I used the instructions from here the Python 3.6+JetPack4.6.3 section but each time i have this error
protobuf requires Python ‘>=3.7’ but the running Python is 3.6.9
on the last step. I check other topics related to this but no one ever had this issue.
this is the output of the command apt-cache show nvidia-jetpack
Package: nvidia-jetpack
Version: 4.6-b199
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-cuda (= 4.6-b199), nvidia-opencv (= 4.6-b199), nvidia-cudnn8 (= 4.6-b199), nvidia-tensorrt (= 4.6-b199), nvidia-visionworks (= 4.6-b199), nvidia-container (= 4.6-b199), nvidia-vpi (= 4.6-b199), nvidia-l4t-jetson-multimedia-api (>> 32.6-0), nvidia-l4t-jetson-multimedia-api (<< 32.7-0)
Homepage: Jetson - Embedded AI Computing Platform | NVIDIA Developer
Priority: standard
Section: metapackages
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6-b199_arm64.deb
SHA256: 69df11e22e2c8406fe281fe6fc27c7d40a13ed668e508a592a6785d40ea71669
SHA1: 5c678b8762acc54f85b4334f92d9bb084858907a
MD5sum: 1b96cd72f2a434e887f98912061d8cfb
Description: NVIDIA Jetpack Meta Package
and also, i have an issue with jtop, I keep on having this when trying to launch it
The jtop.service is not active. Please run:
sudo systemctl restart jtop.service
it is an infinite loop, I run the restart command, even restart the device but I still get the same output.
please I need help it been several weeks I am trying to find a solution.
Blockquote
