Problem with receiving RTSP stream
Hi I need to be able to process ZT30 camera RTSP stream with opencv. For now I am trying to receive stream with any tools possible. On my PC I can just use ffplay rtsp://192.168.144.25:8554/video1. It works without any problems.
Same command on Jetson AGX Orin logs errors:
[rtsp @ 0xffff6c000ba0] RTP: missed 1 packets
[rtsp @ 0xffff6c000ba0] max delay reached. need to consume packet
[rtsp @ 0xffff6c000ba0] RTP: missed 11 packets
[rtsp @ 0xffff6c000ba0] RTP: missed 3 packets
[h264 @ 0xffff6c003f20] out of range intra chroma pred mode
[h264 @ 0xffff6c003f20] error while decoding MB 28 10
[h264 @ 0xffff6c003f20] concealing 6981 DC, 6981 AC, 6981 MV errors in I frame
[h264 @ 0xffff6c003f20] corrupted macroblock 18 7 (total_coeff=-1)
[h264 @ 0xffff6c003f20] error while decoding MB 18 7
[h264 @ 0xffff6c003f20] concealing 7351 DC, 7351 AC, 7351 MV errors in P frame
[rtsp @ 0xffff6c000ba0] RTP: missed 4 packets
[h264 @ 0xffff6c003f20] left block unavailable for requested intra mode
[h264 @ 0xffff6c003f20] error while decoding MB 0 16
[h264 @ 0xffff6c003f20] concealing 6289 DC, 6289 AC, 6289 MV errors in P frame
I tried several other options:
  • VLC just crashes
  • gstreamer drops logs and stuck, no video displayed.
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL ...
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://192.168.144.25:8554/video1
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (open) Opened Stream
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Progress: (request) Sending PLAY request
Progress: (request) Sent PLAY request
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
What is the problem? Is it a driver or decoder issue? Is it related with camera connection?
Please try like this:
deepstream4.0 deepstream-app cannot show the frame by rtsp - #8 by DaneLLL
And see if encoded JPEGs are good.
Thanks for reply.
I tried to run
$ export GST_DEBUG=*FACTORY*:4
$ gst-launch-1.0 rtspsrc location=rtsp://192.168.144.25:8554/video1 latency=0 ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv ! xvimagesink
Still no image:
0:00:00.012634620 16357 0xaaaacf275290 INFO 	GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "rtspsrc"
0:00:00.014128711 16357 0xaaaacf275290 INFO 	GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "rtspwms"
0:00:00.014650283 16357 0xaaaacf275290 INFO 	GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "rtspreal"
0:00:00.015398832 16357 0xaaaacf275290 INFO 	GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "rtph264depay"
0:00:00.015857108 16357 0xaaaacf275290 INFO 	GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "h264parse"
0:00:00.114720039 16357 0xaaaacf275290 INFO 	GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "nvv4l2decoder"
0:00:00.115978512 16357 0xaaaacf275290 INFO 	GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "nvvidconv"
0:00:00.116586677 16357 0xaaaacf275290 INFO 	GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "xvimagesink"
0:00:00.116768310 16357 0xaaaacf275290 INFO 	GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "pipeline"
Setting pipeline to PAUSED ...
0:00:00.408253707 16357 0xaaaacf4041e0 INFO 	GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "udpsrc"
0:00:00.408829551 16357 0xaaaacf4041e0 INFO 	GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "udpsrc"
0:00:00.417537679 16357 0xaaaacf4041e0 INFO 	GST_ELEMENT_FACTORY gstelementfactory.c:360:gst_element_factory_create: creating element "rtpbin" named "manager"
0:00:00.418297140 16357 0xaaaacf4041e0 INFO 	GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "rtpsession"
0:00:00.418913945 16357 0xaaaacf4041e0 INFO 	GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "rtpssrcdemux"
0:00:00.419072698 16357 0xaaaacf4041e0 INFO 	GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "rtpstorage"
0:00:00.420095809 16357 0xaaaacf4041e0 INFO 	GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "udpsink"
0:00:00.423214104 16357 0xaaaacf4041e0 INFO 	GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "fakesrc"
0:00:00.423428634 16357 0xaaaacf4041e0 INFO 	GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "udpsink"
0:00:00.650700825 16357 0xffff70018c00 INFO 	GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "rtpjitterbuffer"
0:00:00.650876378 16357 0xffff70018c00 INFO 	GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "rtpptdemux"
I am not very familiar with gstreamer so may be the flags are wrong.
If you run the command:
$ gst-launch-1.0 uridecodebin uri="rtsp://192.168.144.25:8554/video1" ! nvvideoconvert ! jpegenc ! multifilesink location=dump%05d.jpg
If the RTSP source is valid, it should have dumXXXXX.jpg files be saved.
I tried to run suggested command and got an issue with nvvideoconvert. On forum I found that it can be related with deepstream not installed or damaged.
I completely reinstalled the system to Jetpack 6.2 with deepstream 7.1. Suggested command does not generate an image. The output is:
Pipeline is PREROLLED ...
Prerolled, waiting for progress to finish...
Redistribute latency...
VLC and FFPLAY doesn’t work as well.
It looks to be an issue in the RTSP source. You may try to launch RTSP server throughtest-launch. See if this works. The reference steps are in
Jetson AGX Orin FAQ
I created local rtsp stream using test-launch. I can receive it with FFPLAY and gstreamer so driver is not a problem. Camera RTSP stream works on OrangePi 5, RaspberryPi 5, Ubuntu 22.04 and Windows 10 PCs so RTSP source definitely not a problem. I tried to use a USB-RJ45 adapter instead of JAO original Ethernet port and stream worked with no problem. So the problem is the JAO RJ45 port. Is it a software or hardware issue? Or my device is defective?
~0702
