Good Evening,
I was following the instructions here to try and install TensorFlow to my jetson nano in a virtual environment.
I tried to upgrade to jetpack 5.5, but I am not sure how to tell if it actually worked, which if it didn’t doing that may solve the issue I am seeing.
When pip tries to build and install h5py, I see an error message about
ERROR: Command errored out with exit status -4:
command: /home/user/Code/TensorFlow/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-go1xiwnd/h5py_df959324472048b0bac6e0ddb14b4a65/setup.py'"'"'; __file__='"'"'/tmp/pip-install-go1xiwnd/h5py_df959324472048b0bac6e0ddb14b4a65/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-1vdd9rok
cwd: /tmp/pip-install-go1xiwnd/h5py_df959324472048b0bac6e0ddb14b4a65/
which is a bit cryptic to me, but I was hoping to get some advice on how to hopefully solve this problem so that the install goes correctly.
