basic information
System: Linux(ubuntu16.04)
GPU: NVIDIA RTX 2080
CUDA: cuda-9.0, cudnn7.4.2
problem description:
cuda-memcheck my executable gives this information:
Program hit cudaErrorInvalidValue (error 11) due to “invalid argument” on CUDA API call to cudaFuncSetAttribute.
deviceQuery result:
./deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: “GeForce RTX 2080”
CUDA Driver Version / Runtime Version 10.1 / 9.0
CUDA Capability Major/Minor version number: 7.5
Total amount of global memory: 7951 MBytes (8337227776 bytes)
MapSMtoCores for SM 7.5 is undefined. Default to use 64 Cores/SM
(46) Multiprocessors, ( 64) CUDA Cores/MP: 2944 CUDA Cores
GPU Max Clock rate: 1815 MHz (1.81 GHz)
Memory Clock rate: 7000 Mhz
Memory Bus Width: 256-bit
L2 Cache Size: 4194304 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 1024
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 3 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 10.1, CUDA Runtime Version = 9.0, NumDevs = 1
Result = PASS
problem description
I’m trying to poring my project(cuBlas/CuDNN based), from Windows 7 to Linux(ubuntu 16.04).
My code run OK on Windows but failed on Linux. After googling around, I use cuda-memcheck to figure out what the bug is. The minimal code to reproduce the error (as the title) is:
#include <cuda.h>
#include <cublas_v2.h>
#include <cudnn.h>
#include <stdio.h>
#include <iostream>
using namespace std;
#define cudaDrvCheck(call) \
const CUresult state = call; \
if ((state) != cudaSuccess) { \
fprintf(stderr, "CUDA Driver Error: %s %s %d\n", getCudaDrvErrorString(state), __FILE__, __LINE__); \
exit(1); \
#define cudaErrCheck(condition) \
do { \
cudaError_t error = condition; \
if (error != cudaSuccess) { \
fprintf(stderr, "CUDA Error: %s %s %d\n", cudaGetErrorString(error), __FILE__, __LINE__); \
exit(-1); \
} while (0)
#define cublasErrCheck(condition) \
do { \
cublasStatus_t status = condition; \
if (status != CUBLAS_STATUS_SUCCESS) { \
fprintf(stderr, "cublas Error: error code : %d %s %d\n", status, __FILE__, __LINE__); \
exit(-1); \
} while (0)
#define cudnnErrCheck(condition) \
do { \
cudnnStatus_t status = condition; \
if (status != CUDNN_STATUS_SUCCESS) { \
fprintf(stderr, "cuDNN Error: %s %s %d\n", cudnnGetErrorString(status), __FILE__, __LINE__); \
exit(-1); \
} while (0)
typedef struct RockEngine {
cublasHandle_t handle_cublas;
cudnnHandle_t handle_cudnn;
} RockEngine;
int main() {
RockEngine* engine = (RockEngine*)malloc(sizeof(RockEngine));
cudaError_t cuda_status = cudaSetDevice(0);
cudaErrCheck(cuda_status);
int gpu_id=0;
cudaErrCheck(cudaGetDevice(&gpu_id));
cout << "!!! gpu_id is " << gpu_id << endl;
cudnnStatus_t cudnn_status = cudnnCreate(&engine->handle_cudnn);
cudnnErrCheck(cudnn_status);
cublasStatus_t cublas_status = cublasCreate(&engine->handle_cublas);
cublasErrCheck(cublas_status);
return 0;
What do I execute
After compilation, the executable I get is called “rock”.
What I’m running is:
cuda-memcheck rock > log.txt 2>&1
The whole log
on my machine (whose information is listed in the very begin of this question), the log.txt is:
!!! gpu_id is 0
I! CuDNN (v7402) function cudnnCreate() called:
i! Time: 2019-08-22T15:24:10.299850 (0d+0h+0m+0s since start)
i! Process=768; Thread=768; GPU=NULL; Handle=NULL; StreamId=NULL.
========= CUDA-MEMCHECK
========= Program hit cudaErrorInvalidValue (error 11) due to "invalid argument" on CUDA API call to cudaFuncSetAttribute.
========= Saved host backtrace up to driver entry point at error
========= Host Frame:/usr/lib/x86_64-linux-gnu/libcuda.so.1 [0x390523]
========= Host Frame:/usr/local/cuda-9.0/lib64/libcudnn.so.7 [0x157f001]
========= Host Frame:/usr/local/cuda-9.0/lib64/libcudnn.so.7 [0x13ab8be]
========= Host Frame:/usr/local/cuda-9.0/lib64/libcudnn.so.7 [0x13abc20]
========= Host Frame:/usr/local/cuda-9.0/lib64/libcudnn.so.7 [0x104d928]
========= Host Frame:/usr/local/cuda-9.0/lib64/libcudnn.so.7 (cudnnCreate + 0x5b5) [0x95705]
========= Host Frame:rock [0x3690]
========= Host Frame:/lib/x86_64-linux-gnu/libc.so.6 (__libc_start_main + 0xf0) [0x20830]
========= Host Frame:rock [0x34b9]
========= Host Frame:/usr/local/cuda-9.0/lib64/libcublas.so.9.0 [0x405871]
========= Host Frame:/usr/local/cuda-9.0/lib64/libcublas.so.9.0 [0x3992f5]
========= Host Frame:/usr/local/cuda-9.0/lib64/libcublas.so.9.0 [0x399620]
========= Host Frame:/usr/local/cuda-9.0/lib64/libcublas.so.9.0 (cublasCreate_v2 + 0x3e8) [0x79358]
========= Host Frame:rock [0x36e6]
========= ERROR SUMMARY: 36 errors
However, on my another machine, which is ubuntu16.04 with GTX 1080Ti GPU, cuda-9.0, the log is without any error. I wonder why this error occur, and how can I resolve it? Thanks for any suggestions.
