Hi
I am currently working on extending/adapting the material creation capabilities of the replicator.create API for my use case and ran into an error I cannot quite track down.
I reused the code of replicator.create.material_omnipbr and added the required inputs to the shader to be able to randomize different material properties.
This all works fine, except for the attributes that require 2-dimensional input, like translate or scale.
When I try to randomize those I get a signature Error from the C++ binding of the Pxr.USD API in the replicator pipeline.
[/Replicator/SDGPipeline] Assertion raised in compute - Python argument types in
Vec2f.__init__(Vec2f, numpy.float32, numpy.float32)
did not match C++ signature:
__init__(_object*, float, float)
__init__(_object*, float)
However to me this actually looks fine and I also do not know how to further track down what is causing this error, so any help would be appreciated.
Below is the Code I am using:
- Material Creation
@ReplicatorWrapper
def custom_material_create(
diffuse: Tuple[float] = None,
diffuse_texture: str = None,
roughness: float = None,
metallic: float = None,
semantics: List[Tuple[str, str]] = None,
count: int = 1,
) -> ReplicatorItem:
attribute_types = {
"diffuse_color_constant": "color3f",
"diffuse_texture": "token",
"reflection_roughness_constant": "float",
"metallic_constant": "float",
"texture_rotation": "float",
"texture_translate": "float2",
"texture_scale": "float2"
if not stage.GetPrimAtPath(REPLICATOR_SCOPE):
stage.DefinePrim(REPLICATOR_SCOPE, "Scope")
mdl = "OmniPBR.mdl"
mtl_name, _ = os.path.splitext(mdl)
if not stage.GetPrimAtPath(LOOKS_PATH):
stage.DefinePrim(LOOKS_PATH, "Scope")
prim_paths = []
for _ in range(count):
prim_path = omni.usd.get_stage_next_free_path(stage, f"{LOOKS_PATH}/{mdl.split('.')[0]}", False)
utils._create_material(mtl_url=mdl, mtl_name=mtl_name, mtl_path=prim_path)
shader = UsdShade.Shader(omni.usd.get_shader_from_material(stage.GetPrimAtPath(prim_path), True))
shader.CreateInput("diffuse_color_constant", Sdf.ValueTypeNames.Color3f)
shader.CreateInput("diffuse_texture", Sdf.ValueTypeNames.Asset)
shader.CreateInput("reflection_roughness_constant", Sdf.ValueTypeNames.Float)
shader.CreateInput("metallic_constant", Sdf.ValueTypeNames.Float)
shader.CreateInput("texture_rotate", Sdf.ValueTypeNames.Float)
shader.CreateInput("texture_translate", Sdf.ValueTypeNames.Float2)
shader.CreateInput("texture_scale", Sdf.ValueTypeNames.Float2)
prim_paths.append(prim_path)
material_group = group(prim_paths)
_set_attributes(
material_group,
attribute_types=attribute_types,
semantics=semantics,
diffuse_color_constant=diffuse,
diffuse_texture=diffuse_texture,
reflection_roughness_constant=roughness,
metallic_constant=metallic
return material_group.node
- Property randomization
with rep.new_layer("floor"):
mat = custom_material_create(diffuse=rep.distribution.uniform((0,0,0), (1,1,1)))
plane = rep.create.plane(scale=size, position=position, visible=True, material=mat)
def randomize_floormat():
with mat:
rep.modify.attribute("diffuse_texture", rep.distribution.choice(floor_textures))
rep.modify.attribute("texture_rotate", rep.distribution.uniform(texture_rotate["min"], texture_rotate["max"]))
rep.modify.attribute("reflection_roughness_constant", rep.distribution.normal(roughness["mean"], roughness["std"]))
rep.modify.attribute("texture_scale", rep.distribution.normal(texture_scale["mean"], texture_scale["std"]))
rep.modify.attribute("texture_translate", rep.distribution.uniform(texture_translate["min"], texture_translate["max"]))
return mat.node
rep.randomizer.register(randomize_floormat)
with rep.trigger.on_frame(interval=interval, rt_subframes=10):
rep.randomizer.randomize_floormat()
