problems with include paths
I have problems finding include files that are defined in a makefile with pgcc under cygwin.
I installed pgWIN 8.0.1 on a WIN XP system with a already installed regular cygwin.
Is this o.k., or do I have to remove the regular Cygwin before PG installation?
Variables are defined via “export” in a sh script. All these are set properly.
The makefile has several includes in separate *.mk files that desribe directory paths.
These -Ipaths are extended properly, however pgcc complains not to find the include files albeit they they are in respective dirs
example
make: *** [miscmaths.o] Error 2
pgcpp -w -I/cygdrive/c/fslneu/extras/include/newmat -I/cygdrive/c/fslneu/src/miscmaths -I/cygdrive/c/fslneu/extras/include/libprob
-I/cygdrive/c/fslneu/extras/include/zlib -I. -I/cygdrive/c/fslneu/include -I/cygdrive/c/fslneu/include -c -o optimise.o optimise.cc
“c:\fslneu\src\miscmaths\optimise.h”, line 76: catastrophic error: could not
open source file “newmatap.h”
include “newmatap.h”
this is the makefile
include ${FSLCONFDIR}/default.mk
PROJNAME = miscmaths
USRINCFLAGS = -I${INC_NEWMAT} -I${INC_BOOST} -I${INC_PROB} -I${INC_ZLIB}
USRLDFLAGS = -L${LIB_NEWMAT} -L${LIB_PROB} -L${LIB_ZLIB}
OBJS = miscmaths.o optimise.o miscprob.o kernel.o histogram.o base2z.o t2z.o f2z.o volume.o volumeseries.o minimize.o cspline.o sparse_matrix.o sparsefn.o rungekutta.o nonlin.o bfmatrix.o
LIBS = -lutils -lfslio -lniftiio -lznz -lz -lnewmat -lprob -lm
all: libmiscmaths.a
quick:${OBJS} quick.o
${CXX} ${CXXFLAGS} ${LDFLAGS} -o $@ ${OBJS} quick.o ${LIBS}
libmiscmaths.a: ${OBJS}
${AR} -r libmiscmaths.a ${OBJS}
This is the code of default.mk file
Assumes that ${FSLDIR} is set as an environment variable
include ${FSLCONFDIR}/${FSLMACHTYPE}/systemvars.mk
include ${FSLCONFDIR}/${FSLMACHTYPE}/externallibs.mk
include ${FSLCONFDIR}/common/vars.mk
include ${FSLCONFDIR}/common/rules.mk
this is a snippet of a externallibs.mk file called
FSLEXTLIB=${FSLDIR}/extras/lib
FSLEXTINC=${FSLDIR}/extras/include
GD library
LIB_GD = ${FSLEXTLIB}
INC_GD = ${FSLEXTINC}/libgd
GDC library
LIB_GDC = ${FSLEXTLIB}
INC_GDC = ${FSLEXTINC}/libgdc
The same problem exists with libs and corresponding paths.
When I have the *.h files in the building dir they are found.
I would appreciate any help
a_bra
Hi a_bra,
This is fine. The compilers are Windows native (i.e. DOS) which can be run under Cygwin. However, since they are Windows native, you need to use DOS path names. So changing “/cygdrive/c/” to “C:\” should fix your issue.
Hope this helps,
Mat
Dear Mat
this seems to work thank you.
do we have C99 support? I remember that there is a undocumented switch (?)
I need the function isfinite()
Thank you
a_bra
Hi a_bra,
While the compiler is C99 compliant, Microsoft’s system math library is not. Hence, C99 math library functions such as “isinf” are not supported on Windows.
Sorry,
Mat
hi Mat
where can I find the latest pgi version for SUA?
thanks
a_bra
sorry I meant for sfu, if there is any real difference
Hi a_bra,
For our SUA/SFU compilers, please send a note to PGI Customer Service (trs@pgroup.com) and they should be able get you copy.
Note, that I believe the SFU libraries do support most C99 math functions including “isinf”,
  • Mat
