When I run my tensorflow model on tx2,something wrong with protobuf version occured.Like this:
nvidia@tegra-ubuntu:~/ext$ python3 test_lanenet.py
[libprotobuf FATAL google/protobuf/stubs/common.cc:61] This program requires version 3.5.0 of the Protocol Buffer runtime library, but the installed version is 2.6.1. Please update your library. If you compiled the program yourself, make sure that your headers are from the same version of Protocol Buffers as your link-time library. (Version verification failed in "bazel-out/arm-py3-opt/genfiles/tensorflow/contrib/tpu/proto/tpu_embedding_config.pb.cc".)
terminate called after throwing an instance of 'google::protobuf::FatalException'
what(): This program requires version 3.5.0 of the Protocol Buffer runtime library, but the installed version is 2.6.1. Please update your library. If you compiled the program yourself, make sure that your headers are from the same version of Protocol Buffers as your link-time library. (Version verification failed in "bazel-out/arm-py3-opt/genfiles/tensorflow/contrib/tpu/proto/tpu_embedding_config.pb.cc".)
Aborted (core dumped)
It meaning that I should update my protobuf from 2.6.1 to 3.5.0, but actually I have already installed protobuf version 3.5.0.post1 inside tx2.
Because when I execute uninstall command like this:
nvidia@tegra-ubuntu:~/ext$ pip3 uninstall protobuf
Uninstalling protobuf-3.5.0.post1:
Would remove:
/home/nvidia/.local/lib/python3.5/site-packages/google/protobuf/*
/home/nvidia/.local/lib/python3.5/site-packages/protobuf-3.5.0.post1-py2.7-nspkg.pth
/home/nvidia/.local/lib/python3.5/site-packages/protobuf-3.5.0.post1.dist-info/*
Proceed (y/n)? n
It shown that it will uninstall protobuf version 3.5.0.post1
It seems that although I have install protobuf with right version, but tensorflow will always call the wrong version 2.6.1 protobuf.
How can I tell tensorflow to call the installed right version protobuf?
Could you try following command if helps?
1. Refresh shared library cache
sudo ldconfig
2. Uninstall library
pip uninstall protobuf==2.6.1
I have the same issue. I tried the above, but no luck.
This is the error I am getting:
Using TensorFlow backend.
I tried to install different versions of tensorflow, but no luck.
I tried to removed and recompiled protobuf 3.6 as specified in c++ - upgrading protobuf tensorflow on jetson tx2 - Stack Overflow but still same error.
Some additional info:
$which protoc
/usr/local/bin/protoc
$protoc --version
libprotoc 3.5.0
$pip3 show protobuf
Metadata-Version: 2.0
Version: 3.6.1
Summary: Protocol Buffers
Any ideas on how to fix this, would be greatly appreciated.
Which TensorFlow package do you use? Do you want to use a custom wheel?
It’s recommended to use our official TensorFlow with JetPack3.3 here:
[url]https://devtalk.nvidia.com/default/topic/1038957/jetson-tx2/tensorflow-for-jetson-tx2-/[/url]
did you find a solution? I have the same problem.
@eric.tondelli, could you extend , please?
are you using instructions from the post above?
what errors are you getting?
yes i have installed tensorflow with
pip install --extra-index-url https://developer.download.nvidia.com/compute/redist/jp33 tensorflow-gpu
I am inside a virtualenv with python 2.7.11+
“import tensorflow” is working
I receive this error when execute my script
"[libprotobuf FATAL google/protobuf/stubs/common.cc:61] This program requires version 3.5.0 of the Protocol Buffer runtime library, but the installed version is 2.6.1. Please update your library. If you compiled the program yourself, make sure that your headers are from the same version of Protocol Buffers as your link-time library. (Version verification failed in "external/protobuf_archive/src/google/protobuf/any.pb.cc".)
what(): This program requires version 3.5.0 of the Protocol Buffer runtime library, but the installed version is 2.6.1. Please update your library. If you compiled the program yourself, make sure that your headers are from the same version of Protocol Buffers as your link-time library. (Version verification failed in "external/protobuf_archive/src/google/protobuf/any.pb.cc".)
Aborted (core dumped)"
With pip show protobuf i get
Version: 3.6.1
Home-page: https://developers.google.com/protocol-buffers/
Author: protobuf@googlegroups.com
Author-email: protobuf@googlegroups.com
License: 3-Clause BSD License
Location: /home/nvidia/Berkeley/lib/python2.7/site-packages
Requires: setuptools, six
Required-by: tensorflow-gpu, tensorboard
Have you any ideas how to solve this error?
Try this:
sudo pip uninstall protobuf
sudo pip install protobuf==3.5.0
pip show protobuf
Hi AastaLL,
thanks for the reply. Unfortunately i have tried this approach but with no luck.
The only way i have found is to import tensorflow at the beginning of my python file.
If someone have some ideas why it is working can explain me?
Thanks,
Eric
I have written a simple python script which has only one line “import tensorflow as tf”.
I am calling the same script from my c++ code (Using Python.h header to call python script from c++ code).
I am getting following error related to libprotobuf.
[libprotobuf FATAL google/protobuf/stubs/common.cc:61] This program requires version 3.5.0 of the Protocol Buffer runtime library, but the installed version is 2.6.1. Please update your library. If you compiled the program yourself, make sure that your headers are from the same version of Protocol Buffers as your link-time library. (Version verification failed in “external/protobuf_archive/src/google/protobuf/any.pb.cc”.)
terminate called after throwing an instance of ‘google::protobuf::FatalException’
what(): This program requires version 3.5.0 of the Protocol Buffer runtime library, but the installed version is 2.6.1. Please update your library. If you compiled the program yourself, make sure that your headers are from the same version of Protocol Buffers as your link-time library. (Version verification failed in “external/protobuf_archive/src/google/protobuf/any.pb.cc”.)
I have tried following things but still it didn’t solve my problem.
sudo pip install protobuf==3.6.1
Installing libprotobuf-dev
Refer link : 3.6.1.3-1 : libprotobuf-dev : arm64 : Disco (19.04) : Ubuntu
Steps :
a) uninstall libprotobuf if existing. Command : sudo apt-get remove --purge libprotobuf-dev
b) Download libprotobuf dependencies (zlib1g-dev, libprotobuf17, libprotobuf-lite17)
c) Download and Install libprotobuf-dev_3.6.1.
Installing libprotobuf library for c++ from its source code (I installed version 3.5.0)
Refer link : c++ - upgrading protobuf tensorflow on jetson tx2 - Stack Overflow
Steps :
Note: I am using Nvidia Jetson TX2 and I have installed tensorflow using command “sudo pip3 install --extra-index-url https://developer.download.nvidia.com/compute/redist/jp33 tensorflow-gpu”.
Please help me solve the above issue. Thanks in advance.
