plan, N/2, CUFFT_C2C, NBATCH);
cufftExecC2C(plan, (cufftComplex*)d_idata,
(cufftComplex*)d_idata, CUFFT_INVERSE);
MemcpyD2H(h_idata, d_idata, NNBATCHsizeof(float));
float h_k=h_idata+kN;
if(h_k[i]!=h_idata[i])
printf(“#%d: h_idata(%d) = %f, h_k(%d)=%f\n”,
k, i, h_idata[i],i, h_k[i]);
break;
FreeD(d_idata);
free(h_idata);
cufftDestroy(plan);
return;
int
main()
gpufft_test();
--------------------CODE END----------------------------
Environment Details:
Linux 2.6.18 x86_64bit.
toolkit v2.3
SDK v2.3
Card M1060
When NBATCH is less than 32, no error after running many times; when NBATCH becomes bigger, .e.g., 128, error occurs after running a few times !
Any suggestions are appreciated.
Thank you!
