I’m testing profile-feedback with pgcc. I’m working with a simple code
which contain lots of if-else blocks. The version included below
executes for about 15 seconds, while switching to the f2 function
reduces execution time to 12 seconds.
I would expect profile-feedback to find the correct execution paths
for me, but unfortunately the original version compiled with
profile-feedback still executes in 15 seconds. It seems that
exactly the same code is generated with and without profile-feedback:
I have recompiled both cases with -S option and the assembler code
was exactly the same (up to comments).
I have issued the following commands:
pgcc -O -Mpfi pf.c
./a.out
pgcc -O -Mpfo pf.c
For comparing assembler code:
pgcc -S -O -Mpfo pf.c
mv pf.s saved.s
pgcc -S -O pf.c
diff saved.s pf.s
The compiler’s version is:
pgcc 6.2-5 64-bit target on x86-64 Linux
Do I do something wrong?
The code follows (it is a slightly modified version of an example code from Sun website):
#include <stdio.h>
#include <stdlib.h>
unsigned f1(unsigned *a0, unsigned *a1, unsigned *a2,
unsigned *a3, unsigned *a4, unsigned *a5) {
unsigned result = 0;
if (a0 != NULL) { result += (*a0); } else { printf("a0 == NULL"); }
if (a1 != NULL) { result += (*a1); } else { printf("a1 == NULL"); }
if (a2 != NULL) { result += (*a2); } else { printf("a2 == NULL"); }
if (a3 != NULL) { result += (*a3); } else { printf("a3 == NULL"); }
if (a4 != NULL) { result += (*a4); } else { printf("a4 == NULL"); }
if (a5 != NULL) { result += (*a5); } else { printf("a5 == NULL"); }
return result;
unsigned f2(unsigned *a0, unsigned *a1, unsigned *a2,
if (a0 == NULL) { printf("a0 == NULL"); } else { result += (*a0); }
if (a1 == NULL) { printf("a1 == NULL"); } else { result += (*a1); }
if (a2 == NULL) { printf("a2 == NULL"); } else { result += (*a2); }
if (a3 == NULL) { printf("a3 == NULL"); } else { result += (*a3); }
if (a4 == NULL) { printf("a4 == NULL"); } else { result += (*a4); }
if (a5 == NULL) { printf("a5 == NULL"); } else { result += (*a5); }
return result;
void main(int argc, const char *argv[]) {
int i, j, niters = 1, n = 6;
unsigned sum, answer = 0, a[6];
niters = 1000000000;
if (argc == 2) {
niters = atoi(argv[1]);
for (j = 0; j < n; j++) {
a[j] = rand();
answer += a[j];
for (i = 0; i < niters; i++) {
sum = f1(a + 0, a + 1, a + 2, a + 3, a + 4, a + 5);
if (sum == answer) {
printf("answer = %u\n", answer);
} else {
printf("error sum=%u, answer=%u", sum, answer);
