Hi, I’m having problems compiling NetCDF-Fortran 4.2 on Mac OSX (10.6.8) using PGI compilers (12.10-0). The C package for NetCDF 4.2.1.1 seems to build fine. The configure script for the Fortran package runs okay, but I get the following error when I run make check:
Making check in f90
make check-am
make[2]: Nothing to be done for `check-am’.
Making check in fortran
make check-am
Making check in nf_test
make nf_test tst_f77_v2 ftst_vars ftst_vars2 ftst_vars3 ftst_vars4 ftst_vars5 ftst_vars6 ftst_types ftst_types2 ftst_types3 ftst_groups f90tst_vars tst_types tst_types2 f90tst_vars_vlen tst_f90_nc4 f90tst_grps f90tst_fill f90tst_fill2 f90tst_vars3 f90tst_vars4 f90tst_vars2 ftst_v2 ftest tst_f90
source=‘fortlib.c’ object=‘fortlib.o’ libtool=no
DEPDIR=.deps depmode=none /bin/sh …/depcomp
pgcc -DHAVE_CONFIG_H -I. -I… -I…/fortran -DpgiFortran -I/usr/local/netcdf/4.2.1.1-pgi/include -I/usr/local/include -Msignextend -c -o fortlib.o fortlib.c
/bin/sh …/libtool --tag=F77 --mode=link pgf77 -I…/fortran -I…/f90 -w -L/usr/local/netcdf/4.2.1.1-pgi/lib -L/usr/local/lib -o nf_test test_get.o test_put.o nf_error.o nf_test.o test_read.o test_write.o util.o fortlib.o …/fortran/libnetcdff.la -lnetcdf
libtool: link: pgf77 -I…/fortran -I…/f90 -w -o nf_test test_get.o test_put.o nf_error.o nf_test.o test_read.o test_write.o util.o fortlib.o -L/usr/local/netcdf/4.2.1.1-pgi/lib -L/usr/local/lib …/fortran/.libs/libnetcdff.a -L/usr/local/netcdf/4.2.1.1-gnu/lib /usr/local/netcdf/4.2.1.1-gnu/lib/libnetcdf.dylib /usr/local/lib/libhdf5_hl.dylib /usr/local/lib/libhdf5.dylib -lm -lz
ld: duplicate symbol _main in nf_test.o and /opt/pgi/osx86-64/12.10/lib/pgfmain.o
make[2]: *** [nf_test] Error 2
make[1]: *** [check-am] Error 2
make: *** [check-recursive] Error 1
For what it’s worth I get the same “ld: duplicate symbol _main in nf_test.o and /opt/pgi/osx86-64/12.10/lib/pgfmain.o” error when I try to build NetCDF 3.6.3 with my PGI compilers, so my guess is there’s some incompatibility between PGI 12.10 and NetCDF. I’ve already tried implementing the suggestions for building NetCDF 4.1.1 with PGI (http://www.pgroup.com/resources/netcdf/netcdf411_pgi2011.htm), but that didn’t solve my problems.
Does anyone out there have any insight that might help me solve my compilation problem? The NetCDF support list hasn’t seen this error before either, because they haven’t tested PGI compilers on OSX. Thanks in advance.
Jared
