Into latest jetpack 4.6
hi, @pedro.valdes.guzman. Can please refer this documentation Installing TensorFlow for Jetson Platform :: NVIDIA Deep Learning Frameworks Documentation. Hope this will help you.
Thank you
ainβt actual, Iβm taking about jetpack 4.6, the latest, this didnβt helped me. Thanx
Sorry, I was missing. Iβll try once more.
I am having the same problem; attempting to install tensor into JP 4.6 on Jetson Nano 2GB using these instructions; Installing TensorFlow for Jetson Platform :: NVIDIA Deep Learning Frameworks Documentation yields these errors
sudo env H5PY_SETUP_REQUIRES=0 pip3 install -U h5py==3.1.0
Downloading h5py-3.1.0.tar.gz (371 kB)
|ββββββββββββββββββββββββββββββββ| 371 kB 2.5 MB/s
Installing build dependencies ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-6uer_3bk/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- setuptools wheel
cwd: None
Complete output (29 lines):
File "/usr/lib/python3.6/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/local/lib/python3.6/dist-packages/pip/_vendor/tenacity/__init__.py", line 26, in <module>
from concurrent import futures
File "/usr/local/lib/python3.6/dist-packages/concurrent/futures/__init__.py", line 8, in <module>
from concurrent.futures._base import (FIRST_COMPLETED,
File "/usr/local/lib/python3.6/dist-packages/concurrent/futures/_base.py", line 357
raise type(self._exception), self._exception, self._traceback
SyntaxError: invalid syntax
ERROR: Could not find a version that satisfies the requirement h5py==3.1.0 (from versions: 2.2.1, 2.3.0b1, 2.3.0, 2.3.1, 2.4.0b1, 2.4.0, 2.5.0, 2.6.0, 2.7.0rc2, 2.7.0, 2.7.1, 2.8.0rc1, 2.8.0, 2.9.0rc1, 2.9.0, 2.10.0, 3.0.0rc1, 3.0.0, 3.1.0)
ERROR: No matching distribution found for h5py==3.1.0
