Problem with NVIDIA-AI-IOT/deepstream_lpr_app
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 5.0.1
• TensorRT Version 7.0.0-1
• NVIDIA GPU Driver Version (valid for GPU only) 450.102.04
• Issue Type( questions, new requirements, bugs) bugs
/home/tlt-converter-7.0-cuda10.2-x86/tlt-converter -k nvidia_tlt -p image_input,1x3x48x96,4x3x48x96,16x3x48x96 ./us_lprnet_baseline18_deployable.etlt
/home/tlt-converter-7.0-cuda10.2-x86/tlt-converter: invalid option -- 'p'
Unrecognized argument
Aborted (core dumped)
/home/tlt-converter-7.0-cuda10.2-x86/tlt-converter -k nvidia_tlt -d image_input,1x3x48x96,4x3x48x96,16x3x48x96 ./us_lprnet_baseline18_deployable.etlt
terminate called after throwing an instance of 'std::invalid_argument'
  what():  stoi
/home/tlt-converter-7.0-cuda10.2-x86/tlt-converter -k nvidia_tlt -d 1x3x48x96,4x3x48x96,16x3x48x96 ./us_lprnet_baseline18_deployable.etlt
[ERROR] UffParser: Could not parse MetaGraph from /tmp/fileDCLZQ2
[ERROR] Failed to parse the model, please check the encoding key to make sure it's correct
[ERROR] Network must have at least one output
[ERROR] Network validation failed.
[ERROR] Unable to create engine
Hello, I am trying to reproduce the work exposed in GitHub deepstream_lpr_app, however when I try to reproduce the step of using tlt-converter, I get the errors previously exposed, what am I doing wrong, according to me I follow the tutorial to the letter, with the exception that in the page it is specified to use ./tlt-converter … -p …, however that option does not exist, and I use ./tlt-converter … -d …, Help.
extra tip: I only use the -p and -k options, which are the required flags, in addition to the input model file.
Where did you download tlt-converter?
From here Tlt-converter
It is available for download from the tlt getting tarted,choose the one for cuda 10.2
A latest version of tlt-converter is needed. It can support “-p” option.
I’m still syncing with internal team for its release.
Sorry for confusion. Will update the info when I have.
Sorry for the inconvenience. We haven’t officially released TLT3.0. We will release it this week. Please stay tuned.
Thanks Morganh
Please download the latest tlt-converter according to your devices.
See https://developer.nvidia.com/tlt-getting-started
@Morganh can you please provide the link to the tlt converter. The link here: https://developer.nvidia.com/cuda102-trt71-jp44
Doesn’t work. Same issue with flag -p not recognized
./tlt-converter: invalid option -- 'p'
Please check again. There is no issue. It has “-p” option.
nvidia@nvidia:~/morganh/cuda10.2_trt7.1_jp4.4$ ./tlt-converter -h
usage: ./tlt-converter [-h] [-v] [-e ENGINE_FILE_PATH]
[-k ENCODE_KEY] [-c CACHE_FILE]
[-o OUTPUTS] [-d INPUT_DIMENSIONS]
[-b BATCH_SIZE] [-m MAX_BATCH_SIZE]
[-w MAX_WORKSPACE_SIZE] [-t DATA_TYPE]
[-i INPUT_ORDER] [-s] [-u DLA_CORE]
input_file
Generate TensorRT engine from exported model
positional arguments:
input_file Input file (.etlt exported model).
required flag arguments:
-d comma separated list of input dimensions(not required for TLT 3.0 new models).
-k model encoding key.
optional flag arguments:
-b calibration batch size (default 8).
-c calibration cache file (default cal.bin).
-e file the engine is saved to (default saved.engine).
-i input dimension ordering – nchw, nhwc, nc (default nchw).
-m maximum TensorRT engine batch size (default 16). If meet with out-of-memory issue, please decrease the batch size accordingly.
-o comma separated list of output node names (default none).
-p comma separated list of optimization profile shapes in the format <input_name>,<min_shape>,<opt_shape>,<max_shape>, where each shape has the format: xxx. Can be specified multiple times if there are multiple input tensors for the model. This argument is only useful in dynamic shape case.
-s TensorRT strict_type_constraints flag for INT8 mode(default false).
-t TensorRT data type – fp32, fp16, int8 (default fp32).
-u Use DLA core N for layers that support DLA(default = -1, which means no DLA core will be utilized for inference. Note that it’ll always allow GPU fallback).
-w maximum workspace size of TensorRT engine (default 1<<30). If meet with out-of-memory issue, please increase the workspace size accordingly.
Thanks a lot for getting back to me. I downloaded the the executable from the link I shared and I don’t see --p flag
@THdev-desktop:/opt/nvidia/deepstream/deepstream-5.0/samples/models/LP/LPR$ ./tlt-converter -h
	[-i INPUT_ORDER]
	input_file
  -i		input dimension ordering -- nchw, nhwc, nc (default nchw)
  -t		TensorRT data type -- fp32, fp16, int8 (default fp32)
I am assuming I am using the wrong executable.
Thanks again
Please check below step. I confirm it has “-p”.
In my Nano,
wget https://developer.nvidia.com/cuda102-trt71-jp44
unzip cuda102-trt71-jp44
cd cuda10.2_trt7.1_jp4.4
chmod +x tlt-converter
./tlt-converter -h
