Problems running the Live LLaVA Demo - 'sinkpad' should not be nullptr error
I have the same problem like this closed post:
[webrtc] new WebRTC peer connecting (127.0.0.1, peer_id=0)
ERROR:/opt/jetson-utils/codec/gstEncoder.cpp:876:static void gstEncoder::onWebsocketMessage(WebRTCPeer*, const char*, size_t, void*): ‘sinkpad’ should not be nullptr
Bail out! ERROR:/opt/jetson-utils/codec/gstEncoder.cpp:876:static void gstEncoder::onWebsocketMessage(WebRTCPeer*, const char*, size_t, void*): ‘sinkpad’ should not be nullptr
Fatal Python error: Aborted
Did somebody fix it and how?
I am using an usb camera. Maybe a lib mismatch.. I tried all steps in the above post
HI,
Please provide your command for us to review.
I just used the command from the tutorial:
jetson-containers run $(autotag nano_llm)
python3 -m nano_llm.agents.video_query --api=mlc
–model Efficient-Large-Model/VILA1.5-3b
–max-context-len 256
–max-new-tokens 32
–video-input /dev/video0
–video-output webrtc://@:8554/output
I tried rtp it does not crash anymore, but still no video. I do get text response from the video in the console.
I wonder, why nobody else has this problem. It’s a fresh installation, just followed the steps in the tutorial and an ordinary USB webcam.
Is it possible to enable some debug output?
We need full log to review.
Could you run the application again and provide the full log for us to review?
I am getting same error- jetsono nano- occurs when opening websocket connecton:
A man is sitting in a chair in a room.
19:01:44 | INFO | refresh rate: 0.36 FPS (2807.6 ms)
19:01:45 | INFO | 192.168.1.73 - - [17/Jun/2025 19:01:45] “GET / HTTP/1.1” 200 -
19:01:45 | ERROR | 192.168.1.73 - - [17/Jun/2025 19:01:45] SSL error occurred: [SSL: SSLV3_ALERT_CERTIFICATE_UNKNOWN] sslv3 alert certificate unknown (_ssl.c:2578)
19:01:46 | ERROR | 192.168.1.73 - - [17/Jun/2025 19:01:46] SSL error occurred: [SSL: SSLV3_ALERT_CERTIFICATE_UNKNOWN] sslv3 alert certificate unknown (_ssl.c:2578)
19:01:46 | INFO | 192.168.1.73 - - [17/Jun/2025 19:01:46] “GET /static/chat.css HTTP/1.1” 200 -
19:01:46 | INFO | 192.168.1.73 - - [17/Jun/2025 19:01:46] “GET /static/bootstrap.css HTTP/1.1” 200 -
19:01:46 | INFO | 192.168.1.73 - - [17/Jun/2025 19:01:46] “GET /static/select2.min.css HTTP/1.1” 200 -
19:01:46 | INFO | 192.168.1.73 - - [17/Jun/2025 19:01:46] “GET /static/webrtc.js HTTP/1.1” 304 -
19:01:46 | INFO | 192.168.1.73 - - [17/Jun/2025 19:01:46] “GET /static/rest.js HTTP/1.1” 304 -
19:01:46 | INFO | 192.168.1.73 - - [17/Jun/2025 19:01:46] “GET /static/debounce.js HTTP/1.1” 304 -
19:01:46 | INFO | 192.168.1.73 - - [17/Jun/2025 19:01:46] “GET /static/websocket.js HTTP/1.1” 304 -
19:01:46 | INFO | 192.168.1.73 - - [17/Jun/2025 19:01:46] “GET /static/jquery-3.6.3.min.js HTTP/1.1” 304 -
19:01:46 | INFO | 192.168.1.73 - - [17/Jun/2025 19:01:46] “GET /static/bootstrap.bundle.min.js HTTP/1.1” 304 -
19:01:46 | INFO | 192.168.1.73 - - [17/Jun/2025 19:01:46] “GET /static/select2.min.js HTTP/1.1” 304 -
19:01:46 | INFO | 192.168.1.73 - - [17/Jun/2025 19:01:46] “GET /static/favicon.ico HTTP/1.1” 200 -
19:01:46 | INFO | connection open
19:01:46 | INFO | new websocket connection from (‘192.168.1.73’, 65502)
19:01:46 | INFO | listening on websocket connection from (‘192.168.1.73’, 65502)
[webrtc] websocket /output – new connection opened by 192.168.1.73 (peer_id=0)
[webrtc] new WebRTC peer connecting (192.168.1.73, peer_id=0)
19:01:47 | ERROR | 192.168.1.73 - - [17/Jun/2025 19:01:47] SSL error occurred: [SSL: SSLV3_ALERT_CERTIFICATE_UNKNOWN] sslv3 alert certificate unknown (_ssl.c:2578)
Here is the log:
jetson-containers run $(autotag nano_llm) python3 -m nano_llm.agents.video_query --api=mlc --model Efficient-Large-Model/VILA1.5-3b --max-context-len 256 --max-new-tokens 32 --video-input /dev/video1 --video-output webrtc://@:8554/output
Namespace(packages=['nano_llm'], prefer=['local', 'registry', 'build'], disable=[''], user='dustynv', output='/tmp/autotag', quiet=False, verbose=False)
-- L4T_VERSION=36.4.3  JETPACK_VERSION=6.2  CUDA_VERSION=12.6
-- Finding compatible container image for ['nano_llm']
dustynv/nano_llm:r36.4.0
V4L2_DEVICES:  --device /dev/video1  --device /dev/video2
### DISPLAY environmental variable is already set: ":1"
localuser:root being added to access control list
### ARM64 architecture detected
### Jetson Detected
SYSTEM_ARCH=tegra-aarch64
+ docker run --runtime nvidia --env NVIDIA_DRIVER_CAPABILITIES=compute,utility,graphics -it --rm --network host --shm-size=8g --volume /tmp/argus_socket:/tmp/argus_socket --volume /etc/enctune.conf:/etc/enctune.conf --volume /etc/nv_tegra_release:/etc/nv_tegra_release --volume /tmp/nv_jetson_model:/tmp/nv_jetson_model --volume /var/run/dbus:/var/run/dbus --volume /var/run/avahi-daemon/socket:/var/run/avahi-daemon/socket --volume /var/run/docker.sock:/var/run/docker.sock --volume /ssd/jetson-containers/data:/data -v /etc/localtime:/etc/localtime:ro -v /etc/timezone:/etc/timezone:ro --device /dev/snd -e PULSE_SERVER=unix:/run/user/1000/pulse/native -v /run/user/1000/pulse:/run/user/1000/pulse --device /dev/bus/usb -e DISPLAY=:1 -v /tmp/.X11-unix/:/tmp/.X11-unix -v /tmp/.docker.xauth:/tmp/.docker.xauth -e XAUTHORITY=/tmp/.docker.xauth --device /dev/video1 --device /dev/video2 --device /dev/i2c-0 --device /dev/i2c-1 --device /dev/i2c-2 --device /dev/i2c-4 --device /dev/i2c-5 --device /dev/i2c-7 --device /dev/i2c-9 --name jetson_container_20250618_213716 dustynv/nano_llm:r36.4.0 python3 -m nano_llm.agents.video_query --api=mlc --model Efficient-Large-Model/VILA1.5-3b --max-context-len 256 --max-new-tokens 32 --video-input /dev/video1 --video-output webrtc://@:8554/output
/usr/local/lib/python3.10/dist-packages/transformers/utils/hub.py:124: FutureWarning: Using `TRANSFORMERS_CACHE` is deprecated and will be removed in v5 of Transformers. Use `HF_HOME` instead.
  warnings.warn(
/usr/local/lib/python3.10/dist-packages/huggingface_hub/file_download.py:1142: FutureWarning: `resume_download` is deprecated and will be removed in version 1.0.0. Downloads always resume when possible. If you want to force a new download, use `force_download=True`.
  warnings.warn(
Fetching 13 files: 100%|██████████████████████████████████████████████████████████████████████████████████████| 13/13 [00:00<00:00, 61059.30it/s]
Fetching 17 files: 100%|██████████████████████████████████████████████████████████████████████████████████████| 17/17 [00:00<00:00, 26023.05it/s]
21:37:33 | INFO | loading /data/models/huggingface/models--Efficient-Large-Model--VILA1.5-3b/snapshots/42d1dda6807cc521ef27674ca2ae157539d17026 with MLC
21:37:38 | INFO | NumExpr defaulting to 6 threads.
21:37:39 | WARNING | AWQ not installed (requires JetPack 6 / L4T R36) - AWQ models will fail to initialize
21:37:40 | INFO | patching model config with {'model_type': 'llama'}
21:37:42 | INFO | device=cuda(0), name=Orin, compute=8.7, max_clocks=1020000, multiprocessors=8, max_thread_dims=[1024, 1024, 64], api_version=12060, driver_version=None
21:37:42 | INFO | loading VILA1.5-3b from /data/models/mlc/dist/VILA1.5-3b/ctx256/VILA1.5-3b-q4f16_ft/VILA1.5-3b-q4f16_ft-cuda.so
21:37:42 | WARNING | model library /data/models/mlc/dist/VILA1.5-3b/ctx256/VILA1.5-3b-q4f16_ft/VILA1.5-3b-q4f16_ft-cuda.so was missing metadata
21:37:43 | INFO | loading siglip vision model /data/models/huggingface/models--Efficient-Large-Model--VILA1.5-3b/snapshots/42d1dda6807cc521ef27674ca2ae157539d17026/vision_tower
21:37:48 | WARNING | disabling CLIP with TensorRT due to limited memory (falling back to Transformers API)
21:37:48 | INFO | loaded siglip vision model /data/models/huggingface/models--Efficient-Large-Model--VILA1.5-3b/snapshots/42d1dda6807cc521ef27674ca2ae157539d17026/vision_tower
21:37:48 | INFO | mm_projector (mlp_downsample)  Sequential(
  (0): DownSampleBlock()
  (1): LayerNorm((4608,), eps=1e-05, elementwise_affine=True)
  (2): Linear(in_features=4608, out_features=2560, bias=True)
  (3): GELU(approximate='none')
  (4): Linear(in_features=2560, out_features=2560, bias=True)
21:37:48 | INFO | mm_projector weights:  dict_keys(['1.bias', '1.weight', '2.bias', '2.weight', '4.bias', '4.weight'])
│ _name_or_path              │ ./llm        │
│ architectures              │ ['LlamaForCausalLM']                                                        │
│ drop_path_rate             │ 0.0        │
│ hidden_size                │ 2560        │
│ image_aspect_ratio         │ resize        │
│ interpolate_mode           │ linear        │
│ mm_hidden_size             │ 1152        │
│ mm_projector_lr            │        │
│ mm_use_im_patch_token      │ False        │
│ mm_use_im_start_end        │ False        │
│ mm_vision_select_feature   │ cls_patch        │
│ mm_vision_select_layer     │ -2        │
│ model_dtype                │ torch.bfloat16                                                              │
│ model_type                 │ llama        │
│ num_video_frames           │ 8        │
│ resume_path                │ ./vlm        │
│ s2                         │ False        │
│ s2_max_split_size          │ 336        │
│ s2_scales                  │ 336,672,1008        │
│ transformers_version       │ 4.36.2        │
│ tune_language_model        │ True        │
│ tune_mm_projector          │ True        │
│ tune_vision_tower          │ True        │
│ vision_resolution          │ -1        │
│ name                       │ VILA1.5-3b        │
│ api                        │ mlc        │
│ max_position_embeddings    │ 4096        │
│ mm_vision_tower            │ /data/models/huggingface/models--Efficient-Large-Model--VILA1.5-3b/snapshot │
│ mm_projector_path          │ /data/models/huggingface/models--Efficient-Large-Model--VILA1.5-3b/snapshot │
│ mm_projector_type          │ mlp_downsample                                                              │
│ attention_bias             │ False        │
│ attention_dropout          │ 0.0        │
│ bos_token_id               │ 1        │
│ eos_token_id               │ 2        │
│ hidden_act                 │ silu        │
│ initializer_range          │ 0.02        │
│ intermediate_size          │ 6912        │
│ model_max_length           │ 4096        │
│ num_attention_heads        │ 20        │
│ num_hidden_layers          │ 32        │
│ num_key_value_heads        │ 20        │
│ pad_token_id               │ 0        │
│ pretraining_tp             │ 1        │
│ rms_norm_eps               │ 1e-05        │
│ rope_scaling               │        │
│ rope_theta                 │ 10000.0        │
│ tie_word_embeddings        │ False        │
│ tokenizer_model_max_length │ 4096        │
│ tokenizer_padding_side     │ right        │
│ torch_dtype                │ bfloat16        │
│ use_cache                  │ True        │
│ vocab_size                 │ 32000        │
│ quant                      │ q4f16_ft        │
│ type                       │ llama        │
│ max_length                 │ 256        │
│ prefill_chunk_size         │ -1        │
│ load_time                  │ 14.92252376800002                                                           │
│ params_size                │ 1300.8330078125                                                             │
21:37:48 | INFO | using chat template 'vicuna-v1' for model VILA1.5-3b
21:37:48 | INFO | model 'VILA1.5-3b', chat template 'vicuna-v1' stop tokens:  ['</s>'] -> [2]
21:37:48 | INFO | Warming up LLM with query 'What is 2+2?'
21:37:49 | INFO | Warmup response:  '4</s>'
21:37:49 | INFO | plugin | connected PrintStream to on_text on channel 0
21:37:49 | INFO | plugin | connected ChatQuery to PrintStream on channel 0
huggingface/tokenizers: The current process just got forked, after parallelism has already been used. Disabling parallelism to avoid deadlocks...
To disable this warning, you can either:
	- Avoid using `tokenizers` before the fork if possible
	- Explicitly set the environment variable TOKENIZERS_PARALLELISM=(true | false)
(gst-plugin-scanner:73): GLib-GObject-WARNING **: 21:37:51.179: cannot register existing type 'GstRtpSrc'
(gst-plugin-scanner:73): GLib-GObject-CRITICAL **: 21:37:51.179: g_type_add_interface_static: assertion 'G_TYPE_IS_INSTANTIATABLE (instance_type)' failed
(gst-plugin-scanner:73): GLib-CRITICAL **: 21:37:51.179: g_once_init_leave: assertion 'result != 0' failed
(gst-plugin-scanner:73): GStreamer-CRITICAL **: 21:37:51.180: gst_element_register: assertion 'g_type_is_a (type, GST_TYPE_ELEMENT)' failed
(gst-plugin-scanner:73): GLib-GObject-WARNING **: 21:37:51.180: cannot register existing type 'GstRtpSink'
(gst-plugin-scanner:73): GLib-GObject-CRITICAL **: 21:37:51.180: g_type_add_interface_static: assertion 'G_TYPE_IS_INSTANTIATABLE (instance_type)' failed
(gst-plugin-scanner:73): GLib-CRITICAL **: 21:37:51.180: g_once_init_leave: assertion 'result != 0' failed
sh: 1: lsmod: not found
sh: 1: modprobe: not found
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 277)
(Argus) Error EndOfFile: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 350)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 366)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 379)
(Argus) Error EndOfFile: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error EndOfFile:  (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 92)
[gstreamer] initialized gstreamer, version 1.20.3.0
[gstreamer] gstCamera -- attempting to create device v4l2:///dev/video1
[gstreamer] gstCamera -- found v4l2 device: Logitech StreamCam
[gstreamer] v4l2-proplist, device.path=(string)/dev/video1, udev-probed=(boolean)false, device.api=(string)v4l2, v4l2.device.driver=(string)uvcvideo, v4l2.device.card=(string)"Logitech\ StreamCam", v4l2.device.bus_info=(string)usb-3610000.usb-2.4, v4l2.device.version=(uint)331668, v4l2.device.capabilities=(uint)2225078273, v4l2.device.device_caps=(uint)69206017;
[gstreamer] gstCamera -- found 20 caps for v4l2 device /dev/video1
[gstreamer] [0] video/x-raw, format=(string)YUY2, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)5/1;
[gstreamer] [1] video/x-raw, format=(string)YUY2, width=(int)1600, height=(int)896, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/2, 5/1 };
[gstreamer] [2] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 15/2, 5/1 };
[gstreamer] [3] video/x-raw, format=(string)YUY2, width=(int)960, height=(int)540, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/1, 10/1, 15/2, 5/1 };
[gstreamer] [4] video/x-raw, format=(string)YUY2, width=(int)848, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[gstreamer] [5] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[gstreamer] [6] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[gstreamer] [7] video/x-raw, format=(string)YUY2, width=(int)424, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[gstreamer] [8] video/x-raw, format=(string)YUY2, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[gstreamer] [9] video/x-raw, format=(string)YUY2, width=(int)176, height=(int)144, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[gstreamer] [10] image/jpeg, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[gstreamer] [11] image/jpeg, width=(int)1600, height=(int)896, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[gstreamer] [12] image/jpeg, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[gstreamer] [13] image/jpeg, width=(int)960, height=(int)540, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[gstreamer] [14] image/jpeg, width=(int)848, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[gstreamer] [15] image/jpeg, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[gstreamer] [16] image/jpeg, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[gstreamer] [17] image/jpeg, width=(int)424, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[gstreamer] [18] image/jpeg, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[gstreamer] [19] image/jpeg, width=(int)176, height=(int)144, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[gstreamer] gstCamera -- selected device profile:  codec=MJPEG format=unknown width=1280 height=720 framerate=30
[gstreamer] gstCamera pipeline string:
[gstreamer] v4l2src device=/dev/video1 do-timestamp=true ! image/jpeg, width=(int)1280, height=(int)720, framerate=30/1 ! jpegdec name=decoder ! video/x-raw ! appsink name=mysink sync=false
[gstreamer] gstCamera successfully created device v4l2:///dev/video1
[video]  created gstCamera from v4l2:///dev/video1
gstCamera video options:
  -- URI: v4l2:///dev/video1
     - protocol:  v4l2
     - port:      1
  -- deviceType: v4l2
  -- ioType:     input
  -- codec:      MJPEG
  -- codecType:  cpu
  -- width:      1280
  -- height:     720
  -- frameRate:  30
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- sslCert     /etc/ssl/private/localhost.cert.pem
  -- sslKey      /etc/ssl/private/localhost.key.pem
[gstreamer] gstEncoder -- codec not specified, defaulting to H.264
failed to find/open file /proc/device-tree/model
[gstreamer] gstEncoder -- detected board 'NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super'
[gstreamer] gstEncoder -- hardware encoder not detected, reverting to CPU encoder
[gstreamer] gstEncoder -- pipeline launch string:
[gstreamer] appsrc name=mysource is-live=true do-timestamp=true format=3 ! x264enc name=encoder bitrate=4000 speed-preset=ultrafast tune=zerolatency key-int-max=30 insert-vui=1 ! video/x-h264 ! rtph264pay config-interval=1 ! application/x-rtp,media=video,encoding-name=H264,clock-rate=90000,payload=96 ! tee name=videotee ! queue ! fakesink
[webrtc] WebRTC server started @ https://nano:8554
[webrtc] WebRTC server thread running...
[webrtc] websocket route added /output
[video]  created gstEncoder from webrtc://@:8554/output
gstEncoder video options:
  -- URI: webrtc://@:8554/output
     - protocol:  webrtc
     - port:      8554
  -- deviceType: ip
  -- ioType:     output
  -- codec:      H264
  -- codecType:  cpu
  -- frameRate:  30
  -- bitRate:    4000000
  -- numBuffers: 4
  -- zeroCopy:   true
  -- latency     10
21:37:53 | INFO | plugin | connected VideoSource to on_video on channel 0
21:37:53 | INFO | mounting webserver path /data/datasets/uploads to /images/uploads
[gstreamer] opening gstCamera for streaming, transitioning pipeline to GST_STATE_PLAYING
21:37:53 | INFO | starting webserver @ https://0.0.0.0:8050
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> decoder
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> v4l2src0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> decoder
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> v4l2src0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer message new-clock ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> decoder
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> v4l2src0
21:37:53 | SUCCESS | VideoQuery - system ready
 * Serving Flask app 'nano_llm.web.server'
 * Debug mode: on
21:37:53 | INFO | WARNING: This is a development server. Do not use it in a production deployment. Use a production WSGI server instead.
 * Running on all addresses (0.0.0.0)
 * Running on https://127.0.0.1:8050
 * Running on https://192.168.178.86:8050
21:37:53 | INFO | Press CTRL+C to quit
[gstreamer] gstreamer message stream-start ==> pipeline0
[gstreamer] gstCamera -- onPreroll
[gstreamer] gstBufferManager -- map buffer size was less than max size (1382400 vs 1382407)
[gstreamer] gstBufferManager recieve caps:  video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)jpeg, colorimetry=(string)1:4:0:0, framerate=(fraction)30/1
[gstreamer] gstBufferManager -- recieved first frame, codec=MJPEG format=i420 width=1280 height=720 size=1382407
[cuda]   allocated 4 ring buffers (1382407 bytes each, 5529628 bytes total)
[cuda]   allocated 4 ring buffers (8 bytes each, 32 bytes total)
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
[gstreamer] gstreamer message async-done ==> pipeline0
[gstreamer] gstreamer message latency ==> mysink
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysink
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline0
[cuda]   allocated 4 ring buffers (2764800 bytes each, 11059200 bytes total)
[cuda]   allocated 2 ring buffers (1382400 bytes each, 2764800 bytes total)
[gstreamer] gstEncoder -- starting pipeline, transitioning to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> fakesink0
[gstreamer] gstreamer changed state from NULL to READY ==> queue0
[gstreamer] gstreamer changed state from NULL to READY ==> videotee
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter3
[gstreamer] gstreamer changed state from NULL to READY ==> rtph264pay0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter2
[gstreamer] gstreamer changed state from NULL to READY ==> encoder
[gstreamer] gstreamer changed state from NULL to READY ==> mysource
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline1
[gstreamer] gstreamer changed state from READY to PAUSED ==> queue0
[gstreamer] gstreamer changed state from READY to PAUSED ==> videotee
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter3
[gstreamer] gstreamer changed state from READY to PAUSED ==> rtph264pay0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter2
[gstreamer] gstreamer changed state from READY to PAUSED ==> encoder
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysource
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline1
[gstreamer] gstreamer message new-clock ==> pipeline1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> queue0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videotee
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter3
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> rtph264pay0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter2
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> encoder
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysource
[gstreamer] gstEncoder -- new caps: video/x-raw, width=1280, height=720, format=(string)I420, framerate=30/1
[gstreamer] gstreamer message latency ==> encoder
[gstreamer] gstreamer message stream-start ==> pipeline1
[gstreamer] gstreamer fakesink0 taglist, encoder=(string)x264, encoder-version=(uint)163, maximum-bitrate=(uint)4096000, nominal-bitrate=(uint)4096000;
[gstreamer] gstreamer changed state from READY to PAUSED ==> fakesink0
[gstreamer] gstreamer message async-done ==> pipeline1
[gstreamer] gstreamer message latency ==> fakesink0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> fakesink0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline1
A white object is hanging from the ceiling.
21:37:57 | INFO | refresh rate:  0.73 FPS (1379.0 ms)
21:37:59 | INFO | refresh rate:  0.69 FPS (1455.4 ms)
21:38:00 | INFO | refresh rate:  0.69 FPS (1450.7 ms)
21:38:02 | INFO | refresh rate:  0.70 FPS (1422.5 ms)
21:38:03 | INFO | refresh rate:  0.69 FPS (1450.9 ms)
21:38:05 | INFO | refresh rate:  0.68 FPS (1477.4 ms)
21:38:06 | INFO | refresh rate:  0.68 FPS (1470.0 ms)
21:38:07 | INFO | refresh rate:  0.69 FPS (1448.5 ms)
21:38:09 | INFO | refresh rate:  0.69 FPS (1457.4 ms)
21:38:10 | INFO | refresh rate:  0.69 FPS (1439.7 ms)
21:38:12 | INFO | refresh rate:  0.68 FPS (1460.2 ms)
21:38:14 | INFO | refresh rate:  0.58 FPS (1726.3 ms)
21:38:15 | INFO | refresh rate:  0.70 FPS (1430.2 ms)
21:38:16 | INFO | refresh rate:  0.68 FPS (1472.3 ms)
21:38:17 | INFO | 127.0.0.1 - - [18/Jun/2025 21:38:17] "GET / HTTP/1.1" 200 -
21:38:17 | INFO | 127.0.0.1 - - [18/Jun/2025 21:38:17] "GET /static/select2.min.js HTTP/1.1" 200 -
21:38:17 | INFO | 127.0.0.1 - - [18/Jun/2025 21:38:17] "GET /static/select2.min.css HTTP/1.1" 200 -
21:38:17 | INFO | 127.0.0.1 - - [18/Jun/2025 21:38:17] "GET /static/chat.css HTTP/1.1" 200 -
21:38:17 | INFO | 127.0.0.1 - - [18/Jun/2025 21:38:17] "GET /static/bootstrap.css HTTP/1.1" 200 -
21:38:17 | INFO | 127.0.0.1 - - [18/Jun/2025 21:38:17] "GET /static/webrtc.js HTTP/1.1" 200 -
21:38:17 | INFO | 127.0.0.1 - - [18/Jun/2025 21:38:17] "GET /static/rest.js HTTP/1.1" 200 -
21:38:17 | INFO | 127.0.0.1 - - [18/Jun/2025 21:38:17] "GET /static/debounce.js HTTP/1.1" 200 -
21:38:17 | INFO | 127.0.0.1 - - [18/Jun/2025 21:38:17] "GET /static/websocket.js HTTP/1.1" 200 -
21:38:17 | INFO | 127.0.0.1 - - [18/Jun/2025 21:38:17] "GET /static/jquery-3.6.3.min.js HTTP/1.1" 200 -
21:38:17 | INFO | 127.0.0.1 - - [18/Jun/2025 21:38:17] "GET /static/bootstrap.bundle.min.js HTTP/1.1" 200 -
[webrtc] websocket /output -- new connection opened by 127.0.0.1 (peer_id=0)
21:38:18 | INFO | refresh rate:  0.56 FPS (1778.1 ms)
ERROR:/opt/jetson-utils/codec/gstEncoder.cpp:876:static void gstEncoder::onWebsocketMessage(WebRTCPeer*, const char*, size_t, void*): 'sinkpad' should not be nullptr
Bail out! ERROR:/opt/jetson-utils/codec/gstEncoder.cpp:876:static void gstEncoder::onWebsocketMessage(WebRTCPeer*, const char*, size_t, void*): 'sinkpad' should not be nullptr
Thread 0x0000ffff563df120 (most recent call first):
  File "/usr/lib/python3.10/ssl.py", line 1371 in do_handshake
  File "/usr/local/lib/python3.10/dist-packages/websockets/sync/server.py", line 509 in conn_handler
  File "/usr/lib/python3.10/threading.py", line 953 in run
  File "/usr/lib/python3.10/threading.py", line 1016 in _bootstrap_inner
  File "/usr/lib/python3.10/threading.py", line 973 in _bootstrap
Thread 0x0000ffff58bef120 (most recent call first):
  File "/usr/lib/python3.10/selectors.py", line 416 in select
  File "/usr/lib/python3.10/socketserver.py", line 232 in serve_forever
  File "/usr/local/lib/python3.10/dist-packages/werkzeug/serving.py", line 817 in serve_forever
  File "/usr/local/lib/python3.10/dist-packages/werkzeug/serving.py", line 1123 in run_simple
  File "/usr/local/lib/python3.10/dist-packages/flask/app.py", line 625 in run
  File "/opt/NanoLLM/nano_llm/web/server.py", line 120 in <lambda>
Thread 0x0000ffff5bc0f120 (most recent call first):
  File "/usr/lib/python3.10/selectors.py", line 469 in select
  File "/usr/local/lib/python3.10/dist-packages/websockets/sync/server.py", line 260 in serve_forever
  File "/opt/NanoLLM/nano_llm/web/server.py", line 119 in <lambda>
Thread 0x0000ffff69c8f120 (most recent call first):
  File "/opt/NanoLLM/nano_llm/plugins/video/video_source.py", line 109 in capture
  File "/opt/NanoLLM/nano_llm/plugins/video/video_source.py", line 159 in run
Thread 0x0000ffff6747f120 (most recent call first):
  File "/opt/NanoLLM/nano_llm/agents/video_query.py", line 313 in poll_keyboard
Thread 0x0000ffff64c6f120 (most recent call first):
  File "/usr/lib/python3.10/threading.py", line 324 in wait
  File "/usr/lib/python3.10/threading.py", line 607 in wait
  File "/opt/NanoLLM/nano_llm/plugin.py", line 335 in process_inputs
  File "/opt/NanoLLM/nano_llm/plugin.py", line 321 in run
Thread 0x0000fffe6d51f120 (most recent call first):
Thread 0x0000fffe6dd2f120 (most recent call first):
  File "/usr/lib/python3.10/threading.py", line 320 in wait
  File "/opt/NanoLLM/nano_llm/chat/stream.py", line 79 in __next__
  File "/opt/NanoLLM/nano_llm/plugins/chat_query.py", line 223 in process
  File "/opt/NanoLLM/nano_llm/plugins/chat_query.py", line 152 in process
  File "/opt/NanoLLM/nano_llm/plugin.py", line 361 in dispatch
  File "/opt/NanoLLM/nano_llm/plugin.py", line 348 in process_inputs
Thread 0x0000fffe9f6df120 (most recent call first):
  File "/opt/NanoLLM/nano_llm/models/mlc.py", line 436 in prefill
  File "/opt/NanoLLM/nano_llm/models/mlc.py", line 480 in _generate
  File "/opt/NanoLLM/nano_llm/models/mlc.py", line 538 in _run
Thread 0x0000ffff14f7f120 (most recent call first):
  File "/usr/local/lib/python3.10/dist-packages/tqdm/_monitor.py", line 60 in run
Thread 0x0000ffffbf6866c0 (most recent call first):
  File "/usr/lib/python3.10/threading.py", line 1116 in _wait_for_tstate_lock
  File "/usr/lib/python3.10/threading.py", line 1096 in join
  File "/opt/NanoLLM/nano_llm/agent.py", line 58 in run
  File "/opt/NanoLLM/nano_llm/agents/video_query.py", line 357 in <module>
  File "/usr/lib/python3.10/runpy.py", line 86 in _run_code
  File "/usr/lib/python3.10/runpy.py", line 196 in _run_module_as_main
Extension modules: numpy.core._multiarray_umath, numpy.core._multiarray_tests, numpy.linalg._umath_linalg, numpy.fft._pocketfft_internal, numpy.random._common, numpy.random.bit_generator, numpy.random._bounded_integers, numpy.random._mt19937, numpy.random.mtrand, numpy.random._philox, numpy.random._pcg64, numpy.random._sfc64, numpy.random._generator, torch._C, torch._C._fft, torch._C._linalg, torch._C._nested, torch._C._nn, torch._C._sparse, torch._C._special[gstreamer] gstreamer webrtcbin-0 ERROR Your GStreamer installation is missing a plug-in.
[gstreamer] gstreamer Debugging info: ../ext/webrtc/gstwebrtcbin.c(146): _have_nice_elements (): /GstPipeline:pipeline1/GstWebRTCBin:webrtcbin-0:
libnice elements are not available
, zstandard.backend_c, charset_normalizer.md21:38:18 | INFO | connection open
, yaml._yaml21:38:18 | INFO | new websocket connection from ('127.0.0.1', 48848)
21:38:18 | INFO | listening on websocket connection from ('127.0.0.1', 48848)
, sentencepiece._sentencepiece, psutil._psutil_linux, psutil._psutil_posix, PIL._imaging, PIL._imagingft, google.protobuf.pyext._message, jetson_utils_python, cuda._lib.utils, cuda._cuda.ccuda, cuda.ccuda, cuda.cuda, cuda._cuda.cnvrtc, cuda.cnvrtc, cuda.nvrtc, cuda._lib.ccudart.utils, cuda._lib.ccudart.ccudart, cuda.ccudart, cuda.cudart, _cffi_backend, pyaudio._portaudio, markupsafe._speedups, websockets.speedups, regex._regex, scipy._lib._ccallback_c, numba.core.typeconv._typeconv, numba._helperlib, numba._dynfunc, numba._dispatcher, numba.core.runtime._nrt_python, numba.np.ufunc._internal, numba.experimental.jitclass._box, h5py._errors, h5py.defs, h5py._objects, h5py.h5, h5py.utils, h5py.h5t, h5py.h5s, h5py.h5ac, h5py.h5p, h5py.h5r, h5py._proxy, h5py._conv, h5py.h5z, h5py.h5a, h5py.h5d, h5py.h5ds, h5py.h5g, h5py.h5i, h5py.h5f, h5py.h5fd, h5py.h5pl, h5py.h5o, h5py.h5l, h5py._selector, scipy.sparse._sparsetools, _csparsetools, scipy.sparse._csparsetools, scipy.linalg._fblas, scipy.linalg._flapack, scipy.linalg.cython_lapack, scipy.linalg._cythonized_array_utils, scipy.linalg._solve_toeplitz, scipy.linalg._flinalg, scipy.linalg._decomp_lu_cython, scipy.linalg._matfuncs_sqrtm_triu, scipy.linalg.cython_blas, scipy.linalg._matfuncs_expm, scipy.linalg._decomp_update, scipy.sparse.linalg._dsolve._superlu, scipy.sparse.linalg._eigen.arpack._arpack, scipy.sparse.csgraph._tools, scipy.sparse.csgraph._shortest_path, scipy.sparse.csgraph._traversal, scipy.sparse.csgraph._min_spanning_tree, scipy.sparse.csgraph._flow, scipy.sparse.csgraph._matching, scipy.sparse.csgraph._reordering, pyarrow.lib, pandas._libs.tslibs.ccalendar, pandas._libs.tslibs.np_datetime, pandas._libs.tslibs.dtypes, pandas._libs.tslibs.base, pandas._libs.tslibs.nattype, pandas._libs.tslibs.timezones, pandas._libs.tslibs.fields, pandas._libs.tslibs.timedeltas, pandas._libs.tslibs.tzconversion, pandas._libs.tslibs.timestamps, pandas._libs.properties, pandas._libs.tslibs.offsets, pandas._libs.tslibs.strptime, pandas._libs.tslibs.parsing, pandas._libs.tslibs.conversion, pandas._libs.tslibs.period, pandas._libs.tslibs.vectorized, pandas._libs.ops_dispatch, pandas._libs.missing, pandas._libs.hashtable, pandas._libs.algos, pandas._libs.interval, pandas._libs.lib, pyarrow._compute, pandas._libs.ops, numexpr.interpreter, pandas._libs.hashing, pandas._libs.arrays, pandas._libs.tslib, pandas._libs.sparse, pandas._libs.internals, pandas._libs.indexing, pandas._libs.index, pandas._libs.writers, pandas._libs.join, pandas._libs.window.aggregations, pandas._libs.window.indexers, pandas._libs.reshape, pandas._libs.groupby, pandas._libs.json21:38:18 | INFO | 127.0.0.1 - - [18/Jun/2025 21:38:18] "GET /static/favicon.ico HTTP/1.1" 200 -
, pandas._libs.parsers, pandas._libs.testing, tvm._ffi._cy3.core (total: 145)
Any ideas?
‘sinkpad’ should not be nullptr. That’s the error given if I turn on the webpage. If I use rtp it does not given an error but it does not work
Please try to replace --video-output webrtc://@:8554/output with --video-output display://0.
It might show on your display if monitor connected.
