Problems with the summation of arrays There are no values ​​in the array
Hi all!
I am new in CUDA programming.
Wrote program to sum ​​two arrays in the third array.
For some reason, the target array C is always zero, even after adding … do not tell what I’m doing wrong?
The source code Cuda.cu:
#include <iostream>
#include <cuda_runtime.h>
__global__ void sum(float *A, float *B, float *C)
    int n = blockDim.x * blockIdx.x + threadIdx.x;
    C[n] = A[n] + B[n];
void StartSum(float *A, float *B, float *C, int N)
    sum<<< N/64, 64 >>>(A, B, C) ;
The source code to initialize arrays and calling summation:
#include <windows.h>
#include <cuda.h>
#include <cuda_runtime_api.h>
#include <iostream>
#define N 5
void StartSum(float *A, float *B, float *C, int n);
int main()
    float a[N] = {1,2,3,4,5}, b[N]={-2,-4,5,7,1}, c[N] = {0,0,0,0,0};
    cudaError_t err;
    float *dev_a , *dev_b , *dev_c ;
    cudaSetDevice(0);
    cudaMalloc((void**)&dev_a , sizeof (float)*N);
    cudaMalloc((void**)&dev_b , sizeof (float)*N);
    cudaMalloc((void**)&dev_c , sizeof (float)*N);
    err = cudaMemcpy(dev_a, a, sizeof(float)*N, cudaMemcpyHostToDevice);
    err = cudaMemcpy(dev_b, b, sizeof(float)*N, cudaMemcpyHostToDevice);
    err = cudaMemcpy(dev_c, c, sizeof(float)*N, cudaMemcpyHostToDevice);
    StartSum(dev_a, dev_b, dev_c, N);
    err = cudaMemcpy(c, dev_c, sizeof(float), cudaMemcpyDeviceToHost);
    for (int i = 0; i<N; i++)
        std::cout<<c[i]<<" ";
    std::cout<<std::endl;
    system("PAUSE");
In deriving the results always get zero … std::cout<<c[i]<<" ";
Thank you in advance for your help.
your problem (at least your first problem) is that your kernel is never called since 5/64=0…
Should you check the pre-launch error status, you would have get an “invalid configuration argument” error due to this. To convince yourself, just try this:
$ cat gridDim.cu
#include <stdio.h>
#include <cuda.h>
__global__ void foo() {
	if (threadIdx.x==0)
		printf("in kernel, gridDim and blockDim are %d %d\n", gridDim.x, blockDim.x);
int main() {
	foo<<<0,1>>>();
	printf("%s\n", cudaGetErrorString(cudaGetLastError()));
	foo<<<1,1>>>();
	cudaDeviceSynchronize();
	foo<<<5/64,64>>>();
	return 0;
$ nvcc -arch=sm_21 -o gridDim gridDim.cu
$ ./gridDim
no error
in kernel, gridDim and blockDim are 1 1
Then, I guess you’ll also have to add a test somewhere in your kernel to avoid accessing out of bound data (like an “if(n<N)” test).
Thank you very much, dear Gilles_C!
It worked! :biggrin:
I will continue to study this interesting subject.
Sorry for the stupid question … sum two arrays happened.
How to find the sum of the elements of one array?
I tried to do this:
__global__ void Summation(float *A, float *C)
	*C += A[n];
but this option does not work …
I solved the problem this way:
for (int i=0; i<count; i++)
    *C += A[n];
Do you think this approach is correct, in terms of technology CUDA?
The problem it performs - the array is summed. But I doubt whether I came to this issue.
Thank you.
Last approach won’t help you much - sum of single array is performed by all cores not in parralel but serial way. Take a look at Parallel Reduction.
