I’ve been hoping to try out the new install to NVME features of Jetpack 4.6 but have run into problems building the disk images it seems. I’m on Ubuntu 18.04 and have done a fresh download via SDK Manager of the Jetpack 4.6 for Xavier NX. This example is using the unmodified files, it has the same errors as when I change the config for my drive size, etc. I used this as one of the simplest examples from the readme.
~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash jetson-xavier internal
/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --no-flash jetson-xavier internal
* Step 1: Generate flash packages *
/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_create_images_for_kernel_flash.sh: line 410: odmsign_get_folder: command not found
Create folder to store images to flash
Generate images to be flashed
/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/flash.sh --no-flash --sign jetson-xavier internal
# L4T BSP Information:
# R32 , REVISION: 6.1
Board ID() version() sku() revision()
Copy /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb to /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb.rec
Generated UUID f9286e2e-891b-4d0d-b139-7c4530cf305b for mounting root APP partition.
copying bctfile(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p2888.cfg)... done.
copying bctfile1(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying uphy_config(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg)... done.
copying minratchet_config(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg)... done.
copying device_config(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-sdmmc.cfg)... done.
copying misc_cold_boot_config(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying misc_config(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg)... done.
copying gpioint_config(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg)... done.
copying pmic_config(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a01-p2822-0000.cfg)... done.
copying pmc_config(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg)... done.
copying prod_config(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg)... done.
copying scr_config(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying scr_cold_boot_config(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying bootrom_config(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg)... done.
copying dev_params(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-sdmmc.cfg)... done.
Existing bootloader(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
Making Boot image... done.
/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --cmd sign boot.img kernel
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0005 ] Generating signature
[ 0.0028 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0028 ] Assuming zero filled SBK key : not reading
[ 0.0027 ] Generating ratchet blob
[ 0.0046 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 0.0052 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0055 ]
[ 0.0056 ] header_magic: 414e4452
[ 0.0075 ] tegrahost_v2 --chip 0x19 --align 1_boot.img
[ 0.0083 ]
[ 0.0101 ] tegrahost_v2 --chip 0x19 0 --magicid KRNL --ratchet_blob ratchet_blob.bin --appendsigheader 1_boot.img zerosbk
[ 0.0107 ] adding BCH for 1_boot.img
[ 0.8488 ]
[ 0.8518 ] tegrasign_v3.py --key --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 0.8519 ] Assuming zero filled SBK key : not reading
[ 0.9357 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
[ 1.3788 ]
[ 1.4136 ] Signed file: /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x19: add 0x27cb800 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
done.
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra
30412 blocks
_BASE_KERNEL_VERSION=4.9.253-tegra
~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp/lib ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra
66117 blocks
Making Recovery image...
copying recdtbfile(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0.000379513 s, 52.7 kB/s
Existing sosfile(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
copying bpfdtbfile(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a01.dtb)... done.
Existing scefile(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
Existing spefile(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing wb0boot(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tos-trusty_t194.img) reused.
Existing eksfile(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/eks.img) reused.
copying soft_fuses(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
copying dtbfile(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --cmd sign kernel_tegra194-p2888-0001-p2822-0000.dtb kernel_dtb
version 1.0.0
[ 0.0027 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0054 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0054 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0054 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0054 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0054 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0054 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0054 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0054 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0054 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0054 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0054 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0054 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0054 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0055 ]
[ 0.0055 ] header_magic: d00dfeed
[ 0.0075 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0082 ]
[ 0.0101 ] tegrahost_v2 --chip 0x19 0 --magicid KDTB --ratchet_blob ratchet_blob.bin --appendsigheader 1_kernel_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[ 0.0107 ] adding BCH for 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0167 ]
[ 0.0196 ] tegrasign_v3.py --key --list 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0196 ] Assuming zero filled SBK key : not reading
[ 0.0246 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[ 0.0338 ]
[ 0.0347 ] Signed file: /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate header for kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: chip 0x19: add 0x45651 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
done.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating kernel_tegra194-p2888-0001-p2822-0000.dtb to rootfs... done.
Making system.img...
populating rootfs from /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/rootfs ... populating /boot/extlinux/extlinux.conf ... done.
generating sig file of Image ... /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --cmd sign ./boot/Image kernel
version 1.0.0
[ 0.0006 ] Generating signature
[ 0.0029 ] Assuming zero filled SBK key : not reading
[ 0.0028 ] Generating ratchet blob
[ 0.0050 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 0.0057 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0059 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0059 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0059 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0059 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0059 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0059 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0059 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0059 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0059 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0059 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0059 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0059 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0059 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0059 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0059 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0059 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0059 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0059 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0059 ]
[ 0.0060 ] header_magic: 405614
[ 0.0082 ] tegrahost_v2 --chip 0x19 --align 1_Image
[ 0.0090 ]
[ 0.0108 ] tegrahost_v2 --chip 0x19 0 --magicid KRNL --ratchet_blob ratchet_blob.bin --appendsigheader 1_Image zerosbk
[ 0.0115 ] adding BCH for 1_Image
[ 0.7011 ]
[ 0.7040 ] tegrasign_v3.py --key --list 1_Image_sigheader_list.xml --pubkeyhash pub_key.key
[ 0.7041 ] Assuming zero filled SBK key : not reading
[ 0.7870 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_Image_sigheader.encrypt 1_Image_sigheader.hash zerosbk
[ 1.1753 ]
[ 1.2002 ] Signed file: /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mnt/Image_sigheader.encrypt
l4t_sign_image.sh: Generate header for Image_sigheader.encrypt
l4t_sign_image.sh: chip 0x19: add 0x20e3008 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for Image_sigheader.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/Image.sig
done.
done.
generating sig file of kernel_tegra194-p2888-0001-p2822-0000.dtb ... /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --cmd sign ./boot/dtb/kernel_tegra194-p2888-0001-p2822-0000.dtb kernel_dtb
version 1.0.0
[ 0.0045 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 0.0051 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0053 ]
[ 0.0054 ] header_magic: d00dfeed
[ 0.0073 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0080 ]
[ 0.0099 ] tegrahost_v2 --chip 0x19 0 --magicid KDTB --ratchet_blob ratchet_blob.bin --appendsigheader 1_kernel_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[ 0.0104 ] adding BCH for 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0163 ]
[ 0.0192 ] tegrasign_v3.py --key --list 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0193 ] Assuming zero filled SBK key : not reading
[ 0.0243 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[ 0.0281 ]
[ 0.0286 ] Signed file: /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mnt/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/dtb/kernel_tegra194-p2888-0001-p2822-0000.dtb.sig
done.
done.
generating sig file of initrd ... /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --cmd sign ./boot/initrd data
version 1.0.0
[ 0.0027 ] Assuming zero filled SBK key : not reading
[ 0.0030 ] header_magic: 1f8b0800
[ 0.0049 ] tegrahost_v2 --chip 0x19 --align 1_initrd
[ 0.0057 ]
[ 0.0076 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_initrd zerosbk
[ 0.0082 ] adding BCH for 1_initrd
[ 0.1603 ]
[ 0.1633 ] tegrasign_v3.py --key --list 1_initrd_sigheader_list.xml --pubkeyhash pub_key.key
[ 0.1633 ] Assuming zero filled SBK key : not reading
[ 0.1817 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_initrd_sigheader.encrypt 1_initrd_sigheader.hash zerosbk
[ 0.2592 ]
[ 0.2645 ] Signed file: /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mnt/initrd_sigheader.encrypt
l4t_sign_image.sh: Generate header for initrd_sigheader.encrypt
l4t_sign_image.sh: chip 0x19: add 0x6e72c8 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for initrd_sigheader.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/initrd.sig
done.
done.
generating sig file of extlinux.conf ... /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --cmd sign ./boot/extlinux/extlinux.conf data
version 1.0.0
[ 0.0027 ] header_magic: 54494d45
[ 0.0046 ] tegrahost_v2 --chip 0x19 --align 1_extlinux.conf
[ 0.0053 ]
[ 0.0072 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_extlinux.conf zerosbk
[ 0.0078 ] adding BCH for 1_extlinux.conf
[ 0.0080 ]
[ 0.0107 ] tegrasign_v3.py --key --list 1_extlinux_sigheader.conf_list.xml --pubkeyhash pub_key.key
[ 0.0108 ] Assuming zero filled SBK key : not reading
[ 0.0146 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_extlinux_sigheader.conf.encrypt 1_extlinux_sigheader.conf.hash zerosbk
[ 0.0154 ]
[ 0.0156 ] Signed file: /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mnt/extlinux_sigheader.conf.encrypt
l4t_sign_image.sh: Generate header for extlinux_sigheader.conf.encrypt
l4t_sign_image.sh: chip 0x19: add 0x380 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for extlinux_sigheader.conf.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/extlinux/extlinux.conf.sig
done.
done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image... done.
system.img built successfully.
Existing tbcfile(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/cboot_t194.bin) reused.
copying tbcdtbfile(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
copying cfgfile(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t194_sdmmc.xml) to flash.xml... done.
Existing flasher(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --odmdata 0x9190000 --applet mb1_t194_prod.bin --cmd "sign" --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --chip 0x19 --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a01-p2822-0000.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --dev_params tegra194-br-bct-sdmmc.cfg --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a01.dtb; spe_fw spe_t194.bin; tlk tos-trusty_t194.img; eks eks.img; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb" --skipuid
saving flash command in /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/flash_win.bat
*** Sign and generate flashing ready partition images... ***
version 1.0.0
[ 0.0069 ] Using default ramcode: 0
[ 0.0069 ] Disable BPMP dtb trim, using default dtb
[ 0.0069 ]
[ 0.0090 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0091 ] Assuming zero filled SBK key
[ 0.0091 ] Generating RCM messages
[ 0.0109 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[ 0.0116 ] Header already present for mb1_t194_prod.bin
[ 0.0164 ]
[ 0.0186 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0187 ] Assuming zero filled SBK key
[ 0.0208 ] tegrasign_v3.py --file mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0209 ] Assuming zero filled SBK key
[ 0.0248 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[ 0.0281 ]
[ 0.0299 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.0308 ]
[ 0.0326 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 0.0333 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0334 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0334 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0334 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0334 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0334 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0335 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0335 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0335 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0335 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0335 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0335 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0335 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0335 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0335 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0335 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0335 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0335 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0335 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0335 ]
[ 0.0360 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[ 0.0366 ] RCM 0 is saved as rcm_0.rcm
[ 0.0409 ] RCM 1 is saved as rcm_1.rcm
[ 0.0410 ] RCM 2 is saved as rcm_2.rcm
[ 0.0411 ] List of rcm files are saved in rcm_list.xml
[ 0.0411 ]
[ 0.0411 ] Signing RCM messages
[ 0.0433 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0434 ] Assuming zero filled SBK key
[ 0.0499 ] Copying signature to RCM mesages
[ 0.0518 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0530 ]
[ 0.0530 ] Parsing partition layout
[ 0.0555 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0583 ]
[ 0.0583 ] Creating list of images to be signed
[ 0.0601 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[ 0.0607 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.0612 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.0616 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.0641 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.0647 ] adding BCH for spe_t194.bin
[ 0.0675 ] adding BCH for spe_t194.bin
[ 0.0694 ] adding BCH for nvtboot_t194.bin
[ 0.0718 ] adding BCH for nvtboot_t194.bin
[ 0.0753 ] Header already present for preboot_c10_prod_cr.bin
[ 0.0791 ] Header already present for preboot_c10_prod_cr.bin
[ 0.0793 ] Header already present for mce_c10_prod_cr.bin
[ 0.0801 ] Header already present for mce_c10_prod_cr.bin
[ 0.0816 ] adding BCH for mts_c10_prod_cr.bin
[ 0.0903 ] adding BCH for mts_c10_prod_cr.bin
[ 0.1587 ] adding BCH for cboot_t194.bin
[ 0.2264 ] adding BCH for cboot_t194.bin
[ 0.2355 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 0.2451 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 0.2508 ] adding BCH for tos-trusty_t194.img
[ 0.2574 ] adding BCH for tos-trusty_t194.img
[ 0.2654 ] adding BCH for eks.img
[ 0.2733 ] adding BCH for eks.img
[ 0.2735 ] adding BCH for bpmp_t194.bin
[ 0.2816 ] adding BCH for bpmp_t194.bin
[ 0.3059 ] adding BCH for tegra194-a02-bpmp-p2888-a01.dtb
[ 0.3258 ] adding BCH for tegra194-a02-bpmp-p2888-a01.dtb
[ 0.3457 ] adding BCH for xusb_sil_rel_fw
[ 0.3656 ] adding BCH for xusb_sil_rel_fw
[ 0.3682 ] adding BCH for camera-rtcpu-rce.img
[ 0.3763 ] adding BCH for camera-rtcpu-rce.img
[ 0.3864 ] adding BCH for adsp-fw.bin
[ 0.3945 ] adding BCH for adsp-fw.bin
[ 0.3964 ] Header already present for warmboot_t194_prod.bin
[ 0.3991 ] Header already present for warmboot_t194_prod.bin
[ 0.3999 ] adding BCH for recovery.img
[ 0.4819 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb.rec
[ 1.4459 ] adding BCH for boot.img
[ 1.4737 ] adding BCH for boot.img
[ 2.3103 ] adding BCH for kernel_tegra194-p2888-0001-p2822-0000.dtb
[ 3.1377 ] adding BCH for kernel_tegra194-p2888-0001-p2822-0000.dtb
[ 3.1483 ]
[ 3.1483 ] Filling MB1 storage info
[ 3.1483 ] Generating br-bct
[ 3.1504 ] Performing cfg overlay
[ 3.1504 ] ['tegra194-mb1-bct-memcfg-p2888.cfg', 'tegra194-memcfg-sw-override.cfg']
[ 3.1508 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1.cfg
[ 3.4442 ]
[ 3.4443 ] Updating dev and MSS params in BR BCT
[ 3.4444 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 3.5054 ]
[ 3.5054 ] Updating bl info
[ 3.5074 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 3.5092 ]
[ 3.5093 ] Generating signatures
[ 3.5114 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[ 3.5115 ] Assuming zero filled SBK key
[ 3.8781 ] Generating br-bct
[ 3.8801 ] Performing cfg overlay
[ 3.8802 ] ['/home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1.cfg']
[ 3.8802 ] Updating dev and MSS params in BR BCT
[ 3.8802 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 4.1195 ]
[ 4.1197 ] Updating bl info
[ 4.1236 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 4.1514 ]
[ 4.1515 ] Updating smd info
[ 4.1559 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 4.1594 ]
[ 4.1596 ] Updating Odmdata
[ 4.1634 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[ 4.1663 ]
[ 4.1664 ] Get Signed section of bct
[ 4.1701 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 4.1729 ]
[ 4.1766 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 4.1794 ] Assuming zero filled SBK key
[ 4.2881 ]
[ 4.2881 ] Updating BCT with signature
[ 4.2903 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[ 4.2913 ]
[ 4.2913 ] Generating coldboot mb1-bct
[ 4.2938 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a01-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.2945 ] MB1-BCT version: 0x1
[ 4.2947 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 4.2952 ] Added Platform Config 0 data with size :- 3008
[ 4.2970 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 4.2974 ] File read failed
[ 4.3022 ] File read failed
[ 4.3121 ] Added Platform Config 1 data with size :- 19640
[ 4.3124 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 4.3129 ] Added Platform Config 2 data with size :- 24
[ 4.3133 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a01-p2822-0000.cfg
[ 4.3139 ] File read failed
[ 4.3140 ] File read failed
[ 4.3141 ] Added Platform Config 4 data with size :- 380
[ 4.3145 ]
[ 4.3145 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 4.3146 ] Added Platform Config 3 data with size :- 92
[ 4.3146 ]
[ 4.3146 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 4.3146 ] Added Platform Config 5 data with size :- 68
[ 4.3146 ]
[ 4.3146 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 4.3146 ] Added Platform Config 7 data with size :- 392
[ 4.3146 ]
[ 4.3146 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 4.3146 ] Added Platform Config 8 data with size :- 12
[ 4.3146 ]
[ 4.3146 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.3146 ] Added Platform Config 9 data with size :- 32
[ 4.3146 ]
[ 4.3147 ] Updating mb1-bct with firmware information
[ 4.3170 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 4.3194 ] MB1-BCT version: 0x1
[ 4.3204 ]
[ 4.3205 ] Updating mb1-bct with storage information
[ 4.3243 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 4.3266 ] MB1-BCT version: 0x1
[ 4.3274 ]
[ 4.3275 ] Updating mb1-bct with ratchet information
[ 4.3312 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 4.3334 ] MB1-BCT version: 0x1
[ 4.3344 ] FwIndex: 1, MinRatchetLevel: 0
[ 4.3345 ] FwIndex: 2, MinRatchetLevel: 0
[ 4.3345 ] FwIndex: 3, MinRatchetLevel: 0
[ 4.3345 ] FwIndex: 4, MinRatchetLevel: 0
[ 4.3346 ] FwIndex: 5, MinRatchetLevel: 0
[ 4.3346 ] FwIndex: 6, MinRatchetLevel: 0
[ 4.3346 ] FwIndex: 7, MinRatchetLevel: 0
[ 4.3347 ] FwIndex: 11, MinRatchetLevel: 0
[ 4.3347 ] FwIndex: 12, MinRatchetLevel: 0
[ 4.3347 ] FwIndex: 13, MinRatchetLevel: 0
[ 4.3347 ] FwIndex: 14, MinRatchetLevel: 0
[ 4.3348 ] FwIndex: 15, MinRatchetLevel: 0
[ 4.3348 ] FwIndex: 16, MinRatchetLevel: 0
[ 4.3348 ] FwIndex: 17, MinRatchetLevel: 0
[ 4.3349 ] FwIndex: 18, MinRatchetLevel: 0
[ 4.3349 ] FwIndex: 19, MinRatchetLevel: 0
[ 4.3349 ] FwIndex: 30, MinRatchetLevel: 0
[ 4.3349 ] FwIndex: 31, MinRatchetLevel: 0
[ 4.3350 ] FwIndex: 32, MinRatchetLevel: 0
[ 4.3350 ]
[ 4.3387 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[ 4.3413 ]
[ 4.3457 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 4.3480 ] adding BCH for mb1_cold_boot_bct_MB1.bct
[ 4.3504 ]
[ 4.3554 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.3557 ] Assuming zero filled SBK key
[ 4.3671 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 4.3702 ]
[ 4.3704 ] Generating recovery mb1-bct
[ 4.3738 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a01-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.3755 ] MB1-BCT version: 0x1
[ 4.3761 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 4.3771 ] Added Platform Config 0 data with size :- 3008
[ 4.3798 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 4.3805 ] File read failed
[ 4.3885 ] File read failed
[ 4.4033 ] Added Platform Config 1 data with size :- 19640
[ 4.4038 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 4.4046 ] Added Platform Config 2 data with size :- 24
[ 4.4050 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a01-p2822-0000.cfg
[ 4.4054 ] File read failed
[ 4.4054 ] Added Platform Config 4 data with size :- 380
[ 4.4054 ]
[ 4.4054 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 4.4055 ] Added Platform Config 3 data with size :- 92
[ 4.4055 ]
[ 4.4055 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 4.4055 ] Added Platform Config 5 data with size :- 68
[ 4.4055 ]
[ 4.4055 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 4.4055 ] Added Platform Config 7 data with size :- 392
[ 4.4055 ]
[ 4.4055 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 4.4055 ] Added Platform Config 8 data with size :- 12
[ 4.4055 ]
[ 4.4055 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.4055 ] Added Platform Config 9 data with size :- 32
[ 4.4056 ]
[ 4.4056 ] Updating mb1-bct with firmware information
[ 4.4080 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 4.4088 ] MB1-BCT version: 0x1
[ 4.4091 ]
[ 4.4091 ] Updating mb1-bct with storage information
[ 4.4110 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 4.4119 ] MB1-BCT version: 0x1
[ 4.4122 ]
[ 4.4122 ] Updating mb1-bct with ratchet information
[ 4.4141 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 4.4148 ] MB1-BCT version: 0x1
[ 4.4151 ] FwIndex: 1, MinRatchetLevel: 0
[ 4.4151 ] FwIndex: 2, MinRatchetLevel: 0
[ 4.4151 ] FwIndex: 3, MinRatchetLevel: 0
[ 4.4151 ] FwIndex: 4, MinRatchetLevel: 0
[ 4.4151 ] FwIndex: 5, MinRatchetLevel: 0
[ 4.4151 ] FwIndex: 6, MinRatchetLevel: 0
[ 4.4151 ] FwIndex: 7, MinRatchetLevel: 0
[ 4.4151 ] FwIndex: 11, MinRatchetLevel: 0
[ 4.4151 ] FwIndex: 12, MinRatchetLevel: 0
[ 4.4151 ] FwIndex: 13, MinRatchetLevel: 0
[ 4.4152 ] FwIndex: 14, MinRatchetLevel: 0
[ 4.4152 ] FwIndex: 15, MinRatchetLevel: 0
[ 4.4152 ] FwIndex: 16, MinRatchetLevel: 0
[ 4.4152 ] FwIndex: 17, MinRatchetLevel: 0
[ 4.4152 ] FwIndex: 18, MinRatchetLevel: 0
[ 4.4152 ] FwIndex: 19, MinRatchetLevel: 0
[ 4.4152 ] FwIndex: 30, MinRatchetLevel: 0
[ 4.4152 ] FwIndex: 31, MinRatchetLevel: 0
[ 4.4152 ] FwIndex: 32, MinRatchetLevel: 0
[ 4.4152 ]
[ 4.4173 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[ 4.4197 ]
[ 4.4235 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1.bct zerosbk
[ 4.4257 ] adding BCH for mb1_bct_MB1.bct
[ 4.4280 ]
[ 4.4327 ] tegrasign_v3.py --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.4330 ] Assuming zero filled SBK key
[ 4.4455 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 4.4493 ]
[ 4.4497 ] Generating coldboot mem-bct
[ 4.4536 ] tegrabct_v2 --chip 0x19 0 --sdram /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1.cfg --membct /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1_1.bct /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1_2.bct /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1_3.bct /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1_4.bct
[ 4.4558 ] Packing sdram param for instance[0]
[ 4.5383 ] Packing sdram param for instance[1]
[ 4.5387 ] Packing sdram param for instance[2]
[ 4.5387 ] Packing sdram param for instance[3]
[ 4.5387 ] Packing sdram param for instance[4]
[ 4.5387 ] Packing sdram param for instance[5]
[ 4.5387 ] Packing sdram param for instance[6]
[ 4.5387 ] Packing sdram param for instance[7]
[ 4.5387 ] Packing sdram param for instance[8]
[ 4.5387 ] Packing sdram param for instance[9]
[ 4.5387 ] Packing sdram param for instance[10]
[ 4.5387 ] Packing sdram param for instance[11]
[ 4.5387 ] Packing sdram param for instance[12]
[ 4.5387 ] Packing sdram param for instance[13]
[ 4.5388 ] Packing sdram param for instance[14]
[ 4.5388 ] Packing sdram param for instance[15]
[ 4.5388 ]
[ 4.5388 ] Getting sector size from pt
[ 4.5409 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 4.5417 ]
[ 4.5417 ] BlockSize read from layout is 200
[ 4.5436 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1_1.bct /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1_2.bct /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1_3.bct /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1_4.bct
[ 4.5443 ] adding BCH for /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1_1.bct
[ 4.5465 ]
[ 4.5484 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[ 4.5493 ]
[ 4.5514 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot.bct zerosbk
[ 4.5522 ] Header already present for mem_coldboot.bct
[ 4.5526 ]
[ 4.5550 ] tegrasign_v3.py --key None --list mem_coldboot_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.5551 ] Assuming zero filled SBK key
[ 4.5596 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_sigheader.bct.encrypt mem_coldboot_sigheader.bct.hash zerosbk
[ 4.5606 ]
[ 4.5607 ] Generating recovery mem-bct
[ 4.5626 ] tegrabct_v2 --chip 0x19 0 --sdram /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1.cfg --membct /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1_1.bct /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1_2.bct /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1_3.bct /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/26248/tmp5caj9fjn1_4.bct
[ 4.5633 ] Packing sdram param for instance[0]
[ 4.6229 ] Packing sdram param for instance[1]
[ 4.6231 ] Packing sdram param for instance[2]
[ 4.6232 ] Packing sdram param for instance[3]
[ 4.6234 ] Packing sdram param for instance[4]
[ 4.6236 ] Packing sdram param for instance[5]
[ 4.6237 ] Packing sdram param for instance[6]
[ 4.6237 ] Packing sdram param for instance[7]
[ 4.6237 ] Packing sdram param for instance[8]
[ 4.6237 ] Packing sdram param for instance[9]
[ 4.6237 ] Packing sdram param for instance[10]
[ 4.6237 ] Packing sdram param for instance[11]
[ 4.6237 ] Packing sdram param for instance[12]
[ 4.6237 ] Packing sdram param for instance[13]
[ 4.6237 ] Packing sdram param for instance[14]
[ 4.6237 ] Packing sdram param for instance[15]
[ 4.6237 ]
[ 4.6259 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[ 4.6266 ]
[ 4.6285 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm.bct zerosbk
[ 4.6292 ] adding BCH for mem_rcm.bct
[ 4.6304 ]
[ 4.6327 ] tegrasign_v3.py --key None --list mem_rcm_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.6328 ] Assuming zero filled SBK key
[ 4.6370 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_sigheader.bct.encrypt mem_rcm_sigheader.bct.hash zerosbk
[ 4.6412 ]
[ 4.6415 ] Copying signatures
[ 4.6453 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 6.5448 ]
[ 6.5494 ] tegraparser_v2 --generategpt --pt flash.xml.bin
[ 6.5535 ]
[ 6.5602 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_t194.bin
[ 6.5632 ]
[ 6.5673 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader nvtboot_recovery_t194.bin zerosbk
[ 6.5697 ] adding BCH for nvtboot_recovery_t194.bin
[ 6.5857 ]
[ 6.5910 ] tegrasign_v3.py --key None --list nvtboot_recovery_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 6.5913 ] Assuming zero filled SBK key
[ 6.6040 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_t194_sigheader.bin.encrypt nvtboot_recovery_t194_sigheader.bin.hash zerosbk
[ 6.6146 ]
[ 6.6189 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr.bin
[ 6.6215 ]
[ 6.6251 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader preboot_c10_prod_cr.bin zerosbk
[ 6.6272 ] Header already present for preboot_c10_prod_cr.bin
[ 6.6283 ]
[ 6.6329 ] tegrasign_v3.py --key None --list preboot_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 6.6331 ] Assuming zero filled SBK key
[ 6.6447 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader.bin.encrypt preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[ 6.6477 ]
[ 6.6509 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr.bin
[ 6.6525 ]
[ 6.6554 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader mce_c10_prod_cr.bin zerosbk
[ 6.6571 ] Header already present for mce_c10_prod_cr.bin
[ 6.6606 ]
[ 6.6644 ] tegrasign_v3.py --key None --list mce_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 6.6645 ] Assuming zero filled SBK key
[ 6.6731 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader.bin.encrypt mce_c10_prod_cr_sigheader.bin.hash zerosbk
[ 6.6785 ]
[ 6.6816 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr.bin
[ 6.6833 ]
[ 6.6862 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader mts_c10_prod_cr.bin zerosbk
[ 6.6877 ] adding BCH for mts_c10_prod_cr.bin
[ 6.7731 ]
[ 6.7757 ] tegrasign_v3.py --key None --list mts_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 6.7758 ] Assuming zero filled SBK key
[ 6.7870 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader.bin.encrypt mts_c10_prod_cr_sigheader.bin.hash zerosbk
[ 6.8239 ]
[ 6.8261 ] tegrahost_v2 --chip 0x19 --align bpmp_t194.bin
[ 6.8268 ]
[ 6.8286 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader bpmp_t194.bin zerosbk
[ 6.8293 ] adding BCH for bpmp_t194.bin
[ 6.8467 ]
[ 6.8492 ] tegrasign_v3.py --key None --list bpmp_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 6.8493 ] Assuming zero filled SBK key
[ 6.8551 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp_t194_sigheader.bin.encrypt bpmp_t194_sigheader.bin.hash zerosbk
[ 6.8756 ]
[ 6.8796 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p2888-a01.dtb
[ 6.8819 ]
[ 6.8855 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader tegra194-a02-bpmp-p2888-a01.dtb zerosbk
[ 6.8876 ] adding BCH for tegra194-a02-bpmp-p2888-a01.dtb
[ 6.9315 ]
[ 6.9341 ] tegrasign_v3.py --key None --list tegra194-a02-bpmp-p2888-a01_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 6.9342 ] Assuming zero filled SBK key
[ 6.9402 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p2888-a01_sigheader.dtb.encrypt tegra194-a02-bpmp-p2888-a01_sigheader.dtb.hash zerosbk
[ 6.9514 ]
[ 6.9535 ] tegrahost_v2 --chip 0x19 --align spe_t194.bin
[ 6.9543 ]
[ 6.9562 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader spe_t194.bin zerosbk
[ 6.9569 ] adding BCH for spe_t194.bin
[ 6.9590 ]
[ 6.9614 ] tegrasign_v3.py --key None --list spe_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 6.9615 ] Assuming zero filled SBK key
[ 6.9665 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader.bin.encrypt spe_t194_sigheader.bin.hash zerosbk
[ 6.9684 ]
[ 6.9704 ] tegrahost_v2 --chip 0x19 --align tos-trusty_t194.img
[ 6.9711 ]
[ 6.9731 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader tos-trusty_t194.img zerosbk
[ 6.9738 ] adding BCH for tos-trusty_t194.img
[ 6.9821 ]
[ 6.9846 ] tegrasign_v3.py --key None --list tos-trusty_t194_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 6.9847 ] Assuming zero filled SBK key
[ 6.9894 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-trusty_t194_sigheader.img.encrypt tos-trusty_t194_sigheader.img.hash zerosbk
[ 6.9948 ]
[ 6.9972 ] tegrahost_v2 --chip 0x19 --align eks.img
[ 6.9996 ]
[ 7.0032 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader eks.img zerosbk
[ 7.0053 ] adding BCH for eks.img
[ 7.0059 ]
[ 7.0105 ] tegrasign_v3.py --key None --list eks_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 7.0107 ] Assuming zero filled SBK key
[ 7.0213 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_sigheader.img.encrypt eks_sigheader.img.hash zerosbk
[ 7.0239 ]
[ 7.0278 ] tegrahost_v2 --chip 0x19 --align tegra194-p2888-0001-p2822-0000.dtb
[ 7.0303 ]
[ 7.0341 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --ratchet_blob ratchet_blob.bin --appendsigheader tegra194-p2888-0001-p2822-0000.dtb zerosbk
[ 7.0362 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 7.0545 ]
[ 7.0595 ] tegrasign_v3.py --key None --list tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 7.0598 ] Assuming zero filled SBK key
[ 7.0735 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[ 7.0852 ]
[ 7.0891 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_cpu_t194.bin
[ 7.0916 ]
[ 7.0961 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader nvtboot_recovery_cpu_t194.bin zerosbk
[ 7.0984 ] adding BCH for nvtboot_recovery_cpu_t194.bin
[ 7.1139 ]
[ 7.1177 ] tegrasign_v3.py --key None --list nvtboot_recovery_cpu_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.1179 ] Assuming zero filled SBK key
[ 7.1276 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_cpu_t194_sigheader.bin.encrypt nvtboot_recovery_cpu_t194_sigheader.bin.hash zerosbk
[ 7.1355 ]
[ 7.1358 ] Copying signed file in /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/signed
[ 7.2779 ] tegraparser_v2 --pt flash.xml.bin --generateflashindex /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/signed/flash.xml.tmp flash.idx
[ 8.8429 ]
Error: /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader//flash.idx is not found
Error: failed to relocate images to /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images
Cleaning up...
I’ve tried debugging the build process but alas it seems to be failing at the start of a new step and I unfortunately don’t know what it is. The flash.idx file does exist in ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/signed/ but not anywhere in /home/tad/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/
Any ideas? Thanks.
