Problems showing Allied Vision camera with Gstreamer / OpenCV
JetPack 4.6 (rev. 3)
Allied Vision 1800 C-319c camera
Camera is connected to the Jetson via “ADAPTER CSI-2 JETSON TX2 / XAVIER” board.
Using:
“gst-launch-1.0 nvarguscamerasrc ! nvoverlaysink”
I get the following error:
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:725 No cameras available
ls /dev/video* shows:
/dev/video0
and lsmod shows the driver is installed:
avt_csi2 92085 0
v4l2-ctl -d /dev/video0 --list-formats-ext shows:
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘TP31’
Name : 0x31 MIPI DATATYPE
Size: Discrete 2064x1544
Interval: Discrete 0.019s (51.968 fps)
Index       : 1
Pixel Format: 'GREY'
Name        : 8-bit Greyscale
Index       : 2
Pixel Format: 'RGGB'
Name        : 8-bit Bayer RGRG/GBGB
Index       : 3
Pixel Format: 'JXY0'
Name        : 10-bit/16-bit Greyscale
Index       : 4
Pixel Format: 'JXR0'
Name        : 10-bit/16-bit Bayer RGRG/GBGB
Index       : 5
Pixel Format: 'JXY2'
Name        : 12-bit/16-bit Greyscale
Index       : 6
Pixel Format: 'JXR2'
Name        : 12-bit/16-bit Bayer RGRG/GBGB
Index       : 7
Pixel Format: 'BX24'
Name        : 32-bit XRGB 8-8-8-8
Index       : 8
Pixel Format: 'XR24'
Name        : 32-bit BGRX 8-8-8-8
Index       : 9
Pixel Format: 'VYUY'
I tried using this longer command with edited resolution:
gst-launch-1.0 nvarguscamerasrc sensor_id=0 ! ‘video/x-raw(memory:NVMM),width=2064, height=1544, framerate=51/1’ ! nvvidconv flip-method=0 ! ‘video/x-raw,width=960, height=540’ ! nvvidconv ! nvegltransform ! nveglglessink -e
Output:
Setting pipeline to PAUSED …
Using winsys: x11
Pipeline is live and does not need PREROLL …
Got context from element ‘eglglessink0’: gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING …
New clock: GstSystemClock
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.049963076
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
My goal is to show the camera output using OpenCV so I’ve been looking at the JetsonHacks python script “simple_camera.py” but no luck.
Any help appriciated!
hello Aleks-CST,
please narrow down the issue by Applications Using V4L2 IOCTL Directly to verify basic functionality.
Hi Jerry, thanks for your reply.
Using:
v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --stream-mmap --stream-count=1 -d /dev/video0 --stream-to=ov5693.raw
I get a 0 byte file opening up with a text editor.
Changing the resolutions and format (I picked VYUY from the v4l2-ctl --list-formats-ext list), using:
v4l2-ctl --set-fmt-video=width=2064,height=1544,pixelformat=VYUY–stream-mmap --stream-count=1 -d /dev/video0 --stream-to=ov5693.raw
I get a 12.7 MB file but cannot open it with any media player.
Hope this makes sense
Regards
Aleks
Update:
Using:
v4l2-ctl --set-fmt-video=width=2064,height=1544,pixelformat=VYUY–stream-mmap --stream-count=1000 -d /dev/video0
gives the following output:
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 52.00 fps
hello Aleks-CST,
is this expect sensor outputs?
if yes, you cannot use nvarguscamerasrc plugin since it doesn’t support with YUV formats.
VYUY is a format I used for a different project with the same camera. I can choose JXR2 as well. I’m not sure how to set up a pipeline to use in VideoCapture using OpenCV.
Edit:
I’ve tried different “pixelformat=***” and no matter what I put, I get:
VIDIOC_S_FMT: failed: Invalid argument
<<<<<<<<<<<<<<<<<<<<<<<<<<<< 53.45 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<< 53.50 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<< 53.48 fps
hello Aleks-CST,
may I know what’s the sensor mode/formats reported by v4l utility.
for example, $ v4l2-ctl -d /dev/video0 --list-formats-ext
Index : 0
Index : 1
Pixel Format: ‘GREY’
Index : 2
Pixel Format: ‘RGGB’
Index : 3
Pixel Format: ‘JXY0’
Index : 4
Pixel Format: ‘JXR0’
Index : 5
Pixel Format: ‘JXY2’
Index : 6
Pixel Format: ‘JXR2’
Index : 7
Pixel Format: ‘BX24’
Index : 8
Pixel Format: ‘XR24’
Index : 9
Pixel Format: ‘VYUY’
The above output was copied from my original post where I provided the same info.
Printing the formats again today, I notice the Size and fps have changed… Not sure how this happened…
Output is now:
Size: Discrete 2048x1544
Interval: Discrete 0.019s (53.432 fps)
for all formats. I don’t really understand how this changed from yesterday.
-Aleks
Update:
The above values seem to change when I try to run:
That somehow changes the output of v4l2-ctl --list-formats-ext to
Size: Discrete 2048 x1544
Interval: Discrete 0.019s (53.432 fps )
It’s a bit confusing but not the biggest issue right now. I’m still not sure how I’d set up a pipeline that could work with OpenCV and VideoCapture.
VYUY is not supported in v4l2src You may try GREY. Please try to capture frame data in GREY8 through v4l2-ctl. If the frame data looks good, please try
gst-launch-1.0 v4l2src ! video/x-raw, format=GRAY8, width=2064, height=1544 ! videoconvert ! video/x-raw, format=I420 ! xvimagesink
And check if you can see camera preview.
Hi Dane, thanks for your reply!
A few formats that seem to work:
v4l2-ctl --set-fmt-video=width=2064,height=1544,pixelformat=BX24–stream-mmap -d /dev/video0
v4l2-ctl --set-fmt-video=width=2064,height=1544,pixelformat=BGRx–stream-mmap -d /dev/video0
v4l2-ctl --set-fmt-video=width=2064,height=1544,pixelformat=XR24–stream-mmap -d /dev/video0
pixelformat=GREY8 doesn’t work.
If I set pixelformat=GREY it works, but it lowers width to 2048 like I described above and I have to reload the driver before I can get back to 2064.
doesn’t work and gives me the following message:
Tried to capture at 2064x1544, but device returned size 2048x1544
When changing width to 2048 it works…!
v4l2src supports BGRx so please try
gst-launch-1.0 v4l2src ! video/x-raw, format=BGRx, width=2064, height=1544 ! videoconvert ! video/x-raw, format=I420 ! xvimagesink
If it works, you can apply this string:
v4l2src ! video/x-raw, format=BGRx, width=2064, height=1544 ! videoconvert ! video/x-raw, format=BGR ! appsink
to the sample and try:
V4l2src using OpenCV Gstreamer is not working in Jetson Xavier NX - #3 by DaneLLL
Hi again, it’s finally working. Thank you so much, I’ve been stuck with this problem for days…
The following code seems to be working, however, it’s running really really slowly on my Jetson, using Visual Studio Code. Any idea what could cause this?
import cv2
cap = cv2.VideoCapture("v4l2src device=/dev/video0 ! video/x-raw, format=BGRx, width=2064, height=1544 ! videoconvert ! video/x-raw, format=BGR ! appsink")
while True:
    ret_val, img = cap.read()
    cv2.imshow('v4l2-source',img)
    if cv2.waitKey(1) ==  ord('q'):
        break
cv2.destroyAllWindows()
Thanks for your help so far!
It takes significant CPU usage. Please execute sudo nvpmodel -m 0 and sudo jetson_clocks. To run CPU cores at maximum clock and try again.
That seemed to do the trick. Thank you!
