I have a Nano Jetson and flashed it with the latest available Jetpack version from here: https://developer.nvidia.com/embedded/learn/get-started-jetson-nano-devkit which is 4.6.1. Now when following this guide to install tensorflow: Installing TensorFlow for Jetson Platform :: NVIDIA Deep Learning Frameworks Documentation I checked the version of tensorflow I need here: TensorFlow for Jetson Platform Release Notes :: NVIDIA Deep Learning Frameworks Documentation which is following command: sudo pip3 install --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v461 tensorflow==2.7.0+nv22.01 now when I run this command I get following error:
ERROR: Could not find a version that satisfies the requirement h5py~=3.1.0 (from tensorflow) (from versions: 2.2.1, 2.3.0b1, 2.3.0, 2.3.1, 2.4.0b1, 2.4.0, 2.5.0, 2.6.0, 2.7.0rc2, 2.7.0, 2.7.1, 2.8.0rc1, 2.8.0, 2.9.0rc1, 2.9.0, 2.10.0, 3.0.0rc1, 3.0.0, 3.1.0)
ERROR: No matching distribution found for h5py~=3.1.0
which doesn’t even make sense, since 3.1.0 is in the list of available versions. When I try to manually install h5py 3.1.0 it fails a few times and keeps trying to install older versions after which it finally successfully installs h5py version 2.10.0, which is obviously too old for the version needed for the tensorflow version for my jetpack version. How can I install tensorflow on my nano jetson with Jetpack version 4.6.1?
